SirSkorpan
why does the knife tool leave gaps in the shape? (CS6)
Jun 11, 2013 2:32 PM
Tags: #illustrator #problem #bug #tool #knife_tool
When I use the knife tool on an shapeit leaves a gap where I slice. First I thought it was just an illusion in the program but it stays even after I've exported the image (both by "save as" in illustrator and "export" in inDesign). I've been careful not to move the shapeafter I used the tool so I don't think that should be a reason.
I've tried on different types of shapes like normal circles and more complex shapes. I've also attempted to start a new file from scratch but with the same result  What could the reason be? Is there a setting I should be aware of?
This is what I see in Illustrator:
And this is what the image looks like when saved as pdf (in illustrator):
It also looks the same if I place it in inDesign and then export to pdf.
EDIT: I don't know if it is important but the size of the shape is about an A4 or there about.
Best regards,
SirSkorpan
    Jun 11, 2013 3:03 PM   in reply to SirSkorpan
    That's caused by anti-aliasing and is a screen issue.
    Turn off anti-aliasing in preferences and it should be gone.
    Jun 12, 2013 11:43 AM   in reply to SirSkorpan
    No worries should go away for all formats, with a slight exception .pdf. Do a test save for web to confirm.
    For PDF you need to uncheck Smooth Line Art in Acrobat >> Page Display >> Preferences.
    Unfortuantely you cannot chaneg this preference for the person viewing your document. If that is a concern,  in illustrator object >> rasterize. You will lose vector, but in most cases would be worth rasterizing.
