Dermfellow
"Invalid Key" and EKAG20NT.EXE error
Jun 12, 2013 12:37 AM
Tags: #error #premiere_pro_cs6
After trying to update my computer with an SSD, then returning to the original HDD's, I now get an error that says I have an invalid key. If I click through, it gives me an "Incorrect EKAG20NT.EXE version (internal error, API V2.00)". The program appears to load normally, and seems to function normally while editing, but I don't want to get in the middle of this rather large project and get stranded.
It does not happen with AE, PS, Audition, or any other programs in the Production Suite. I have a Dell Precision T5600 twin Xeon Workstation. It does use a PERC 310 raid controller with two main 350GB enterprise drives. All video file data is kept off the machine on external eSATA drives.
Any idea why this happened, and how I can fix it?
Thank you-
Addendum: It also happens if I export a file for encoding to Media Encoder.
    Jun 12, 2013 2:07 AM   in reply to Dermfellow
    See http://www.file.net/process/ekag20nt.exe.html
    You may want to remove that file. It is not normally installed on a system due to its key-logger nature.
    Jun 12, 2013 6:17 AM   in reply to Dermfellow
    Have you ever installed the x264Pro plug-in?  If so, then that's probably the source of your issue.  Changing the hardware configuration will invalidate the current license key.  Contact 3AM Digital Studios to get it sorted.
    Jeff
    Jun 12, 2013 8:50 AM   in reply to Jeff Bellune
    Jeff
    please contact 3am directly at support@3amDigitalStudios.com so that we can help you (if you didn't already a month ago).
    Yes, "Invalid Key" is a license problem when some hardware changes, not a bug or virus. I just became aware of this thread today.
