Installing Nik Software in Photoshop CC.
Jun 18, 2013 11:07 AM
Tags: #adobe #install #cloud #nik_software #photoshop_cc
How do I install Nik software into Photoshop CC when the host box remains empty. You have the option of a custom host but what do I choose? Would really appreciate some help. Thanks.
    Jun 18, 2013 11:16 AM   in reply to Daznic
    Run the nik installation programme, it will not detect Photoshop CC so you have to add it to the progs nik software will install in. Press the +button and add the path to the plug in folder in the Photoshop programme directory.
    Jun 18, 2013 2:45 PM   in reply to Dave Rosser
    Already tried Dave Rosser's suggestion, it does not work. The Nik files do get loaded into the plug-ins directory but CC does not recognize them.
    Jun 18, 2013 3:17 PM   in reply to Roy Berger
    Thought I would share this from another forum (worked for me):
    spedruco  says:
    Thought I'd pass on, but I got NIK to work on Photoshop CC by copying the folder Google from the Photoshop CS6 plugin folder and pasting it into the Photoshop CC plugin folder on a Windows machine at least.
    Jun 18, 2013 3:18 PM   in reply to Roy Berger
    Copied the Google folder (containing the NIK plugins) from the PS CS6 plugin folder to the PS CC plugin folder. PS CC recognizes all (Windows 7 64 bit).
    Graham
    Jun 18, 2013 3:31 PM   in reply to Graham in NC
    I am running Windows 8 64 bit. I also tried copying the folder from CS6 (where they work fine with Win 8) to CC but the filters do not show up in the PS CC filters list.
    Jun 18, 2013 3:36 PM   in reply to Roy Berger
    For the record, I am running Win8 64-bit as well.
    Jun 18, 2013 4:29 PM   in reply to visualtotems
    Got it!!! I did not realize that it was necessary to copy the Google plug-ing files from both the 32 bit and the 64 bit version of CS6 to both the 32 and 64 bit version of CC. I had been trying to get the plug ins to work but had just been copy the file from 64 bit version to 64 bit version. Works great now!!! I am a happy camper. Thanks to all who responded.
    Jul 5, 2013 6:58 PM   in reply to Daznic
    I've just checked it on Mac OS X (10.8.4). Works without any problems.
    Sep 22, 2013 7:18 PM   in reply to Dave Rosser
    I did just what you said but the Nik filters are not showing up in Photoshop CC. When I go to Program Files>Adobe>Photoshop CC>Plugins>Google, everything is there, just not showing up.
    Sep 22, 2013 7:18 PM   in reply to Roy Berger
    I don't have both 32 and 64 bit of either one on my computer.
    Sep 27, 2013 3:31 PM   in reply to patski107
    same here, I only had 64bit CS5 on my machine.   So far no NIK stuff showing
    in filters........  ;-(
    Oct 2, 2013 5:59 PM   in reply to Daznic
    I use an up-to-date iMac and I had similar problems.  However, I found the trick that appears to work.  Google's instructions are incomplete - at least for Macs.  You need to direct the installation to go one extra step: Photoshop CC>Plugins>Nik Software.  I had prior installed Nik Software for one of the pre-Google applications and had thereby automatically created the Nik Software folder in Plugins.  I found you may need to manually create such a folder prior to installation and then be sure to direct the installation to go all the way to that folder within Plugins - and not just to Plugins.
    Oct 2, 2013 6:37 PM   in reply to TomCoynerSeoul
    Thanks Tom... just tried that with my WIN 7 install and there are
    still no filters installed........     I had high hopes
    Oct 2, 2013 9:07 PM   in reply to hodad66
    I contacted Nik support and they sent me a link to download the Nik collection and this time it worked. I don't understand it, because the file I downloaded had the same name as the one I had been using to
    install Nik. I now have my Topaz and Nik filters. Wahoo.
    Thanks to everyone for their suggestions.
    Pat
    Nov 18, 2013 12:53 AM   in reply to Daznic
    I have a related issue...
    I have been successfully using Nik software from within PS CC for several months.  However about a month ago, the Nik stuff disappeared from my Filter menu.  After much frustration and a Nik reinstall, it came back.  I have been using it fine for the past month.  I have just gone into PS now and it has disappeared again.  Does anyone else have this issue?  I shouldn't have to keep reinstalling my Nik software every few weeks because PS keeps forgetting about it!!! Help!!!
    Dec 8, 2013 3:10 PM   in reply to UncleDobby
    Mine did not work until I moved the google directory under panels, see below:
    C:\Program Files\Adobe\Adobe Photoshop CC (64 Bit)\Plug-ins\Panels\Google
    Then everything shows up.
    Hope this works.
