texber2012
Cannot open Encore projects CS 5.1
Jun 9, 2013 7:17 PM
I am trying to open two completed Encore projects, so far no luck.  I get the following message - "" Could not create "Blu-ray NTSC 1280x720 24p MPEG-2.epr". The path is not valid."  The projects were completed about two months ago.
Please let me know if there is a solution to this.  Thanks.  I do not look forward to starting the projects from scratch.
    Jun 9, 2013 7:39 PM   in reply to texber2012
    Encore is not finding a preset. Are your presets in this location?: (For win7)
    C:\Program Files\Adobe\Adobe Encore CS6\Presets\Internal
    Jun 10, 2013 6:40 AM   in reply to texber2012
    And the part of the path you left out includes "...(x86)/Adobe/Adobe Encore CS5.1/Presets"?
    Encore (all adobe programs?) keep versions separate by install directories.
    I am assuming that is yes. Can we also assume the projects were completed in CS5.1?
    I don't know why this error would come up unless something changed.
    Jun 11, 2013 11:13 AM   in reply to texber2012
    Are you running Encore "as administrator"? Not just as a user with administrative rights.
    Can you open Encore before opening a project? Can you create a new project?
    Jun 11, 2013 11:38 AM   in reply to texber2012
    No idea what is going on.
    Create a new project, add an asset as timeline (doesn't matter what it is), then right click on the asset and pick transcode settings. Under Bluray, set to mpeg, pixel size as in your error message, and see if you can pick a preset from the list. Select and save. Does that work?
    This further checks the functionality of the presets.
    We have to suspect a corrupt Encore project.
    Jun 11, 2013 6:35 PM   in reply to texber2012
    No idea.
    So the file that should be:
    was:
    Blu-ray NTSC 1280x720 24p MPEG-2.epr.rej
    OR
    Blu-ray NTSC 1280x720 24p MPEG-2.rej
    Jun 11, 2013 9:17 PM   in reply to texber2012
    Congrats on going back to look at those files, and thanks for reporting back!
