Please help me with a custom ease...
Jun 14, 2013 8:23 AM
Tags: #flash_cs6 #custom_ease
I have a line of text that I want to come in fast, slow down, then exit as quickly as it entered. When I create a custom ease and apply it to the X property in Basic Motion, it just goes back and forth! Also, could someone explain what the % in a custom ease relates to, e.g. if I add a point at frame 50 and set it to 50%, what is it doing? Thanks!
  • kglad
    Jul 21, 2002
    Jun 14, 2013 8:30 AM   in reply to Syrax12
    at the start of your tween span, move your object to the left of the stage, in the middle of your tween span, move your object to stage center and at the end of your tween span move your object off-stage to the right.  test.  is that doing what you want?
  • kglad
    Jul 21, 2002
    Jun 14, 2013 12:10 PM   in reply to Syrax12
    you said, "..it just goes back and forth".  that problem has been solved, correct?
    to see the effect of eases, use -100 and +100.
    also, you might want to try different (than simple slow) eases
