sclouston
Help with Images Maps,
Jun 14, 2013 5:20 PM
I have an HTML page where an IMG is loaded:
<img src="images/renders/Main_Image.jpeg" alt="Main Image" name="Main_IMG" width="800" height="600" border="0" usemap="#Main_MAP" id="Main_IMG" />
Then I have 4 images maps laid on top of the image:
<map name="Main_MAP" id="Main_MAP">
  <area shape="poly" coords="--some numbers--" href="Area1.html" target="_parent" alt="Area1 Button" />
  <area shape="poly" coords="--some numbers--" href="Area2.html" target="_parent" alt="Area2 Button"  />
  <area shape="poly" coords="--some numbers--" href="Area3.html" target="_parent" alt="Area3 Button" />
  <area shape="poly" coords="--some numbers" href="Area4.html" target="_parent" alt="Area4 Button"/>
</map>
See Example:
Each area is essentially an invisible button. I want to make it so when the mouse hovers over the areas, I want the background image to display something different. On mouse out of the area, I want the image to go back. When the user clicks the Area, the user is moved to another part of the site.
etc.
I thought I could do this with Images Maps, but I can't figure out how. Is there an easier way? I have Dreamweaver CS4.
Thank you in advance!
    Jun 14, 2013 7:31 PM   in reply to sclouston
    Not possible with a single image and mapping.
    If you "slice" the image and place the slices in individual DIVs, then you can either add a javascript mouseover or use the slices as background images and add a CSS "hover" effect to change the background image on mouseover.
