rms1908
Premiere Elements 11 won't open
Jun 14, 2013 2:50 AM
Installed Premiere Elements 11 but it won't open. Have uninstalled and reinstalled but still no luck.
    Jun 14, 2013 2:59 AM   in reply to rms1908
    What system? What errors/ warnings? What is happening (or not)? You need to explain better and provide more info.
    Mylenium
    Jun 14, 2013 2:42 PM   in reply to rms1908
    Moving this discussion to the Premiere Elements forum.
    RMS1908 I would recommend reviewing your Event Viewer when trying to open Premiere Elements.  Please see Identify software conflicts | System log | Windows Vista - http://helpx.adobe.com/x-productkb/global/identify-software-conflicts- system-log.html for more details.
    Jun 14, 2013 3:11 PM   in reply to rms1908
    One prime bit of info that I did not see in the list was the video card.
    What is the make/model of your video card/display adapter?
    What is the number and date of the installed video driver?
    An obsolete video driver is one of the primary causes for PrE not launching, so we probably need to get that out of the way early on.
    Jun 15, 2013 11:23 AM   in reply to rms1908
    First, thank you for that information.
    Now, you say:
    I ran the Update Driver and it said it is up to date. I installed it on another computer that is older and it works ok...still won;t open on mine
    I would first go to the Intel Web site, and manually check for a more recent update. 2011 is a very long time ago. I find that the OS's driver update utility, or any driver utility, will likely be very out of date. For most programs, that does not usually matter much, but PrE really needs to interface VERY critically with that video driver.
    If you have a Dell, Lenovo, HP, or other major mfgr's. computer, I would also check their Web site, as some of those companies will rewrap the video drivers for their specific version of the hardware and their specific version of the OS.
    As for PrE running on one computer, but not the other, I would look closely to see if those two computers have the exact same video card, and video driver. If they do, then I would check to see if they each have the exact same Windows updates and hot-fixes applied. Even simple OS updates CAN render the video driver obsolete. That is why the major video chip companies update their drivers so very often. Intel, while making good chips, has not been nearly as good with driver support, as nVidia, or AMD/ATI. As mentioned above, the video driver is not so important for general computing (Intel's target), but programs, such as PrE, extreme games, or 3D work, require much more from the video driver - other programs will usually still run pretty well, but not programs, like PrE.
    Good luck, and hope that Intel has a newer driver for you, that solves your issue.
    Jun 17, 2013 1:27 PM   in reply to rms1908
    Hi RMS1908
    As asked by Jeff, could you check your event viewer and let us know the fault module mentioned under Error for Premiere Elements.
    It will help us in providing suggestions.
    Jun 21, 2013 6:29 AM   in reply to rms1908
    According to Intels web site the latest drivers are 15.28.15.306 dated 21st March 2013. If you try those, create a System Restore point first - it is possible that Acer customise the generic drivers so a Restore point makes it easier to revert should you wish to do so.
    Cheers,
    Neale
    Insanity is hereditary, you get it from your children.
    Jun 21, 2013 10:33 AM   in reply to rms1908
    It runs on an older computer than this one ok.
    Does that older computer have the same exact video chip/card, and the same exact video driver, as the computer, on which the program will not run?
    Also, is the OS the exact same on both computers, and have the exact same updates and hot-fixes been applied to both?
    Good luck, and I hope that Neale's video driver will do the trick. Also, do check the Acer Web site, to see if they offer a re-wrapped, updated driver for the Intel Graphics chip.
