ic3man7019
How might you draw a border around a rectangle in Flex?
Jun 12, 2013 12:34 PM
Tags: #flex-4.6 #flex_mobile
I need to know how to draw a gray border around a rectangle using MXML, without filling the rectangle with any color. I also need to know how to design the screen so that the components (in this case I have a couple text input fields, a button, and a checkbox) appear within the rectangle. The rectangle should not take up the entire width or height of the screen.
    Jun 12, 2013 1:04 PM   in reply to ic3man7019
    Jun 13, 2013 8:45 AM   in reply to ic3man7019
    Use a Group. Set its width and heigth to whatever size. Inside the group use a Rect with width and height of 100%. Give it a stroke.
    Example:
    <s:Group width="100" height="100">
    <s:Rect width="100%" height="100%">
         <s:bottomLeftRadiusX>2</s:bottomLeftRadiusX>
         <s:bottomLeftRadiusY>2</s:bottomLeftRadiusY>
         <s:bottomRightRadiusX>2</s:bottomRightRadiusX>
         <s:bottomRightRadiusY>2</s:bottomRightRadiusY>
         <s:topLeftRadiusX>2</s:topLeftRadiusX>
         <s:topLeftRadiusY>2</s:topLeftRadiusY>
         <s:topRightRadiusX>2</s:topRightRadiusX>
         <s:topRightRadiusY>2</s:topRightRadiusY>
         <s:fill>
              <s:SolidColor color="#ffffff" />//if this color value doesn't work then use 0xffffff
         </s:fill>
         <s:stroke>
              <s:SolidColorStroke weight="1" color="#000000"  />//if this color value doesn't work then use 0x000000
         </s:stroke>
    </s:Rect>
    </s:Group>
