Eel River
this is about updateing CS6 Photoshop
Jun 10, 2013 9:35 AM
Tags: #updates #update_server
I keep getting the following error messages when I update from the Photoshop help/update selection
Extension Manager 6.0.6 Update
Installation failed. Error Code: U44M1P7
Adobe Photoshop 13.0.1.2
    Jun 10, 2013 10:12 AM   in reply to Eel River
    I have this same error. I uninstalled PS then downloaded again and reinstalled. Same result. My PS version is showing 13.0.1.2 as well.
    Here are the three errors from the install log
    ---------------------------------------------------------------------- --- Begin Log
    06/10/13 09:33:34:769 | [INFO] |  | OOBE | DE |  |  |  | 17560 | ERROR: DF045: File corruption detected. Re-install the product & then apply the patch again. (Can not repair file "C:\Program Files (x86)\Adobe\Adobe Photoshop CS6\boost_threads.dll")(Seq 15)
    06/10/13 09:33:34:769 | [INFO] |  | OOBE | DE |  |  |  | 17560 | ----------- Payload: Adobe Photoshop CS6 Core_x64_13.1.2_AdobePhotoshop13-Core_x64 13.1.2.0 {59482051-CFF2-47AE-B944-A7352D74A8B5} -----------
    06/10/13 09:33:34:769 | [INFO] |  | OOBE | DE |  |  |  | 17560 | ERROR: DF045: File corruption detected. Re-install the product & then apply the patch again. (Can not repair file "C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Plugin.dll")(Seq 14)
    06/10/13 09:33:34:769 | [INFO] |  | OOBE | DE |  |  |  | 17560 | ----------- Payload: Adobe Photoshop CS6 Support_13.1.2_AdobePhotoshop13-Support 13.1.2.0 {B65FABC3-FCF2-4BE6-B12A-600CA2EBFB9D} -----------
    06/10/13 09:33:34:769 | [INFO] |  | OOBE | DE |  |  |  | 17560 | ERROR: DF045: File corruption detected. Re-install the product & then apply the patch again. (Can not repair file "C:\Program Files (x86)\Common Files\Adobe\Adobe Photoshop CS6\patcher_trigger\patchTrigger")(Seq 5)
    Jun 11, 2013 10:02 AM   in reply to visualtotems
    The U44M1P7 error indicates noting more than the update has failed.
    Visualtotems you are correct to look at your installation log which displays your particular failure with the update.  The error is as follows:
    Please follow the suggestion of removing and reinstalling Photoshop CS6.
    Eel River for information on how to review your installation logs and deal with update failures, indicated by U44M1P7, please see Installation failed. Error U44M1P7 | Updates - http://helpx.adobe.com/creative-suite/kb/error-u44m1p7-installing-upda tes-ccm.html.
    Jun 11, 2013 5:52 PM   in reply to Jeff A Wright
    Jeff, I already did so and got the same result again. However, being this close to the release of PS CC, I may just bide my time and upgrade on release anyhow.
    Also, tried the direct update as suggested by the link you provided but no go - the downloads page did not contain the stand alone update for this current version.
    Jun 12, 2013 8:39 AM   in reply to visualtotems
    Many of the feature bearing updates are only available through the Adobe Application Manager.  Odd that you got the file corruption error again though.  If you continue to experience difficulties next week you may want to look at the logs for the downloads of the installers themselves.  The download logs can be found in the following locations:
    On Windows, %temp%\AdobeDownloads\
    On Mac, ~/Library/Logs/Adobe/AdobeDownloads/
    Jun 16, 2013 2:29 PM   in reply to Jeff A Wright
    Jeff, tried again today (still planning to move to PSCC when released) and got the same result, even after reinstalling. These are the files that fail with error DF045:
    plugin.dll
    boost_threads.dll
    "patchTrigger"
    Jun 16, 2013 3:54 PM   in reply to visualtotems
    You might look at your download logs Visualtotems.  You can look use a similar method as looking at the installation logs and do a search on the word error.
    Jun 16, 2013 5:40 PM   in reply to Jeff A Wright
    Where are the download logs located?
    Jun 17, 2013 8:42 AM   in reply to visualtotems
    They are in the following locations:
  • kglad
    Jul 21, 2002
    Jun 17, 2013 11:12 AM   in reply to visualtotems
    if you're trying to update ps 13.0.1.2 to 13.1.2,
    1. uninstall ps
    2. reinstall using adobe application manager.
    3. close aam after installation is complete.
    4. open ps>click help>update and select 13.1.2.  (do not update to  13.0.1.2 first.)
    Jun 17, 2013 3:30 PM   in reply to kglad
    That did the trick, kglad! Thank you!
  • kglad
    Jul 21, 2002
    Jun 17, 2013 3:37 PM   in reply to visualtotems
    you're welcome.
