the Future Store
Audio Conforming Issues
Jun 13, 2013 8:13 AM
Tags: #adobe #audio #premiere #bug #fcpx #conforming #fcp7
Will the next version Adobe Premiere adress the issue of audio conforming?
Try to import 1TB of footage that has 1 hour takes.
Do you how long it takes when you can start cutting?
If this can be done in FCP7 ( 32 bit app !!!!!! )   and FCPX , then why can't Premiere?
In a lot of cases, when you reopen the project , it starts conforming again!
Hello Adobe?
Running CS6 on 10.8
    Jun 13, 2013 8:25 AM   in reply to the Future Store
    >Hello Adobe?
    This is "mostly" a forum for users to help other users
    Tell Adobe at https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    Jun 13, 2013 9:41 AM   in reply to the Future Store
    What exactly is the 'issue' here?
    Jun 13, 2013 10:13 AM   in reply to the Future Store
    Audio conforming only takes place ones, when opening the files for the first time.
    It should not conform every time you open the project and have not added new footage/audio.
    Jun 13, 2013 2:20 PM   in reply to the Future Store
    1 day waiting for conforming on a fast setup.
    Thats an issue!
    Get even faster drives.  That really is the only way your 'issue' is going to be resolved, I'm afraid.
    Jun 14, 2013 5:50 AM   in reply to the Future Store
    They're two different programs that work differently.  Premiere Pro creates 32 bit floating point 'conformed' audio files for use within the program, allowing very fine precision audio editing and very high quality effects.  If you prefer the way FCP works, use that.
    Jun 14, 2013 6:58 AM   in reply to Ann Bens
    A bit off-topic, perhaps, but unfortunately, Premiere does recreate all peak files again, and again, and again and again.
    Jun 14, 2013 7:21 AM   in reply to Moergestel TV
    You can turn off automatic peak file generation in the preferences.
    And yes start a new thread if you have a different issue.
  • joe bloe premiere
    Dec 6, 2009
    Jun 14, 2013 8:30 AM   in reply to the Future Store
    You can file a feature request here:
    http://www.adobe.com/go/wish
    Jun 14, 2013 9:19 AM   in reply to the Future Store
    You are correct that Conforming to 32-bit floating point does not make the sound quality any better, but it does make editing more precise.
    Jun 15, 2013 5:14 PM   in reply to the Future Store
    Conforming a 16 bit audio file to 32 bit floating point doesn't make the quality of the 16 bit file better
    It does when you add effects.
    Jun 17, 2013 9:26 AM   in reply to Jim Simon
    after import of footage PP starts to build peakfiles to show the audio in the timeline.
    That is a non blocking process - so you can start to edit but havn't available the waveform display from start...
    If you have a fast HDD array or SSD this should go very fast - it takes just seconds fo me to generate the peakfiles for 14 feature length mono audio channels
    If PP "starts conforming audio" it typically rerenders and timestretch/pitches audio to a new framerate. that takes much longer and you should check if you want this or do the conversion in a dedicated DAW for better detail control...
    --> Is PP really doing an "audio conform" or just generating peak files?
