cyberix12
Error accessing Flex application via proxy server (IBM HTTPServer)
Jun 18, 2013 9:48 PM
Currently I have this situation, I have a Flex application and a java webservice application (2 seperate war file) running in a IBM Websphere Application Server (version 8). The Flex application consume the java webservices through the WebService component in the Flex SDK. The client machine browser is able to load and run the Flex application successfully (on Flash Player 10 IE9). However, when a proxy server (IBM HTTPServer) is introduced, a "security error accessing url" is encountered, crossdomain.xml doesn't seem to help, appreciate is someone can help.
Thankyou very much.
Webservice location
http://XX.XX.XX.100:9080/myServer/services/My_Svc.port?wsdl
Accessing Flex directly on IBM Web Application Server is working
http://XX.XX.XX.100:9080/myFlexApp/
Accessing Flex via a IBM HTTPWeb Server (proxy) is not working
http://XX.XX.XX.70/myFlexApp/
Cross Domain Policy File as below
<?xml version="1.0"?>
<!DOCTYPE cross-domain-policy SYSTEM "http://www.adobe.com/xml/dtds/cross-domain-policy.dtd">
<cross-domain-policy>
<allow-access-from domain="*" secure="false"/>
</cross-domain-policy>
