smarino333
mpeg2-dvd render color stripe on right side
Jun 15, 2013 6:06 AM
Tags: #render #premiere_pro_cs6
When I render HD720p video to mpeg2-dvd (23.976) I end up with a thin color stripe on the right side of the output video.  The stripe usually appears wherever I have a crossfade between images/videos.  How can I solve this problem>
    Jun 15, 2013 7:39 AM   in reply to smarino333
    Very little info to go on.
    Anyway:
    Make sure you are on the last update of Premiere CS??
    Make sure you have the latest graphics card driver installed.
    Jun 15, 2013 7:46 AM   in reply to smarino333
    A test... export as (widescreen?) DV AVI and see if you still have the problem
    As a personal choice, so I don't have to figure out bit budgeting and transcode settings, I always export as DV AVI for Encore authoring (and I have Encore set to use automatic transcoding to make a "best fit" of video to my chosen single or dual layer DVD)
    IF exporting to DV AVI for Encore authoring works, use that
    Jun 15, 2013 8:03 AM   in reply to smarino333
    Does this issue appear in other projects with 720p to mpeg2-dvd or just this one.
    Is your source also 23,976
    Did you set scale to fill?
    Instead of using a crossfade try overlapping the clips and keyframe opacity.
    Jun 15, 2013 9:22 AM   in reply to smarino333
    If this the only project giving you this issue I think the project might be a bit corrupt.
    You can try and open this project into a new project.
    If you can add a cross dissolve you can overlap the video part. Its basicly the same.
    Use alt or unlink video from audio.
