marshom
problem Module/datagrid, one time with data, one time is null
Jun 12, 2013 2:32 PM
Tags: #moduleloader #datagrid #selecteditems #doubleclick
Hello All
thanks for this discussion place, i have a problem in Flash Builder 4.6 (sdk 4.6.0), construct an application who connect to DB, for now, the CRUD works fine with flex service,
i have a problem with a datagrid, one time it's worked fine, and another time my obj is null, i cannot understand why.. the fact it's work one time trouble me.. and i have no error in console..
the target, is to edit a row of datagrid in popup, it's work as you stay in the ModuleClient, but when i launch another Module and come back to ModuleClient, the edit datagrid doesn't work anymore
i try to put the process here, as the app is large: (say to me if you want more code, i will try to isolate some pieces)
- click in ModuleMenu and load ModuleClient in ModuleContent
- dataGrid populate with ArrayCollection
- double click row in dataGrid (dataGrid_doubleClickHandler(event:MouseEvent))
- dataGridClients.selectedItem contains effective data
- push data to ValueObject (ClientObj) already defined in flex services/connected to DB
          var ClientDataGrid:ClientObj = dataGridClients.selectedItem as ClientObj;
- push data ClientDataGrid to Popup
          in Popup: <valueObjects:ClientObj id="clientObj"/>
- works fine
if i select another Module in ModuleMenu, and later relaunch ModuleClient
- ClientDataGrid is null
- cannot push data ClientDataGrid to Popup as ClientDataGrid is null
- doesn’t work
<s:DataGrid id="dataGridClients" left="0" right="230" top="66" bottom="10"
creationComplete="dataGrid_creationCompleteHandler(event)"
dataProvider="{clientListeSimpleResult.lastResult}"
doubleClick="dataGrid_doubleClickHandler(event)" doubleClickEnabled="true"
alternatingRowColors="[#FFFFFF, #f4f3f2]">
Thanks in advance for any advices/ideas
i think i make misunderstood of something, im not a flex/flash as3 coder
so any help would be greatly appreciated
best regards anyway
    Jun 12, 2013 9:24 PM   in reply to marshom
    There's a modules presentation on my blog (blogs.adobe.com/aharui).  It explains more on how modules work, especially that they are factories, not instances.  So often you load a module once in an app, then create multiple instances from the module's factory.
    HTH,
    -Alex
