Ability to add ActionScript 2.0 support in Flash CC
Jun 18, 2013 7:39 AM
Is there someway we can copy over files from Flash CS6 into Flash CC to enable ActionScript 2.0 support again or has it been removed from the programs code?
    Jun 18, 2013 7:45 AM   in reply to KenneyNL
    Totally removed as2 support in CC. It will open a fla with as2 but remove the code.
  • kglad
    Jul 21, 2002
    Jun 18, 2013 8:06 AM   in reply to KenneyNL
    it might not be possible and, if it is, it would require adding a playerglobal.swc that supports as2 to your library path and adding an as2 compatibile template.
    Jun 18, 2013 9:33 AM   in reply to KenneyNL
    I'm sorry Kenney.  Adobe announced a lot of months ago they would drop support for AS2.
    Jun 18, 2013 6:51 PM   in reply to KenneyNL
    You can try yourself by creating a new Flash Player configuration file that uses an asversion target of "2"
    On Mac OS X you'll find the player configuration file at Adobe Flash CC/Adobe Flash CC.app/Contents/Common/Configuration/Players
    Copy one of the FlashPlayer xml profiles there and change it to target asversion="2". You will also need to point to the proper playerglobal.swc as well for the version of Flash Player you are using.
    A set of complete instructions on how to add in other versions of Flash Player targetting in Flash Professional can be found at
    http://forums.adobe.com/message/3724540
    Good luck, and let us know if it works.
    Aug 7, 2013 6:43 AM   in reply to KenneyNL
    You can still download Flash Pro CS6 from https://creative.adobe.com/products/flash and get your AS2 support back.  Go to the dropdown under "In This Version" and select Adobe Flash CS6 to download instead of the CC version. We have multiple FLA files made with AS2 and don't have the time to recode them all.  I went back to CS6 to do periodic minor updates on those old files.
    Oct 23, 2013 12:43 PM   in reply to KenneyNL
    This is a pretty huge problem for me. I work with some big brands that have a looooot of legacy flash files. Going back to CS6 for sure. Can't imagine it's really necessary to remove support for this considering there's still so much of it floating around, and it's only one version back.
    Oct 28, 2013 2:25 PM   in reply to kang0372
    I needed an AS2 solution and only having a Cloud Subscription and no previous version of the Creative Suite this saved my bacon today. You're a champ! This information needs to be pinned on the forums for easy access.
    Nov 12, 2013 3:17 AM   in reply to KenneyNL
    It looks like they removed the link or am I missing something?
    Nov 12, 2013 3:20 AM   in reply to Dazzie
    Never mind, you need to be logged in for the dropdown to show up on the link which Kang0372 gave.
    Nov 14, 2013 4:37 AM   in reply to Dazzie
    Why did they remove this!? A lot of people (like myself) still use AS2 for simple quick coding stuff.
    They should put it back in, since they can now with the cloud and updates.
    Jan 24, 2014 2:44 AM   in reply to KenneyNL
    agree, adobe made a lot of mistakes these years against developers
    so if they want to keep generations of actionscript developers they must
    continue to support as2 because it concerns hundred of thousands companies and developers
