The drop down sub menus display on the wrong side
Jun 15, 2013 7:55 AM
When selecting a sub menu from within a main drop down menu the arrow points to the right but the actual sub menu pops up on the left in most cases. I have only noticed this recently and wonder if I have inadvertently messed up a setting as in the past I cant recall this being so but I don't use the editor a lot so may be mistaken.
    Jun 15, 2013 2:24 PM   in reply to Scotty Hall
    Are you on a windows operating system?
    Jun 15, 2013 2:39 PM   in reply to Scotty Hall
    For windows you should be able to go to the Control Panel and set the side the menus display under Tablet PC Settings.
    Jun 17, 2013 2:41 PM   in reply to Scotty Hall
    What operating system are you using?
    What version of photoshop elements are you using?
    What is your screen resolution set at?
    Jun 18, 2013 2:54 AM   in reply to Scotty Hall
    See if the following works for you:
    Press the Windows Logo Key+R to bring up the Run dialog box. In the Open line, copy/paste the following text.
    shell:::{80F3F1D5-FECA-45F3-BC32-752C152E456E}
    Press OK.
    This will start the Tablet PC Settings configuration dialog (Even if you do not have a Tablet PC).
    Select the Other Tab.
    In the Handedness section, place a check mark in the Left Handed option.
    Click OK.
    This should place the menus on the right side.
    Jun 21, 2013 11:34 AM   in reply to Scotty Hall
    Glad it worked.
    I've had that happen after windows updates several times, so it's probably nothing you did.
