1120 Error
Jun 17, 2013 11:57 AM
Tags: #help #error #new #interactive #question #map #bindable #1120 #openscales
Very new to Flash builder. im trying to do a project for school making an interactive map.
I found the Openscales project which im trying to use to give my map interactivity.
Ive been following the tutorial given on the project website
( http://openscales.org/documentation/tutorials/current/tutorial-api-2.h tml )
Before I try to import my own map image im trying to make this map from the tutorial work then im assuming it will be fairly easy to plug in my graphics. but...
Ive run into an Error which I cant seem to fix. Ive googled and read of similar problems with this error but their problems werent exactly the same so i still couldnt really figure out whats causing it for me.
I get the Error "1120:Access of undefined property fxmap."
This is the code which i followed from the tutorial:
                                 xmlns:mx="library://ns.adobe.com/flex/mx"
                                 minWidth="955"
                                 minHeight="600"
                                 xmlns:os="http://openscales.org"
                                 creationComplete="initMap();">
  <fx:Declarations>
  </fx:Declarations>
          <os:Map id="fxMap"
                              width="500"
                              height="600"
                              zoom="11"
                              center="4.78783,45.68800"
                              x="60"
                              y="50">
  <os:Mapnik name="Mapnik"/>
  <os:MousePosition
                              x="10"
                              y="{fxmap.height-20}"
                              displayProjection="EPSG:4326"/>
  <os:DragHandler/>
  <os:ClickHandler/>
  <os:WheelHandler/>
  </os:Map>
  <os:PanZoom
                              map="{map}"
                              x="{fxmap.x+10}"
                              y="{fxmap.y+10}"/>
  <fx:Script>
                    <![CDATA[
                              import org.openscales.core.Map;
                              import org.openscales.core.feature.CustomMarker;
                              import org.openscales.core.feature.PointFeature;
                              import org.openscales.core.layer.FeatureLayer;
                              import org.openscales.core.style.Style;
                              import org.openscales.geometry.Point;
                              import org.openscales.proj4as.ProjProjection;
                              [Bindable] private var map:Map = null;
                              private function initMap():void{
                                        map = fxmap.map;
  </fx:Script>
  </os:Map>
</s:Application>
The Error is on the Line 45:
  map = fxmap.map;
Any help is greatly appreciated. Im on a pretty short deadline to figure all of this out.
    Jun 17, 2013 9:13 PM   in reply to Jynglez888
    Property names are case-sensitive.  You named your Map fxMap but reference it as fxmap in initMap()
