Illustrator CC is not importing AutoCAD DWG file layers correctly
Jun 18, 2013 4:25 PM
In CS6, I could import (open) DWG files  and it would correctly categorize the input objects into separate layers. In CC, it is putting them into a group in a single layer,  which is a big usability regression. Is there a fix for this?
    Jun 24, 2013 9:55 AM   in reply to hjespersen
    I am experiencing the same error.
    Jul 19, 2013 8:19 AM   in reply to hjespersen
    Same problem here, llustrator CC.
    Sep 24, 2013 1:50 PM   in reply to hjespersen
    It would be very helpful if they'd fix this! It defeats the advantage of using Illustrator to render acad drawings. Thanks for persevering.
    Oct 25, 2013 12:52 PM   in reply to hjespersen
    It's realy big problem for me but i figured out a way that you can make each layer on DWG as a one block. so when you open the file on illustrator u still be able to select each layer alone.
    Oct 25, 2013 1:07 PM   in reply to samimid
    Have you tried saving the acad file back to 2006? I think I saw a memo to that effect.
    Oct 25, 2013 1:32 PM   in reply to kriegeld
    There is no 2006 file... 2004, 2007, 2010, 2013. I tried all of them... It's the same.
    Nov 10, 2013 9:26 AM   in reply to hjespersen
    Dear Adobe...
    Dont be Microsoft and push this half-assed CC software out the door!
    And for Gods sake.. Secure your damn transaction servers...
    Nov 11, 2013 6:41 AM   in reply to samimid
    "i figured out a way that you can make each layer on DWG as a one block". How do you do this?
    Nov 18, 2013 2:07 AM   in reply to BeneQ
    In the latest update of  Adobe Illustrator CC, released about an hour ago, this bug has been fixed. For more details on this update, kindly refer to:
    http://helpx.adobe.com/illustrator/release-note/illustrator-17-0-1-rel ease-notes.html
    Thanks & Regards,
    Raghuveer
    Nov 18, 2013 2:55 AM   in reply to Raghuveer Singh Bhunwal
    Tnx for the fix and message!
    Jan 28, 2014 7:44 AM   in reply to hjespersen
    CC updated and now I am having an issue where the layers import but the objects are on diffferent layers than where they started out. Some of the dimension objects wind up on the walls layer the valence objects end up on the 0 layer amd all sorts of random objects land on the defpoints layer I never use the defpoints layer etc etc. I have to go through the file and select all the objects by stroke color then cut and paste in place everything in the correct layer. this is a new issue since the CC updated last week. Tried saving the autocad file back to 2000 and as a DXF.
