Zjuka
Animated GIF export issue
Jun 14, 2013 4:19 PM
Tags: #windows #cs6 #gif #photoshop_cs6 #gif_export
Odd new issue surfaced today - frame animation plays fine when played from timeline but all layers are exported stacked on top of each other for the duration of the whole animation.
I'm able to see that because the layers have transparency.
About animation - 8 frames with in endless loop, imported into a timeline via 'Make Frames from Layers' command in a fly-out menu in the Timeliine window.
Tweens for animation are off, 01.sec delay for all frames
I was able to export animated GIF before, wondering if this issue is tied to the latest update.
Anyone else is experiencing this weird issue?
-thank you
Photoshop CS6 Extended
Windows 7x64 SP1
    Jun 14, 2013 11:46 PM   in reply to Zjuka
    Care to provide screenshots? How do you check the GIFs?
    Mylenium
    Jun 16, 2013 7:02 AM   in reply to Zjuka
    Well, you have disabled transparency dithering, have you not? GIF can only have one level of transparency. Everything else must be faked using colors or dithering.
    Mylenium
