Premiere CC and Encore CS6
Jun 18, 2013 11:03 AM
Tags: #encore #encode #dvd #cc
It appers that there is no Encore CC version and it cannot dynamicly link to Premiere CC kindof a huge kink in my workflow! Anyone else having this issue? For a work around i exported my timeline in media encoder using the DVD presets.
    Jun 18, 2013 11:15 AM   in reply to Mr Eric J
    Jun 18, 2013 2:33 PM   in reply to Stan Jones
    This is very disturbing to my workflow.
    I make videos of operas. My clients want their operas on DVD. Unfortunately all my efforts to get them to consider Blu-Ray have failed. I sell 1 Blu-Ray to every 20 DVDs.
    The problem: Operas are LONG. They run 1:45 (short like LA BOHEME) - 2:15 (moderate like FAUST) hours (obviously without the intermissions).
    Anything much longer and I'm putting the opera on 2 discs. So far I've found burning to dual-layer DVD is not economic (the blanks are costly and unreliable and the failure rate is high; plus it takes three times as long to burn).
    So I've relied on the Dynamic Link to do "bit-budgeting", which it does decently.
    No Dynamic Link, no bit budgeting which means I have to play with the settings in Media Encoder, adding much time and effort to my work flow. ADOBE STOLE THAT TIME FROM ME. How difficult would it be to put Dynamic Link from PPro CC to Encore CS6? I'm not carping about not updating Encore. I just want my Dynamic Link back since Encore had an intelligence I don't want to have to develop about how to apportion the data on these discs.
    I also feel that they did this sneaky. I feel cheated. Anyone disagree?
    Jay
    Jun 18, 2013 3:15 PM   in reply to ElJayBronx
    Export DV AVI (regular or widescreen, as appropriate) and import the AVI in Encore... and tell Encore to use Automatic transcoding to make a "best fit" of time -vs- single or dual layer DVD
    Then, have Encore create an ISO instead of going to disc, and use the FREE http://www.imgburn.com/index.php?act=download to write files or folders or ISO to disc for DVD or BluRay (send the author a PayPal donation if you like his program)
    Imgburn will read the ACTUAL disc brand from the disc, which is not always the same as the box label (Memorex is notorious for buying "anything" and putting it inside a Memorex box)
    When you write to disc with Imgburn, use the SLOWEST possible speed setting, so your burner has the best chance to create "good, well formed" laser burn holes... since no DVD player is required to read a burned disc, having a "good" one from a high quality blank will help
    Use Taiyo Yuden single layer or Verbatim Two layer Or Falcon Pro for inkjet printable Two layer
    Jun 18, 2013 4:20 PM   in reply to John T Smith
    John:
    SO the idea is NOT to use PPro to make an already-transcoded file...interesting! I've been using ImgBurn for years and agree it's amazing. I have to use inkjet printable (Artisan 50 Printer). I've had very good luck with Encore's ISO images burning to disc, that's not the problem.
    My current workflow: Make video using Sony HDR-CX550V camera which puts out AVCHD at 1980x1020i. Cut (sometimes 12 performances in one project, each in its own sequence), add dissolves, titles, chapters. Dynamically link to Encore, set stop action/title button action/name video/make sure "image" is selected and set the place for it to save. Check for problems, usually none. Press "build". Wait about 2 hours or less. When Encore says "complete" it's time to burn the discs.
    What I'm trying to understand...I am getting from your post that the main thing I'm giving up is the time necessary to do a second transcode (to DV AVI using AME). Is there a way to get the chapters to come across or should i wait and create them in Encore? My only problem, if this works, is that it seems to force me to do two transcodes where before there was one...I guess it's better than trying to guess bitrates etc.
    Jay
    Jun 18, 2013 7:27 PM   in reply to ElJayBronx
    If you move to Premiere Pro Cloud you MUST export "something" from PPro, since it will not (from what I've read) use Dynamic Link to Encore CS6
    I think you can still export from PPro as MPEG2-DVD but that still requires bit budgeting... hence my AVI suggestion to then let Encore do the bit calculation
    Also, as pointed out in another thread, as time goes on, Adobe will NOT provide Encore CS6 updates for new Mac or Windows operating systems http://www.adobe.com/products/encore/faq.html
    Jun 18, 2013 9:54 PM   in reply to Mr Eric J
    They cancelled Encore??? Has anyone from adobe walked into a store, any store, ever??? DVD and Blu-Ray are still valid and common items. This just let a lot of the wind out my sail towards Adobe, I was a big supporter of the cloud. Stupid, just stupid. How about they cut the dumb Behance stuff, and keep up on the programs that still have a place in the profesional community.
    Jun 18, 2013 11:15 PM   in reply to ElJayBronx
    Here's the text of a letter I just faxed to Adobe corporate headquarters (for what it's worth):
    Dear sir or madam:
    I have just downloaded Premiere Pro CC and made a terrible discovery. I knew you had decided to retire Encore after CS6. What was not made clear was that you were wiping away the Dynamic Link between Premiere Pro and Encore in the process.
    Is that a necessary part of retiring Encore? It destroys my workflow and that of almost anyone who uses Premiere to make DVDs. I don’t notice a lot of extra help with the newly-necessary bit-budgeting process that the Premiere/Encore team was so good at to shoehorn large projects into single layer DVDs as I must.
    I don’t WANT to know how the sausages were made, and you’re in effect making me a sausage-maker. I’m not very happy.
    I note that you – after users including MYSELF complained mightily – put back the ability to directly mark a clip that you had taken away between PPro CS5.5 and CS6; can you not consider restoring the linkage between PPro CC and Encore CS6? I somehow think it would be less difficult for you to do that than for thousands of us to have to manually calculate our bit budgets. PLEASE consider restoring this valuable feature, or come up with an alternative such as adding in more granular and intelligent, and less esoteric, control of file size within PPro CC.
    The fact is that while many users of video software are not making DVDs and Blu-Rays, and while it probably almost seems dishonest to continue to make updates to software that already does virtually everything it can do (referring to Encore here), restoring the link to the older version would be appreciated by the thousands of users who DO have to make DVDs for our customers.
    Thanks in advance for your consideration of my point of view.
    Does anyone here disagree with my point of view?
    Jun 18, 2013 11:19 PM   in reply to squarepixelllc
    In defense of Adobe, my brother runs a far more professional-quality video-production shop than mine, and reports to me that although he has all the equipment to burn Blu-Ray and DVD, no client has asked for media to be delivered on those types of media for a long time...too late to ask him; maybe two or three years?
    That's the professional corporate video market. I suspect that it's the same market that drives demand for PPro (even though we know the product has been used to deliver feature films). Also, Encore may well have run out of tricks. The last version went to 64 bit and transcodes way faster than previously. I just feel strongly - see next post - that they unnecessarily threw away an important component of the workflow of people who DO still write DVD/Blu-Ray. Less important with Blu-Ray for me; when I make up a Blu-Ray disc with 1080i footage it would take about 3 1/2 hours to come close to filling the 25Gig disc. DVD not so much (although I'd put 3 1/2 hours on two discs). Too much close bit-budgeting going on.
    Jay
    Jun 18, 2013 11:23 PM   in reply to John T Smith
    One more question for John...I can't find anything in Encore documentation as to whether AVI is the only acceptable transcode format. I gather you suggest it since if we make a DVD-MPEG file it won't transcode and WE have to do the trial-and-error. What about a flavor of h264 or quicktime? Is there a list of what Encore can "see" to transcode?
    Jay
    Jun 19, 2013 5:13 AM   in reply to ElJayBronx
    John is using a 2 transcode method: once to get the avi (which for his purposes serves as a "not too lossy" step), and again in Encore where he is using the "automatic" transcode setting to let Encore do the bit budgeting when it transcodes.
    For DVD, the ONLY final format that Encore will not transcode again is MPEG2-DVD. (Bluray is another matter.)
    Most users who are not using dynamic link a) export from Premiere/AME as MPEG2-DVD and do the bit budgeting or b) export a lossless intermediate from Premiere/AME (or frame serve), and transcode that to MPEG2-DVD using a non-Adobe transcoder.
    The list of files Encore will import is here:
    http://helpx.adobe.com/encore/using/importing-assets.html
    Jun 19, 2013 7:58 AM   in reply to Stan Jones
    Grin... what Stan said, at 5:13 AM while I was still sleeping
    I export AVCHD to Widescreen DV AVI since it has all the quality that I need... but I am NOT doing work for pay, only for family video http://forums.adobe.com/thread/652694
    For me, the DVD's I make now are much better than the ones I made when I had a tape camera captured through a Pinnacle DV500 card... since the AVCHD I start with is much better than what came off the tape
    For you... you may want to export to a lossless (and very large) file as Stan suggests and give that file to Encore... or do the bit budgeting yourself and export from PPro to MPEG2-DVD
    Actually, you may want to do a test using both procedures... and see if you notice a quality difference between your calculations for MPEG2-DVD and the DV AVI route
    Jun 19, 2013 9:46 AM   in reply to Mr Eric J
    The loss of being able to easily mark a clip was a huge bummer for me as well.
    You can still export markers from Premiere, but I don't think we know yet what formats will work correctly with the "new" CC markers. I hope that the only change they made was in the GUI, and that the actual technical information being  transmitted in the xml files is the same.
    And it was a bit of a point to update markers. But no question; dynamic link was a very useful way to work interactively in creating DVDs and Blurays. Even if you abandoned it in the end and used exported files.
    Jun 19, 2013 9:47 AM   in reply to John T Smith
    Well, it was 8:15 my time!
