Can Flash Pro CC publish to flash player 9??
Jun 18, 2013 5:20 AM
Hi
It is possible to publish to flash player 9 in Flash CC. Most of the flash ads still require flash player 9 as the highest version to publish for.
thanks
Andrew
  • kglad
    Jul 21, 2002
    Jul 16, 2013 12:17 PM   in reply to andykenward
    10.3 is as far back as you can publish unless you add an older playerglobal swc to the publishing options.
  • kglad
    Jul 21, 2002
    Jun 18, 2013 6:45 AM   in reply to andykenward
    to start, you need to find a version 9 playerglobal.swc.
  • kglad
    Jul 21, 2002
    Jul 16, 2013 12:19 PM   in reply to andykenward
    add the swc to the default location, Adobe\Adobe Flash CC\Common\Configuration\ActionScript 3.0\FP9\playerglobal.swc
    then you need to add an fp9 publishing template.
  • kglad
    Jul 21, 2002
    Jun 18, 2013 8:14 AM   in reply to andykenward
    you need a publishing template (xml) for fp9 so it shows up in your publish settings target combobox.
    here's some info: http://blogs.adobe.com/rgalvan/2011/11/adding-fp11-support-to-flash-pr o-cs5-and-cs5-5.html
    Jul 8, 2013 3:11 PM   in reply to kglad
    Sorry but why is this not built in? Crappy Flash CC... does Adobe know that major Ad-Servers do not accept SWFs higher than Flashplayer 9? Therefore Flash CC, as it is right now, is useless.
    Jul 9, 2013 2:48 AM   in reply to FUNE78
    That is so true ...
    Jul 15, 2013 9:49 AM   in reply to sjess-novagraphix
    Hey just went through the stressful experience of building some banners in CC only to realize they couldn't be exported as Flashplayer 9.  I tried then opening them in CS6 but they wouldn't load properly and when published their SWF would be extremely choppy.  Seeing as the client needed the animation quickly I tried everything and found a solution.  Figured I would share it here in case any one else finds them self in my shoes.
    First I would save my files in Flash CC as an .xfl file.  Then in CS6 open the .fla file that was created with the .xfl folder and with out touching anything go to File>Publish Settings and switch the target to Flash Player 9 hit 'OK' then hit CTRL-F12
    And success I finally saw my animation playing back without being choppy.  I guess for the time being I will have to stick with CS6 for web banners.  It's a shame since CC performs so well and helps keep file size down a bit...  I would love to add a Flash Player 9 option to CC if possible.
  • kglad
    Jul 21, 2002
    Jul 15, 2013 10:36 AM   in reply to Will at RR
    Jul 15, 2013 5:16 PM   in reply to kglad
    @kglad i tried that way, flash cc does not work with a fp9 publishing template. Problems with exporting as3 to fp9. So instead of keep fooling us in the wrong direction bring up a complete solution, right you can't...
    Flash's main profit scheme is online-marketing, also the only reason why flash still exists (everything else is already replaced). looks like adobe is dumb enough to pull the plug here. Nobody intelligent enough does Websites, Games, Video-Embeding and so on with Flash anymore.
    kglad if you want to do a good job for Flash, i mean it honest, then contact someone at adobe to really get the focus on the flash cc publish to fp9 issue. OK?
  • kglad
    Jul 21, 2002
    Jul 16, 2013 9:56 AM   in reply to FUNE78
    i just added fp 9 to flash cc and tested and i don't see a problem.
    Jul 16, 2013 10:17 AM   in reply to kglad
    Well thats the problem... you don't see it, because you most likely did not a full test. Ad some AS3-code to it and it will fail when you publish it. Looks like alot of Flash CC AS3-Code does not work in FP9. If not, it would be very awesome if you could share your solution here. And correct me if am wrong.
  • kglad
    Jul 21, 2002
    Jul 16, 2013 12:20 PM   in reply to FUNE78
    you're wrong.
    i see no problem with actionscript unless i try to use something not available in fp 9 (like the native JSON class that was added with fp 11) which confirms i'm using fp 9 to publish.  so yes, there's alot of code that would work in fp11 that would not work with fp 9.  if you expect anything else, you have some fundamental misunderstanding.
    anyway, the solution is the same as i already mentioned, more than once.  here are the file paths on my computer (which are the default paths):
    C:\Program Files\Adobe\Adobe Flash CC\Common\Configuration\Players\FlashPlayer9_0.xml
    C:\Program Files\Adobe\Adobe Flash CC\Common\Configuration\ActionScript 3.0\FP9\playerglobal.swc
    and i attached two files so you don't have to find fp9 playerglobal.swf and you don't need to create a fp 9 xml.
    Jul 16, 2013 12:41 PM   in reply to kglad
    Thank you kglad for this solution... Looks like my playerglobal.swc was different to yours. So now we only have to bring adobe to the point that they implement it...
  • kglad
    Jul 21, 2002
    Jul 16, 2013 12:51 PM   in reply to FUNE78
    you're welcome.
    Jul 17, 2013 7:40 AM   in reply to kglad
    Thanks kglad!! and thanks for attaching the files.  I agree with FUNE Adobe should definitely update CC to have the option of flash player 9.  Since it is the DFA standard at the moment.
  • kglad
    Jul 21, 2002
    Jul 17, 2013 1:44 PM   in reply to Will at RR
    you're welcome.
    Sep 4, 2013 5:11 AM   in reply to kglad
    Thanks kglad,
    For Mac the file paths are:
    /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Common/Configuration/Players/FlashPlayer9_0.xml
    and
    /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Common/Configuration/ActionScript 3.0/FP9/playerglobal.swc
    To navigate inside "Adobe Flash CC.app" in Finder, you need to right click it and select "Show Package Content".
  • kglad
    Jul 21, 2002
    Sep 4, 2013 6:42 AM   in reply to Jarkko Syrjälä
    you're welcome.
    and thank you for the mac paths.
    Sep 25, 2013 11:45 AM   in reply to kglad
    Thanks for this.
    For others with Macs, the swc file given here did not work for me, I used this one which solved my issues: https://code.google.com/p/flashdevelop/source/browse/trunk/FD3/FlashDe velop/Bin/Debug/Library/AS3/intrinsic/libs/player/9/playerglobal.swc?r =1097
    Oct 3, 2013 9:40 AM   in reply to kglad
    kglad, You sir are freaking AWESOME!!!!  You just saved me about 3 days of rebuilding 40 banner ads!  I am VERY glad you figured this out and shared it for everyone to know!  You sir are a knight in shining armor!!
  • kglad
    Jul 21, 2002
    Oct 5, 2013 8:22 AM   in reply to Submortal69
    you're welcome!
    Oct 10, 2013 7:43 AM   in reply to kglad
    Just like to add how helpful this advice has been - saved a complete rebuild in CS6 of several very high profile banners. Thanks.
  • kglad
    Jul 21, 2002
    Oct 10, 2013 9:44 AM   in reply to 3x3 Photo
    great.  you're welcome, too.
    Dec 4, 2013 3:36 PM   in reply to kglad
    kglad you just saved my bacon. a HUGE thanks for the info, much appreciated (i was beginning to panic a little bit then saw your post and all is good now!)
    Dec 5, 2013 2:57 PM   in reply to emmeh_d
    To anyone on OS X that doesn't want to modify the Adobe Flash CC.app (because you shouldn't), you can drop the files into locations similar to those mentioned by Jarkko (#5652006) in your Library folder:
    ~/Library/Application Support/Adobe/Flash CC/en_US/Configuration/ActionScript 3.0/FP9/playerglobal.swc
    ~/Library/Application Support/Adobe/Flash CC/en_US/Configuration/Players/FlashPlayer9_0.xml
    You locale might be different (mine being "en_US"), and you'll probably have to create the FP9 and Players folders. I used the SWC from Antoine above and everything worked like a charm (#5713272).
  • kglad
    Jul 21, 2002
    Dec 5, 2013 3:21 PM   in reply to emmeh_d
    you're welcome.
    Jan 9, 2014 5:22 AM   in reply to kglad
    Thanks for saving my ***! Banners are on their way to the client
    Jan 13, 2014 1:52 AM   in reply to kglad
    Hey guys,
    do you know what's wrong with mine?
    I did everything as kglad, Jarkko and Actionscripted instructed, but I end up with somehow corrupted file which is not working properly.
    Anyone know what could I do differently?
    Jan 13, 2014 8:24 AM   in reply to AnnemariEerola
    Jan 14, 2014 5:58 AM   in reply to Antoine Bonnin
    I'm on Mac too and I tried also that file - didn't make any difference.
    Jan 14, 2014 6:18 AM   in reply to AnnemariEerola
    Annemari, Have you double checked that the swc file is in correct folder? The message is your screenshot says that playerglobal.swc file was not found.
    Maybe you could try adding the swc file to both
    and/or
    (The Tilde (~) in the beginning of the path means your home directory which is usually Machintosh HD > Users > yourUserName)
    Jan 14, 2014 6:34 AM   in reply to Jarkko Syrjälä
    Oh, awesome! Seems like that was the problem. Working now, thanks!
    Jan 24, 2014 1:35 PM   in reply to Jarkko Syrjälä
    Sorry to harp on the same problem. Just upgraded to CC and finding this problem also. I've read thru everything and I am having the error too. It seems like I need to put the file into this path
    But the problem is, I don't have this path!! Even when I view all of my hidden folders. I get to Adobe Flash CC.app and its not there.
    The error I'm getting in Flash is
    Warning: 5004: The file '/Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Common/Configuration/ActionScript 3.0/FP9/playerglobal.swc', which is required for typechecking ActionScript 3.0, could not be found. You may need to reinstall Flash.
    Do I really need to reinstall??
    Jan 24, 2014 1:58 PM   in reply to jt8348
    Nevermind, I figured it out. "Show package contents" !
    I'm good....thank you to everyone who contributes and helps out the rest of us!
    Jan 24, 2014 4:51 PM   in reply to andykenward
    no you cant
