how to swap out an image in a .fla file
Jun 14, 2013 6:32 AM
Tags: #image #edit #replace #swap #.swf #.fla #adobe_flash
I have an existing .swf movie and I aquired the .fla files to make edits. I found the image I want to swap out but I am not sure how to do it. I was planning on using Flash Pro to make the edit. Any help would be greatly appreciated.
Thank you,
Ashley
  • kglad
    Jul 21, 2002
    Jun 14, 2013 6:41 AM   in reply to ashmic19
    if you want to replace all instances of the image, right click it in the library>click properties>click import>navigate to the replacement image>click ok.
  • kglad
    Jul 21, 2002
    Jun 14, 2013 12:12 PM   in reply to ashmic19
    when you right click and click properties, you should be looking at a bitmap panel.  are you?  if so, check the buttons on the right (update, import, test).
  • kglad
    Jul 21, 2002
    Jun 17, 2013 11:27 AM   in reply to ashmic19
    then you're not right clicking a bitmap.
    what do you mean by, image?
  • kglad
    Jul 21, 2002
    Jun 19, 2013 2:17 PM   in reply to ashmic19
    if you only want to change the bitmap in the one on-stage instance what you did is ok.  if you want to change them all, you should follow the same steps for that bitmap in your library panel (windows>library).
    you need to publish a new swf using the updated fla to see the changes in your swf.
