What class should I use for a Fluid Div Tage
Jun 14, 2013 11:22 AM
Tags: #dreamweaver #css #cs6 #fluid_grid
Hi!
Forgive me if this question has been asked.  When I want to insert a fluid Div (from the Insert panel), it asks which "class" to use.  (Attached image for clarity.)  So, I chose 'fluid.'  Is that correct?
Furthermore, when I do choose 'fluid', my CSS shows up like this: <div class="fluid fluid"> Is it supposed to repeat like that.
Thanks (and I can't wait for CC!)
Jon
    Jun 14, 2013 12:14 PM   in reply to jonfreed77
    It really depends on what you're planning to do with the inserted div.
    Ideally, everything should go inside the .gridContainer div.
    <div class="gridContainer clearfix">
         <div id="LayoutDiv1">  </div>
         <div id="LayoutDiv2">  </div>
         <div id="LayoutDiv3">  </div>
         <div id="LayoutDiv4">  </div>
    </div>
    It doesn't matter much what you call your Divs.  The pre-defined classes are there to help you if you choose to use them.
    Creative Cloud 12.2 Enhancement to Fluid Grid Layouts
    http://blogs.adobe.com/dreamweaver/2013/02/updated-fluid-grids-in-drea mweaver.html
    Nancy O.
    Jun 15, 2013 2:26 PM   in reply to jonfreed77
    FGL comes with several pre-defined and re-usable classes in the CSS file.
    Go to insert > Div.  Type "foo" into the class field.  DW generates the following code.
    <div class="fluid foo">
    This is the content for Layout Div Tag "foo"
    </div>
    Go to insert > Div again and look inside the drop list.  Now you'll see "foo" has been added to the list of class names.
    If you type "foofoo" in the div ID field, DW generates this code:
    <div id="foofoo" class="fluid">
    This is the content for Layout Div Tag "foofoo"
    </div>
    IDs are unique and can be used only one time per page.  But classes are re-usable as many times as you need one.
    I agree the documentation leaves a lot to be desired.  That may be changing after Monday when the new CC becomes available.
    Nancy O.
    Jun 15, 2013 8:23 PM   in reply to jonfreed77
    Hi Jon,
    I wouldn't rely on Adobe for responsive design - or much of anything in
    terms of client side stuff. They typically just grab free stuff off the
    Web - whatever is trendy - and turn it into a feature. CS6 uses
    Boilerplate and CC will be using the mote robustly bloated Bootstrap.
    The last time Adobe wrote something itself they gave the world Spry,
    which met an untimely end.
    Responsive design is extremely easy to master and the time it takes
    understanding a bloated framework would be much more productively spent
    learning how to do it yourself - with a fraction of the code.
    Dreamweaver is a first-class web authoring tool as long as you restrict
    your use to actual authoring
    Al Sparber - PVII
    http://www.projectseven.com
    The Finest Dreamweaver Menus | Galleries | Widgets
    Since 1998
    Jun 15, 2013 9:49 PM   in reply to jonfreed77
    If I were privy to a beta I would not be able to tell you. The details
    were discussed at MAX and in some Adobe videos.
    From what I see, the CSS version will be a valuable upgrade based on
    new CSS editing features and a claimed improvement in speed and stability.
    As for learning responsive design, the key is to study the basics and
    ignore the tutorials or articles that include any reference to a
    particular CSS framework.
    The key components are:
    Include a viewport meta tag. This tells a mobile device to render your
    page in its viewport full-size, without shrinking it.
    Write a simple media query with no more than 1 or 2 breakpoints.
    Do not use JavaScript detection. Responsive design is for all mobile
    devices and is to be considered a progressive enhancement for modern
    browsers that support media queries.
    We produce responsive tools and templates. Feel free to examine the code.
    Al Sparber - PVII
    Since 1998
    Jul 30, 2013 3:57 AM   in reply to Al Sparber
    I like your style, Al.
    Jul 30, 2013 5:10 AM   in reply to Al Sparber
    @Al Sparber:  +1000, I couldn't agree more.
