tanky321
Real time frequency analysis of 4 Mono inputs?
Jun 17, 2013 1:48 PM
Im trying to evaluate Audition for a particular project in which I am acquiring ultrasonic signals. I am using 4 ultrasonic microphones and a Roland Octa-Capture as my USB capture device. It is very important that I am able to see some type of frequency analysis in real time, since I cant hear the signal. The only current way I have been able to do a real time frequency analysis is to set each track as a monitor input, but the problem is that my frequency analysis is a composite of all 4 channels, which isnt really helpful. Is it possible to create a real-time frequency analysis of these 4 signals?
Thanks!
  • SteveG(AudioMasters)
    Oct 26, 2006
    Jun 18, 2013 1:37 PM   in reply to tanky321
    Sorry - haven't had a chance to look yet. I have a sneaky feeling that this may work better in CC than CS6, but I'd have to confirm that. I think that what should happen (if I've got it right) is that you should get four overlays on the same background - but if you want it to run in real time, you'll have to use a relatively small FFT anyway, so the resolution won't be that wonderful.
    Jun 18, 2013 2:42 PM   in reply to SteveG(AudioMasters)
    But since it is for checking ultrasonic frequencies a small FFT shouldn't be a problem should it?
    Oct 26, 2006
    Jun 18, 2013 3:17 PM   in reply to ryclark
    I think it might be... smaller numbers, lower resolution; it's the number of slices you take of the entire spectrum.
    Jun 19, 2013 8:31 AM   in reply to tanky321
    But you will see the waveform appear on the tracks as you record if audio is there. As well, of course, as the track meters wiggling about.
    Oct 26, 2006
    Jun 19, 2013 12:15 PM   in reply to tanky321
    I'm going to do a little experiment later - there may be another way around this..
