Topaz Labs plugins don't showup in Photoshop CC
Jun 18, 2013 11:00 AM
Topaz labs plugins don't appear in Photoshop CC, not even after re-installing and restarting Photoshop AND there is no setting for additional plugins in the preferences menu option. Help, please?
    Jun 18, 2013 11:01 AM   in reply to grusum
    Jun 18, 2013 3:55 PM   in reply to grusum
    Make sure you are exited out of CC when you redownload the Topaz software from topazlabs.com/downloads. They should then install to the filter menu.
    Jun 18, 2013 4:38 PM   in reply to grusum
    This was exactly my experience too.  CC saw the filters if you copied their CS6 shortcut in the 64bit Plugins folder to the Plugins folder in CC, but the shortcut was NOT installed when I went throught the installation process.  The installation process put the filters in CS6 but not CC.  I had a similar problem and solution with Vuescan (which had refused to turn up under Import in CC) and the Photozoom Pro software (which had refused to turn up in the Automate menu).  At least there are workarounds...
    Jun 18, 2013 6:01 PM   in reply to nickna12
    For any of you guys who are having problems with plug-ins not showing up in PhotoshopCC, I figured out a solution - at least for Windows 7 users!
    Try running PSCC with the plug-ins installed. You should get nothing.
    Now close PSCC and open BridgeCC.
    Open an image in Bridge and send it to PSCC.
    See if you now have the plug-ins showing.....I do!
    Now, if you've already pinned PSCC to your taskbar, delete that one.
    Right click on the PSCC that is open with the plug-ins showing and pin that one to the taskbar.
    That should fix the problem......................for now.
    Jun 19, 2013 4:53 PM   in reply to grusum
    From Topaz Labs
    For Windows users:
    1. Exit out of all Photoshop applications
    2. Go to C:\Program Files\Adobe\Adobe Photoshop CS6 (64bit)\Plug-ins
    3. In another window open up C:\Program Files\Adobe\Adobe Photoshop CC (64bit)\plug-ins
    4. Drag/copy the Topaz shortcuts (eg. topazdenoise5_x64) to the CC Plug-Ins folder
    5. Re-open Photoshop CC and your Topaz Labs filters should be in the filter menu.
    See here for a video on how to do this: http://www.youtube.com/watch?v=g0a4_WfV8Ng
    *If using 32-bit CC, copy the plugin shortcuts from the 32-bit Plug-ins folder to 32-bit CC Plug-ins folder. The 32-bit CC is in:
    C:\Program Files (x86)\Adobe\Adobe Photoshop CC\
    **If you do not have a previous version of PS installed, you will need to re-download the plug-ins from topazlabs.com/downloads (be sure you are exited out of PS during the installation process).
    ***An alternative option:
    1. Close PSCC and open BridgeCC.
    2. Open an image in Bridge and send it to PSCC.
    3. See if you now have the plug-ins showing...
    4. If you've already pinned PSCC to your taskbar, delete that one.
    5. Right click on the PSCC that is open with the plug-ins showing and pin that one to the taskbar.
    For Mac users:
    2. Redownload the plug-ins from topazlabs.com/downloads
    3. After installation open PS and the Topaz plug-ins should be located in your filter menu.
