First export test in CC, Very Slow
Nov 12, 2013 1:42 PM
So, I made a test with a 1:30 min. sequence.
In CS6 the export time is 00:03:52
In CC: 27:43!!!!!
Exactly the same sequence, same export settings, both via Media Encoder CS6 & CC respectly.
What could be the problem?
Title was changed to be more clear. Rendering and exporting are not the same thing. Message was edited by: Kevin Monahan
Replies 1 2 Previous Next
    Jun 18, 2013 1:20 AM   in reply to Jorge Jaramillo Hdz
    That is not correct.
    Make a new project and try again.
    Jun 18, 2013 2:01 AM   in reply to Jorge Jaramillo Hdz
    AME carries a huge overhead, slowing things down very much. That is the reason we changed our benchmark to only use Direct Export. AME was already crippled in CS6 and still is in CC.
    Jun 18, 2013 2:20 AM   in reply to Jorge Jaramillo Hdz
    Let me give you an example of how AME deteriorated in performance in time.
    With CS5.03 the MPEG2-DVD test in our benchmark using AME on my old system took 25 seconds. That system now ranks # 49 in the benchmark and is a lowly i7-920 with 24 GB and a GTX 480, overclocked to 3.7 GHz.
    With CS6.03 the same test on my new system using AME takes 44 seconds. That is the system that ranks #1, an i7-3930K with 64 GB and a GTX 680, overclocked to 4.7 GHz. If anything, it should have been much better, not worse by 76%.
    I have not seen a noticeable improvement in CC yet.
    So, clearly, AME has serious performance problems since CS5 and Adobe is aware of that. It is the internal caching algorithms that cause this behaviour. Unfortunately, the bug has been deferred to somewhere in the future.
    Jun 18, 2013 4:05 PM   in reply to Jorge Jaramillo Hdz
    So...the new AME CC is basically going to make using PP useless for me if I cannot edit while I exportin the background with AME. I just tried to export a 3 min 1920x1080 Canon DSLR footage sequence with AME and it wanted 1 hour to export. I did a direct export through PP and it only took 6 min. I am going to go back and open the project in CS6 and see what I get. I too never had problems with AME CS6, nothing ever seemed crazy long....this is AWFUL!
    Jun 18, 2013 4:53 PM   in reply to Dmart Films
    I'm also seeing up to 100% longer render times in AME CC versus AME CS6.
    Jun 18, 2013 5:14 PM   in reply to Jorge Jaramillo Hdz
    Just did same!
    Jun 18, 2013 6:28 PM   in reply to Jorge Jaramillo Hdz
    That's a shame...
    i use AME a lot as i need to batch render differents projects in different formats.
    I have always had great results with my configuration in CS5.5, those poor AME performances are one reason keeping me away from upgrading to CS6 or CC.
    How come this keep getting worse?? What's the point of AME then?
    Jun 18, 2013 8:02 PM   in reply to Jorge Jaramillo Hdz
    this won't be good. It already takes longer than realtime to export my videos
    why did I leave apple again?
    Can companies please stop "fixing" things that aren't broken and making software for teenagers
    Jun 18, 2013 8:07 PM   in reply to Jorge Jaramillo Hdz
    I ran a short test of the MPEG2 sequence from PPBM5.5 and got a 3:45 export from CS6 and a 4:31 export from CC, identical settings, going through AME.
    I haven't tried a Direct Export yet.
    Jun 19, 2013 9:07 AM   in reply to Harm Millaard
    I ran some more tests.  Here's what I have so far:
    Windows 8 Pro 64 bit
    i7 2500
    8GB DDR3 1333 RAM
    1TB HD (single drive)
    GTX 560 Ti 2GB, 320.18 driver
    CUDA acceleration turned on in both versions
    I imported a 4 minute AVCHD clip with a lot of action.  I created a sequence based on that clip.  I exported that clip with no edits or effects to BD and DVD settings identical in both versions.
    Using AME for Export:
    CC7_BD = 5:58
    CS6_BD = 5:43  <---Winer CS6
    CC7_DVD = 3:07  <---Winner CC7
    CS6_DVD = 3:12
    Using Direct Export
    CC7_BD = 5:49
    CS6_BD = 5:40  <---Winner CS6
    CC7_DVD = 1:39  <---Winner CC7
    CS6_DVD = 2:55
    So, it looks like MPEG2 is faster with CC7 and H.264 is faster using CS6.  The biggest difference is for DVD using CC7.  Look at the times for AME and Direct, nearly cut in half!
    Now it should be noted that a brand new project was started in each version.  I've seen reports of older projects opened in CC7 behaving slowly, so I wanted to take that into account.  And in fact my first test was done opening an older project, Harm's 5.5 benchmark project, in fact.  So far, it's looking like where the project was created makes a difference.  Of course, Harm's project was full of effects, and this round of tests used none at all.  That's the next step, repeating these tests with effects, both accelerated and not.
    Jun 23, 2013 7:13 AM   in reply to Harm Millaard
    I did a quick test with AME vs Pr exporting with CC this morning.  Harm's right on the money.  It took 15 minutes for an export with AME, and less than 8 minutes with Pr.  Same project, same footage, same export settings, same everything.
    That's just... silly.
    Jun 23, 2013 7:40 AM   in reply to Jason Van Patten
    That's not just "silly" but totally unacceptable!
    What's going on ?
    In my case, not beeing able to use AME efficiently is just a deal breaker...
    Just to illustrate my case:
    I run a Yoga lesson-videos streaming site. We upload 3 videos a week, about 30min to 90 min each, currently streamin 170 videos and counting.
    For every single videos i edit, i batch export in 4 different optimized formats: 1 master for us, 1 for vimeo, 1 for brightcove  and 1 teaser for Youtube
    So any single project ends up in AME CS 5.5 in 4 different outputs. Of course, i usually render multiple projects in a row, making it a dozen tasks in line.
    (Thanks to Harm Millard advices when i rebuild my editing station 2 years ago, everything is just working so smoothly it is outrageous )
    In the mean time,  i can just keep doing something else, like a shooting or going for dinner, or well you know...
    Now, imagine me doing direct render in Premiere, waiting for one task to end to manually start another one...just plain impossible.
    Jun 23, 2013 9:34 AM   in reply to Jason Van Patten
    What were those export settings?
    Jun 23, 2013 11:18 AM   in reply to Jim Simon
    It shouldn't matter, Jim.  But compressing down from 1080p to 720p and converting AVCHD to MP4.  Same frame rate (29.97), 1 pass VBR, and 5Mbps bitrate.
    I've never been able to use AME with PrP CS6 because I can't edit my AVCHD with it.  All I know is that AME 5.5 is considerably faster than AME CC with the same footage.  It's a 20 minute video, and 5.5 can do the deed in half real time. (10 minutes or so).
    Jun 23, 2013 11:29 AM   in reply to Jason Van Patten
    I ask because in my tests, the H.264 Blu-ray settings showed AME and Direct export times within seconds of each other.  (Post 15)  The Direct was barely faster, not enough to cause concern with using AME.  It was a very different story with MPEG2, which showed a significant decrease in export time going Direct.
    Also, was that project created in CC, as that does seem to make a difference?
    Jun 23, 2013 12:05 PM   in reply to Jim Simon
    Yes, it was created in CC.
    Jun 23, 2013 12:20 PM   in reply to Jason Van Patten
    Thanks.
    Any effects?  (My test had none.)  Were any of them accelerated?
    Jun 23, 2013 12:26 PM   in reply to Jim Simon
    Jim Simon wrote:
    Thanks.
    Crop and Horizontal Flip, both of which are accelerated.
    Jun 23, 2013 3:43 PM   in reply to Jason Van Patten
    Thanks.  Testing now.
    Jun 23, 2013 4:11 PM   in reply to Jason Van Patten
    Ran another test and I'm seeing the same as you.  AME was 16:33 and Direct was 9:14.
    I wonder if my earlier test using a 4 minute clip just wasn't long enough for significant differences to manifest.
    Jun 24, 2013 7:03 AM   in reply to Jorge Jaramillo Hdz
    So I don't have a direct to test this and I'm not sure if it helps but;
    Intel Core i7 2600K water cooled and clocked at 4Ghz
    32GB 1866 DDR3 RAM
    SSD - Samsung 840 256gb - WIndows and Adobe install
    10,000RPM drive - effects files and scratch/cach
    7200RPM 2TB WD red - Raw files storage
    Nvidia GTX680
    I have a premiere cs6 upgraded to cc (by opening the file in cc) that has a 24minute timeline at 4K using all R3D files that has some AE dynamic link mixed it, some AE edited r3d files, and some text plates.
    I exported the project in 4k with 5.1 audio (it was a 5.1 project) using h.264 and queued it in AME CC... Well this export with nothing else open or running on the above PC took 20hours over the weekend. I did it last week in Premiere CS6 exporting to AMECS6 and it took about 10hours. That's at least double the time but these export times are guestimates as I wasn't doing this to post here lol.
    Jun 24, 2013 12:24 PM   in reply to Jorge Jaramillo Hdz
    Yeah this is insane. I updated to CC on day one and now am seriously regretting it. I cut a weekly 30min television show on my work station. A lot of different clips, titles and graphics, a mix of HDV and DSLR footage, all 1080 at 29.97fps.
    The HDV footage is dynamically linked to AE and keyed out with a simple solid BG behind it. So obviously that is a bit of a chore for any system to render it. But in CS6, using AME I could render out the final show in about 2.5 to 3 hours.
    But since I upgraded a couple unfinished shows from CS6 to a CC project I'm getting render times of 14+ hours.
    That simply can't be right. I've tried making previews of select areas and it's the same insane ammount of time.
    Why is there no one from Adboe responding to this forum?
    Jun 24, 2013 1:21 PM   in reply to jwilliamsrfcu
    No offense but why on earth are you using untested software for such important work?
    Jun 24, 2013 1:35 PM   in reply to tclark513
    cool man, thanks for being so helpful
    Jun 24, 2013 2:40 PM   in reply to Jorge Jaramillo Hdz
    It looks like I may have solved my problem, though I'm not sure if it will be any help to the rest of you. I noticed that the render times were only getting seriously clogged because of the AE comps I had dynamically linked into my timeline. These were clips that I had keyed out in AE using a third party plugin. When I went back into AE and used a different effect to get my green screen key (this time I used the buil in Keylight effect) everything seemed back to normal. By which I mean a few hours to render instead of 20.
    So maybe check any effects you are using, if they are the CS6 version they may not work to well with CC
    Jun 24, 2013 2:47 PM   in reply to jwilliamsrfcu
    Glad you found a solution.  On this end, I don't use/own AE, so that's not what's causing any of my slow-downs.
    Jun 24, 2013 3:47 PM   in reply to Jorge Jaramillo Hdz
    Well I guess that didn't totally fix the issue. It still takes quite a bit longer, actually way longer, than CS6 would take to render it.
    Jun 24, 2013 5:16 PM   in reply to tclark513
    Actually, i think you've just nailed it (without knowing it?)
    CC is, by design, a constantly evolving software suite.
    Adobe already proved they are willing to add or scratch features any time, without any real notice from now on.
    So there we have a  software suite in a constant "untested" state, which may be working now but become buggy with the add or removal of something in coming months...
    Since this looks a bit like gambling to me, I would propose a new definition for Adobe CC :
    For a monthly bet of 30-50 USD, you can now join  the  Adobe Casino Cloud
    Jun 24, 2013 6:31 PM   in reply to Rishaar
    Hopefully it won't turn into another "Mac CS6 'Serious Error' thread" for PPro which was NEVER resolved by Adobe! It caused quite a bit of problems for a lot of people, including me
    Jun 24, 2013 6:35 PM   in reply to Kurrykid
    It actually was solved by new video card drivers.  It took a while for them to release them but it did fix it.
    Jun 24, 2013 6:39 PM   in reply to tclark513
    Hmmm...I followed that thread for a long time and don't remember a posted fix but with 14 pages of threads, I may have missed it
    Sorry for getting Off Topic...please resume!
    Jun 24, 2013 6:57 PM   in reply to Rishaar
    That's great!
    I would never use new software for anything important until I tested it on my own.  I've read posts from people actually stating that they updated in the middle of a project and having clients in to see their progress the same day.  That is business suicide!
1 2 Previous Next
Actions
