Ginschung
Problem when I try to output a project.
Jun 14, 2013 3:40 PM
Tags: #error #adobe #premiere #elements #xp #11 #unknown #compiling #movie.
Hello Everyone,
I have a problem using Premiere Elements 11.
I have been working on the editing of my project for a long time, I have started working on it nearly six months ago !!!
This is a very important project to me.
I have two projects, 2 minutes each, that I have managed to output in .AVI.
But the project I'm having a problem with is a 40 minutes project.
All these three projects contain videos, sounds, musics, jpeg images and screencaptures, etc.
my problem is that when I try to output this 40 mins project, it's loading and then it stop to tell me "Error compiling movie. Unknown error".
I have tried every possible output extension, Avi, Mpeg, Quicktime, etc etc. It loads, then stops.
I am using Microsoft XP.
I remember that sometimes when I was working on the editing, when I was opening my project (.prel), a window appeared asking me when this file was, etc, so I have chosen the proper locations to find the files).
But the last coulple of times I was doing the editing, it kept asking me when one specific image was, and when I found the same named picture, it wasn't actually THE file needed. Because I think the file they were asking me to find was a picture that I had taken myself, and when you wanna transfer your pictures from your camera to your computer, they ask you to name it, so I named it photoperso.jpeg, etc and, I don't know maybe I have deleted a picture from my computer after putting it in my project. I am sorry, I may had typed too much, but this projects means a lot to me. I have travelled to film the different scenes, etc, and I don't really wanna lose all the editing I have done. That's why I thought I'd come and join You all to ask You if You could help me out a little bit.
THANKS VERY MUCH IN ADVANCE.
Best to All,
J
    Jun 14, 2013 3:44 PM   in reply to Ginschung
    Pictures that are "overly" large may cause video editing problems
    Photo Scaling for Video http://forums.adobe.com/thread/450798
    -PrEl Crash http://forums.adobe.com/thread/973935
    I'm not sure if this is for PrElements, but it may help
    Error Compiling Movie http://kb2.adobe.com/cps/906/cpsid_90670.html
    Jun 14, 2013 5:05 PM   in reply to Ginschung
    Ginschung
    Let us go through this systematically to see if we can get at the core of the issue. The answers should be in the details.
    Given that you are using Premiere Elements 11. You say that you are using "Microsoft XP". Is that Windows XP Professional SP3 32 bit or something else. Whether it be 32 or 64 bit, your Premiere Elements 11 is going to be a 32 bit application and as such has the limitations of 32 bit system that being maximum supported installed RAM = 4.0 GB of which typically 3.0 GB or less of that are available. That and your free hard drive space needs looking into since you say that a 2 min project works and a 40 min project does not. So, we need to assure an optimized computer with adequate available RAM and free hard drive space as well as Scratch Disks directed to a hard drive area with enough free space to accept as they are automatically generated by the program in one of its operations. Do you have pile up of preview files and conformed audio files in the Adobe Folder that needs deleting and/or a pile up of conformed video that can be cleaned out in Edit Menu/Preferences/Media.
    You cannot move or delete source media that went into the project after the project is saved closed. When you re-opened it, you will be hit with some nasty missing media messages. But those messages will be your avenue to reconnecting the missing. If you are not moving or deleting photos and you are storing them on an external hard drive and using them from there,
    a. make sure that the external hard drive letter is not changing
    and
    b. make sure that the external hard drive is formatted NTFS and not FAT32
    As for your message
    Expand the Timeline with the -+ slider over the Timeline to get a close look at the track content. First look for very thin vertical black lines that may be scattered on the tracks. They must be deleted if there. Look for irregularities in place of transitions, gaps, etc.
    Define the properties of what you have on the Timeline in terms of formats including file extension, duration, effects. This all may boil down to breaking apart the content in search of offending component(s). You mention that this 40 min Timeline consists of
    Those screencapture formats draw attention.
    What are the pixel dimensions of those photos and how many of them do you have? Another attention grabber.
    When I refer to formats, I am typically referring to video and audio compression, frame size, frame rate, aspect ratio, file extension, duration. Are you working from an NTSC or PAL setup?
    Please review the above.
    If you need clarification on anything that I have written, please do not hesitate to ask.
    Thanks.
    ATR
