Mayaninn
How do I automatically populate a template with images?
Jun 17, 2013 10:30 AM
Tags: #template #batch #place #actions #automate #populate #multiple_images
Hello, everyone!
I have more than 2,000 QR codes that I need to insert into this template for printing. I am hoping that there is an automated way to do this so I don't need to resize and place each QR code image by hand.
Is there a batch command or action of some kind that can perform this task for me?
Thanks so much for your help in advance!
    Jun 17, 2013 12:39 PM   in reply to Mayaninn
    Is it obligatory to do that task in Illustrator?
    If not, you may want to look at the Data Merge capabilities in InDesign.
    Jun 17, 2013 3:18 PM   in reply to Mayaninn
    There's also a script in the sample folder in ID called ImageCatalog.jsx which could be used for what you want.
    Jun 17, 2013 3:51 PM   in reply to Mayaninn
    I would definitely agree with the suggestions of using InDesign for this, it'll be a lot easier.  I would guess the hardest part is going to be the file names for each QR code.  Do you have them cataloged by chance?
    Do you have Excel handy?  Create a new book and for the header put something along the lines of @QRCode (The @ symbol is used to indicate a graphic placement).  Then list all the QR codes in that column, save it as a CSV file.  In InDesign create a Rectange Frame the size you need (on the toolbar the rectangle with the X through it.  Open Data Merge (Window, Utilities, Data Merge).  Select the Source Data in the main window it will show the available merge.  The QRCode should show up with a little Mountain Icon indicating an image placement.  Click the rectangle you drew then click on the data field you created.  It should show up with << >> marks before and after it.  Then just click the Preview check to view them.
