Marcozrin
Which presets sequences in premiere for a canon 5d mk3
Jun 14, 2013 1:39 PM
Tags: #premiere #importing
Hello,
I need a help to find which presets sequences I've to use to import in a Premiere cs6 my recorded files of a Canon 5D mk3.
Actually I use a HDV, is that right?
Regards
  • joe bloe premiere
    Dec 6, 2009
    Jun 14, 2013 1:46 PM   in reply to Marcozrin
    When you launch Premiere, you are presented with
    a menu of Sequence preset types to choose from.
    You can skip this step by hitting Cancel, import (or capture) your media,
    then do this:
    Or, right-click a media file and select 'New Sequence From Clip".
    How do I choose the right sequence settings?
    http://www.video2brain.com/en/lessons/how-do-i-choose-the-right-sequen ce-settings
    Jun 14, 2013 1:44 PM   in reply to Marcozrin
    Not HDV, there ought to be a "DSLR" folder. If you don't see a long list of options, you could have a faulty install that did not put everything in.
    Once you choose DSLR, there are sub-options to match the frame size and frame rate as well. The truth is, you do NOT have to use a "DSLR" preset necessarily, you could also use AVHCD or something else as long as the specs match.
    Also, on bottom right of Project Bin, there is a button for New Item - drag and drop a clip onto that icon to create a Sequence with the correct parameters to match your source footage.
    Jeff Pulera
    Safe Harbor Computers
    Jun 14, 2013 1:44 PM   in reply to SAFEHARBOR11
    Oh Joe, ya beat me again
    Jeff
  • joe bloe premiere
    Dec 6, 2009
    Jun 15, 2013 6:30 AM   in reply to Marcozrin
    Can I use AVCHD to import clip from 5D mk3 and also from GoPro 3 Black Edition?
    You do not use a Sequence preset from this menu to import media.
    Your initial choice of a Sequence preset from this menu
    will have no bearing or affect on the import of your media files.
    You can select anything (or nothing by hitting 'Cancel'), then import
    (or capture) your media, and create a properly configured Sequence
    that matches your media type by doing what is indicated in post #1.
    If your two different source types are not the same frame size
    and frame rate, you should create a Sequence using the media type
    that will constitute the majority of the material in the Timeline.
