matttm
Saved  PDF won't display base color
Jun 12, 2013 2:14 AM
Tags: #illustrator #problem #help #pdf #saving #cs6
In Illustrator, I save a vector clouds with a blue backround. However, once saved as a PDF, the blue sky doesn'y appear. Just the white clouds on a checkerboard backround appear.
I have checked, the layer isn't locked.
    Jun 12, 2013 6:46 AM   in reply to matttm
    Is the blue background on a seperate layer? If the layer name is in Italics you have the the layer option for print unchecked.
    By default the print layers option is set to visible and printable. This setting affects PDF output. You can change that to visible layers.
    In any case test to see if this is a layer related issue and if items on the layer with the blue backgorund show up transparent.
    Jun 14, 2013 1:46 PM   in reply to matttm
    In your screen shot the layer with the sky is locked.
