how do you change bullets to check marks on a list
Jun 14, 2013 9:03 PM
Hello,  how do you use something other than bullets on a list.  If you use check marks instead...can you change the color of the check marks?
    Jun 14, 2013 9:37 PM   in reply to Hot Rod Raven
    I'm unaware of any CSS for checkmarks as it isn't a list style rule.  You'd have to make a checkmark image and use it:
    You can set a class for the list item:
    ul.checkmark li {
        background
    :url("../checkmark.gif") no-repeat 0 50%;
        padding
    -left: 20px;
    ul
    .checkmark {
        list
    -style-type: none;
    And then in the HTML:
    <ul class="checkmark">
    <li>List item goes here</li>
    </ul>
    or set it for the entire list:
    ul {
    list
    -style-image:url("/default_unchecked.png");
    /* other list styles*/
    And just create the list as normal.
    You'd need to "tweak" the CSS to place the image exactly where you want it.
    Jun 15, 2013 9:39 AM   in reply to Hot Rod Raven
    Or, you could use the CSS :before pseudo-class property with an escaped HTML entity code like this:
    .checkmark li {list-style:none}
    .checkmark li:before {content:"\2714  "}
         <li>list item</li>
         <li>list item</li>
         <li>list item</li>
    </ul>
    Nancy O.
