PE 11 Timecode error 1014
Jun 14, 2013 9:50 PM
Have PE11 installed on new computer
Followed instructions that came with PE11
Turned on camera        Panasonic NV-GS 180 DV
switched camera to playback mode
Inserted tape into camera
connected camera to desktop computer using USB port
Started PE11
open video editor
open New Project
click on -  add media
click on -  DV Camcorder (usb 2.0)
Debug Event box appears with   Premiere Elements has encountered an error    Srd/Timecode.cpp-1014
Click on  "continue"
get big white patches on screen  and egg timer   with nothing happening
right click on screen
option to   (a)close program  or  (b) wait for program to respond
choose (b) nothing happens
choose (a) "windows is checking"    message apears briefly before programme shuts down
Whats wrong ???
Ta Graham
    Jun 14, 2013 10:09 PM   in reply to 1958surferboy
    Being a miniDV tape camera (from what I can tell), what happens if you attach it to the computer via a FireWire 400 (IEEE-1394a/iLink) cable? Does PrE allow you to Capture from the tape in the camera?
    Jun 14, 2013 10:36 PM   in reply to 1958surferboy
    I have a box full of different cables but all cables look too similar and there seems to be a number of different firewire cables on the market
    You are correct. Each will have certain connections, and the one chosen will depend on the two connection types - the one on the computer (the iLink/FireWire-400/IEEE-1394a), and the one on the camera. Get those two connectors correct, and you have the cable that you need. I have a box of those too, plus USB, SCSI, Parallel, and Serial cables too - tons of them.
    In general terms, to Capture from miniDV tape to PrE, the FireWire is the standard. There is a rare instance, where one could Capture via a specialized USB cable, but that is not common - still, it did exist.
