Matissage
Aamee and Photoshop CS6
Jun 13, 2013 9:13 AM
Tags: #cs6 #activation #aamee
Hi all,
Hope you will help me out with my installation issue.
Most of my users are working on a secure network without any internet connection. Then they wont be able to activate Photoshop CS6.
I just heard that AAMEE can solve my issue and generate a MSI package with all necessary activation information.
I installed and used AAMEE (3.1.108.0). My first impression was, too easy.
But at final the MSI is not working.
I tried from a command prompt with administrator rights (run as)
The installation starts but it failed at the end.
The progress bar goes back.
I tried on Windows 7 x64 and Windows Vista x32.
Any ideas ?
Thanks in advance
    Jun 13, 2013 9:56 AM   in reply to Matissage
    I ran into the same problem and was told it was because AAMEE packages files for distribution using SCCM and ARD. To get around this issue, we created a self-extracting zip file containing a batch file to start the installation. I am sure there was probably a better way to accomplish the task, but this is what worked for us based on system restrictions and server permissions.
    Batch file contains the following text: (Modify echo text as you see fit and include your msi filename in the msiexec line)
    echo "Press ENTER to begin installation."
    pause
    msiexec /i Build\YOUR_MSI_FILENAME_HERE.msi
    Exceptions\ExceptionDeployer.exe --workflow=install --mode=post
    echo "Press ENTER to exit installation."
    pause
  • Pierre Courtejoie
    Jan 11, 2006
    Jun 13, 2013 10:06 AM   in reply to Matissage
    Hi, Karim.
    You might want to change your user name to avoid getting spam.
