Mayamoto
Flash Pro CC is crashing when trying to create new of open existing document.
Jun 19, 2013 7:34 AM
Tags: #flash #professional #cc
These are the things that I have already tried:
  • Sign out and back in to Creative Cloud App. >> did not work
  • Unistall and reinstall the app. >> did not work
The is a portion of the crash report I get:
     Crashed Thread: 0  Dispatch queue: com.apple.main-thread
     Exception Type: EXC_BAD_ACCESS (SIGSEGV)
     Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
The machine is a Macbook Pro Retina (Mid 2012) High-end specs. (no system resource shortage)
Other symptoms:
  • when the app launches and before the attempt to create or open a document, I get a backgroud in the center of the stage with wierd blue streaks across it
    Jun 19, 2013 5:17 PM   in reply to Mayamoto
    Hi Mayamoto,
    I have forwarded your query to the product team. Will let you know as soon as I hear from them.
    Preran
    Jun 25, 2013 10:16 AM   in reply to Mayamoto
    I also have this exact problem. When I open the program I get different glitched out dotted / lined patterns where the canvas usually is. I too, uninstalled and reinstalled Flash to remedy the problem. No luck. Additional information. I'm using this player - "flashplayer_11_plugin_debug".
    Here some screen caps...
    http://foxflare.com/trans/ss1.png
    http://foxflare.com/trans/ss2.png
    I'm going back to Flash Professional 6 until CC becomes stable.
    Jul 18, 2013 7:15 AM   in reply to flite415
    I am also having this issue - I have also uninstalled CS6 - so now I'm right back to CS5.5 as my only option (this is not at all ideal)
    Crash report:
    Process:         Adobe Flash CC [717]
    Path:            /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/MacOS/Adobe Flash CC
    Identifier:      com.adobe.Adobe Flash CC.application
    Version:         13.0.0.759 (13.0.0.759)
    Code Type:       X86-64 (Native)
    Parent Process:  launchd [181]
    User ID:         501
    Date/Time:       2013-07-18 15:08:14.281 +0100
    OS Version:      Mac OS X 10.8.4 (12E55)
    Report Version:  10
    Interval Since Last Report:          4460 sec
    Crashes Since Last Report:           12
    Per-App Interval Since Last Report:  214 sec
    Per-App Crashes Since Last Report:   7
    Anonymous UUID:                      9DE44919-D51E-B895-839D-BFBEB1A8731F
    VM Regions Near 0:
        __TEXT                 0000000100000000-0000000101798000 [ 23.6M] r-x/rwx SM=COW  /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/MacOS/Adobe Flash CC
    Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
    0   ???                                     000000000000000000 0 + 0
    1   com.adobe.Adobe Flash CC.application          0x0000000100e28c17 CStagePlayer::ConnectToASStagePlayer() + 135
    2   com.adobe.Adobe Flash CC.application          0x0000000100e2889c CStagePlayer::LoadStageMovie(CSketchDoc*) + 428
    3   com.adobe.Adobe Flash CC.application          0x0000000100e1b70a CStagePlayerManager::GetPlayerForView(CStagePlayerView*) + 106
    4   com.adobe.Adobe Flash CC.application          0x00000001006f1732 CSketchView::GetStagePlayer(bool) + 130
    5   com.adobe.Adobe Flash CC.application          0x00000001006f2547 CSketchView::FreeBuffer() + 23
    6   com.adobe.Adobe Flash CC.application          0x000000010080ea5c COffscreenView::UpdateBuffer() + 108
    7   com.adobe.Adobe Flash CC.application          0x00000001000c73d3 DroverSketchView::UI_Draw(dvaui::drawbot::Drawbot*) const + 499
    8   com.adobe.dvaui.framework               0x000000010365ab6c dvaui::ui::UI_Node::UI_DrawSelf(dvaui::drawbot::Drawbot*, bool, dvaui::drawbot::ColorRGBA const*) const + 332
    9   com.adobe.dvaui.framework               0x000000010365af75 dvaui::ui::UI_Node::UI_DrawAndCache(dvaui::drawbot::Drawbot*, bool, dvaui::drawbot::ColorRGBA const*) const + 901
    10  com.adobe.dvaui.framework               0x000000010365b298 dvaui::ui::UI_Node::UI_DispatchDrawToChild(dvaui::ui::UI_Node const*, dvaui::drawbot::Drawbot*) + 296
    11  com.adobe.dvaui.framework               0x0000000103659a2b dvaui::ui::UI_Node::UI_Draw(dvaui::drawbot::Drawbot*) const + 43
    12  com.adobe.dvaui.framework               0x000000010365ab6c dvaui::ui::UI_Node::UI_DrawSelf(dvaui::drawbot::Drawbot*, bool, dvaui::drawbot::ColorRGBA const*) const + 332
    13  com.adobe.dvaui.framework               0x000000010365af75 dvaui::ui::UI_Node::UI_DrawAndCache(dvaui::drawbot::Drawbot*, bool, dvaui::drawbot::ColorRGBA const*) const + 901
    14  com.adobe.dvaui.framework               0x000000010365b298 dvaui::ui::UI_Node::UI_DispatchDrawToChild(dvaui::ui::UI_Node const*, dvaui::drawbot::Drawbot*) + 296
    15  com.adobe.dvaui.framework               0x0000000103659a2b dvaui::ui::UI_Node::UI_Draw(dvaui::drawbot::Drawbot*) const + 43
    16  com.adobe.dvaui.framework               0x000000010365ab6c dvaui::ui::UI_Node::UI_DrawSelf(dvaui::drawbot::Drawbot*, bool, dvaui::drawbot::ColorRGBA const*) const + 332
    17  com.adobe.dvaui.framework               0x000000010365af75 dvaui::ui::UI_Node::UI_DrawAndCache(dvaui::drawbot::Drawbot*, bool, dvaui::drawbot::ColorRGBA const*) const + 901
    18  com.adobe.dvaui.framework               0x000000010365b298 dvaui::ui::UI_Node::UI_DispatchDrawToChild(dvaui::ui::UI_Node const*, dvaui::drawbot::Drawbot*) + 296
    19  com.adobe.dvaui.framework               0x0000000103659a2b dvaui::ui::UI_Node::UI_Draw(dvaui::drawbot::Drawbot*) const + 43
    20  com.adobe.dvaui.framework               0x000000010365ab6c dvaui::ui::UI_Node::UI_DrawSelf(dvaui::drawbot::Drawbot*, bool, dvaui::drawbot::ColorRGBA const*) const + 332
    21  com.adobe.dvaui.framework               0x000000010365af75 dvaui::ui::UI_Node::UI_DrawAndCache(dvaui::drawbot::Drawbot*, bool, dvaui::drawbot::ColorRGBA const*) const + 901
    22  com.adobe.dvaui.framework               0x000000010365b298 dvaui::ui::UI_Node::UI_DispatchDrawToChild(dvaui::ui::UI_Node const*, dvaui::drawbot::Drawbot*) + 296
    23  com.adobe.dvaui.framework               0x0000000103659a2b dvaui::ui::UI_Node::UI_Draw(dvaui::drawbot::Drawbot*) const + 43
    24  com.adobe.dvaui.framework               0x000000010365ab6c dvaui::ui::UI_Node::UI_DrawSelf(dvaui::drawbot::Drawbot*, bool, dvaui::drawbot::ColorRGBA const*) const + 332
    25  com.adobe.dvaui.framework               0x000000010365af75 dvaui::ui::UI_Node::UI_DrawAndCache(dvaui::drawbot::Drawbot*, bool, dvaui::drawbot::ColorRGBA const*) const + 901
    26  com.adobe.dvaui.framework               0x000000010365b298 dvaui::ui::UI_Node::UI_DispatchDrawToChild(dvaui::ui::UI_Node const*, dvaui::drawbot::Drawbot*) + 296
    27  com.adobe.dvaui.framework               0x0000000103659a2b dvaui::ui::UI_Node::UI_Draw(dvaui::drawbot::Drawbot*) const + 43
    28  com.adobe.dvaui.framework               0x000000010365ab6c dvaui::ui::UI_Node::UI_DrawSelf(dvaui::drawbot::Drawbot*, bool, dvaui::drawbot::ColorRGBA const*) const + 332
    29  com.adobe.dvaui.framework               0x000000010365af75 dvaui::ui::UI_Node::UI_DrawAndCache(dvaui::drawbot::Drawbot*, bool, dvaui::drawbot::ColorRGBA const*) const + 901
    30  com.adobe.dvaui.framework               0x000000010365b298 dvaui::ui::UI_Node::UI_DispatchDrawToChild(dvaui::ui::UI_Node const*, dvaui::drawbot::Drawbot*) + 296
    31  com.adobe.dvaui.framework               0x000000010365ab24 dvaui::ui::UI_Node::UI_DrawSelf(dvaui::drawbot::Drawbot*, bool, dvaui::drawbot::ColorRGBA const*) const + 260
    32  com.adobe.dvaui.framework               0x000000010365af75 dvaui::ui::UI_Node::UI_DrawAndCache(dvaui::drawbot::Drawbot*, bool, dvaui::drawbot::ColorRGBA const*) const + 901
    33  com.adobe.dvaui.framework               0x000000010365b66c dvaui::ui::UI_Node::UI_DispatchDrawFromRoot(dvaui::drawbot::ColorRGBA const&, dvaui::drawbot::Drawbot*, bool) const + 348
    34  com.adobe.Adobe Flash CC.application          0x0000000100076486 SketchViewPanel::UI_Draw(dvaui::drawbot::Drawbot*) const + 86
    35  com.adobe.dvaui.framework               0x00000001036e91b6 void dvaui::drawbot::InvokeDrawbotFromRegionT<dvaui::ui::OS_View, std::const_mem_fun1_ref_t<void, dvaui::ui::OS_View, dvaui::drawbot::Drawbot*>, NSView*>(dvaui::ui::OS_View const&, std::const_mem_fun1_ref_t<void, dvaui::ui::OS_View, dvaui::drawbot::Drawbot*> const&, dvaui::drawbot::SupplierInterface const&, NSView*, __HIShape const*, dvaui::drawbot::SurfaceInterface*, bool) + 198
    36  com.adobe.dvaui.framework               0x00000001036e5961 void dvaui::drawbot::InvokeDrawbot<dvaui::ui::OS_View, std::const_mem_fun1_ref_t<void, dvaui::ui::OS_View, dvaui::drawbot::Drawbot*>, NSView*>(dvaui::ui::OS_View const&, std::const_mem_fun1_ref_t<void, dvaui::ui::OS_View, dvaui::drawbot::Drawbot*> const&, dvaui::drawbot::SupplierInterface const&, NSView*, __HIShape const*, dvaui::drawbot::SurfaceInterface*, std::vector<dvacore::geom::RectT<int>, std::allocator<dvacore::geom::RectT<int> > >*, bool) + 577
    37  com.adobe.dvaui.framework               0x00000001036d56c2 dvaui::ui::OS_View::UI_HandlePlatformDrawEvent(dvaui::drawbot::Surfac eInterface*) + 402
    38  com.adobe.dvacore.framework             0x0000000102f13fc4 int dvacore::config::ErrorManager::ExecuteFunction<void>(boost::function0 <void>*, void*) + 68
    39  com.adobe.Adobe Flash CC.application          0x000000010003fbf7 flashpro::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler(b oost::function0<int>) + 71
    40  com.adobe.dvacore.framework             0x0000000102f1405c void dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHa ndler<void>(boost::function0<void>, bool*) + 140
    41  com.adobe.dvacore.framework             0x0000000102f15bcd void dvacore::config::ExecuteTopLevelFunction<void>(boost::function0<void> , bool*) + 125
    42  com.adobe.dvaui.framework               0x00000001036dfa96 -[DVAMacContainerView drawRect:] + 118
    43  com.apple.AppKit                        0x00007fff8fa9c064 -[NSView _drawRect:clip:] + 4217
    44  com.apple.AppKit                        0x00007fff8fa9a6c1 -[NSView _recursiveDisplayAllDirtyWithLockFocus:visRect:] + 1656
    45  com.apple.AppKit                        0x00007fff8fa9aad9 -[NSView _recursiveDisplayAllDirtyWithLockFocus:visRect:] + 2704
    46  com.apple.AppKit                        0x00007fff8fa986f2 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisi bleRectForView:topView:] + 817
    47  com.apple.AppKit                        0x00007fff8fa99a44 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisi bleRectForView:topView:] + 5763
    48  com.apple.AppKit                        0x00007fff8fa99a44 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisi bleRectForView:topView:] + 5763
    49  com.apple.AppKit                        0x00007fff8fa99a44 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisi bleRectForView:topView:] + 5763
    50  com.apple.AppKit                        0x00007fff8fa99a44 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisi bleRectForView:topView:] + 5763
    51  com.apple.AppKit                        0x00007fff8fa99a44 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisi bleRectForView:topView:] + 5763
    52  com.apple.AppKit                        0x00007fff8fa99a44 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisi bleRectForView:topView:] + 5763
    53  com.apple.AppKit                        0x00007fff8fbe7fab -[NSNextStepFrame _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisi bleRectForView:topView:] + 286
    54  com.apple.AppKit                        0x00007fff8fa93d6d -[NSView _displayRectIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:] + 4675
    55  com.apple.AppKit                        0x00007fff8fa5dc93 -[NSView displayIfNeeded] + 1830
    56  com.apple.AppKit                        0x00007fff8fbe7e64 -[NSNextStepFrame displayIfNeeded] + 84
    57  com.adobe.owl                           0x00000001064f58ff 0x1064b2000 + 276735
    58  com.adobe.owl                           0x00000001064f8e23 0x1064b2000 + 290339
    59  com.adobe.owl                           0x00000001064d9a9d 0x1064b2000 + 162461
    60  com.adobe.owl                           0x00000001064d96eb 0x1064b2000 + 161515
    61  com.adobe.owl                           0x00000001064f0ac6 0x1064b2000 + 256710
    62  com.adobe.owl                           0x00000001064fd6c3 0x1064b2000 + 308931
    63  com.adobe.owl                           0x00000001064fcc99 OWLWidgetShow + 491
    64  com.adobe.Adobe Flash CC.application          0x0000000100095eed owlhost::OwlWorkspaceUtil::SetFocusedTabPanel(owlhost::OwlPanel*, bool, bool) + 685
    65  com.adobe.Adobe Flash CC.application          0x0000000100028cbb flashpro::App::OpenSketchViewPanel(flashpro::FlDocument*, bool) + 1019
    66  com.adobe.Adobe Flash CC.application          0x00000001000298d4 flashpro::App::CreateFLADocument(CSketchDoc::SketchDocType, bool) + 244
    67  com.adobe.Adobe Flash CC.application          0x00000001000296c0 flashpro::App::CreateNewDocument(flashpro::DocType) + 48
    68  com.adobe.Adobe Flash CC.application          0x0000000100501459 drover::model::NewDocumentEveDialogModel::ApplyNewDocument() + 265
    69  com.adobe.Adobe Flash CC.application          0x00000001005027d9 drover::dialogs::DoNewDocumentEveDialog() + 601
    70  com.adobe.Adobe Flash CC.application          0x000000010002186e flashpro::App::DoHandleCommand(int) + 334
    71  com.adobe.Adobe Flash CC.application          0x0000000100025e70 non-virtual thunk to flashpro::App::DoHandleCommand(int) + 16
    72  com.adobe.exo.framework                 0x00000001041dc18b exo::uisupport::CommandHandler::HandleCommand(int) + 235
    73  com.adobe.exo.framework                 0x00000001041dc2ea exo::uisupport::CommandHandler::DoCallMyCommandChain(int) + 26
    74  com.adobe.exo.framework                 0x00000001041dbcc8 exo::uisupport::CommandHandlerBase::CallCommandChain(int) + 56
    75  com.adobe.exo.framework                 0x00000001041e34b4 exo::uisupport::KeyCommandManager::RouteKeyEvent(dvaui::ui::KeyboardE vent const&) + 852
    76  com.adobe.exo.framework                 0x00000001041f8593 exo::workspace::TopLevelWindow::UI_DoKeyboardEvent(dvaui::ui::UI_Node *, dvaui::ui::KeyboardEvent const&) + 131
    77  com.adobe.Adobe Flash CC.application          0x000000010008f482 owlhost::OwlPanel::UI_DoKeyboardEvent(dvaui::ui::UI_Node*, dvaui::ui::KeyboardEvent const&) + 114
    78  com.adobe.dvaui.framework               0x0000000103660130 dvaui::ui::UI_Node::UI_DispatchKeyboardEvent(dvaui::ui::UI_Node*, dvaui::ui::KeyboardEvent const&) + 496
    79  com.adobe.dvaui.framework               0x00000001036c8eed dvaui::ui::OS_Node::UI_DispatchKeyboardEventFromOS(dvaui::ui::OS_Even t*) + 157
    80  com.adobe.dvaui.framework               0x00000001036d47fe dvaui::ui::OS_View::UI_DispatchPlatformKeyDownEvent(dvaui::ui::OS_Eve nt&) + 126
    81  com.adobe.dvaui.framework               0x00000001036d4373 dvaui::ui::OS_View::UI_DispatchEvent(dvaui::ui::OS_Event*) + 435
    82  com.adobe.dvaui.framework               0x00000001036d4196 dvaui::ui::OS_View::UI_HandleOSEvent(dvaui::ui::OS_Event*) + 22
    83  com.adobe.Adobe Flash CC.application          0x00000001000c1335 flashpro::swfviewer::OS_PlayerView::UI_HandleOSEvent(dvaui::ui::OS_Ev ent*) + 37
    84  com.adobe.dvaui.framework               0x00000001036d5439 dvaui::ui::OS_View::UI_HandlePlatformEvent(NSEvent*) + 57
    85  com.adobe.dvacore.framework             0x0000000102f13fc4 int dvacore::config::ErrorManager::ExecuteFunction<void>(boost::function0 <void>*, void*) + 68
    86  com.adobe.Adobe Flash CC.application          0x000000010003fbf7 flashpro::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler(b oost::function0<int>) + 71
    87  com.adobe.dvacore.framework             0x0000000102f1405c void dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHa ndler<void>(boost::function0<void>, bool*) + 140
    88  com.adobe.dvacore.framework             0x0000000102f15bcd void dvacore::config::ExecuteTopLevelFunction<void>(boost::function0<void> , bool*) + 125
    89  com.adobe.dvaui.framework               0x00000001036e217a -[DVAMacContainerView keyDown:] + 122
    90  com.adobe.Adobe Flash CC.application          0x00000001000c0a57 -[SwfViewerContainerView keyDown:] + 215
    91  com.apple.AppKit                        0x00007fff8fb40020 -[NSWindow sendEvent:] + 9687
    92  com.adobe.owl                           0x00000001064e8aca 0x1064b2000 + 223946
    93  com.apple.AppKit                        0x00007fff8fb3b644 -[NSApplication sendEvent:] + 5761
    94  com.adobe.dvaui.framework               0x00000001036d993e -[DVAMacApplication sendEvent:] + 622
    95  com.adobe.exo.framework                 0x000000010417b310 -[ExoMacApplication sendEvent:] + 544
    96  com.apple.AppKit                        0x00007fff8fa5121a -[NSApplication run] + 636
    97  com.adobe.exo.framework                 0x000000010417ad48 exo::app::OS_AppBase::RunEventLoop() + 56
    98  com.adobe.Adobe Flash CC.application          0x000000010002de30 flashpro::App::ProcessCommandLineParamsAndRunEventLoop(std::vector<st d::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::allocator<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > > const&) + 992
    99  com.adobe.Adobe Flash CC.application          0x00000001000baa50 main + 992
    100 com.adobe.Adobe Flash CC.application          0x0000000100002aa4 start + 52
    Thread 1:: Dispatch queue: com.apple.libdispatch-manager
    0   libsystem_kernel.dylib                  0x00007fff93139d16 kevent + 10
    1   libdispatch.dylib                       0x00007fff90d68dea _dispatch_mgr_invoke + 883
    2   libdispatch.dylib                       0x00007fff90d689ee _dispatch_mgr_thread + 54
    Thread 2:
    0   libsystem_kernel.dylib                  0x00007fff931396d6 __workq_kernreturn + 10
    1   libsystem_c.dylib                       0x00007fff9682ef4c _pthread_workq_return + 25
    2   libsystem_c.dylib                       0x00007fff9682ed13 _pthread_wqthread + 412
    3   libsystem_c.dylib                       0x00007fff968191d1 start_wqthread + 13
    Thread 3:
    Thread 4:
    Thread 5:
    0   libsystem_kernel.dylib                  0x00007fff931392aa __recvfrom + 10
    1   ServiceManager-Launcher.dylib           0x0000000111638231 0x111620000 + 98865
    2   ServiceManager-Launcher.dylib           0x00000001116375d6 0x111620000 + 95702
    3   ServiceManager-Launcher.dylib           0x0000000111636678 0x111620000 + 91768
    4   ServiceManager-Launcher.dylib           0x00000001116366e6 0x111620000 + 91878
    5   ServiceManager-Launcher.dylib           0x00000001116312e4 0x111620000 + 70372
    6   ServiceManager-Launcher.dylib           0x0000000111631cfe 0x111620000 + 72958
    7   ServiceManager-Launcher.dylib           0x0000000111631c0b 0x111620000 + 72715
    8   ServiceManager-Launcher.dylib           0x000000011163536e 0x111620000 + 86894
    9   ServiceManager-Launcher.dylib           0x00000001116354b2 0x111620000 + 87218
    10  ServiceManager-Launcher.dylib           0x000000011163526d 0x111620000 + 86637
    11  ServiceManager-Launcher.dylib           0x00000001116351e6 0x111620000 + 86502
    12  ServiceManager-Launcher.dylib           0x0000000111623916 0x111620000 + 14614
    13  ServiceManager-Launcher.dylib           0x0000000111627b05 0x111620000 + 31493
    14  ServiceManager-Launcher.dylib           0x0000000111635e46 0x111620000 + 89670
    15  ServiceManager-Launcher.dylib           0x0000000111637ef3 0x111620000 + 98035
    16  libsystem_c.dylib                       0x00007fff9682c7a2 _pthread_start + 327
    17  libsystem_c.dylib                       0x00007fff968191e1 thread_start + 13
    Thread 6:
    0   libsystem_kernel.dylib                  0x00007fff931390fa __psynch_cvwait + 10
    1   libsystem_c.dylib                       0x00007fff96830fe9 _pthread_cond_wait + 869
    2   com.macromedia.Flash Player.authplaylib          0x000000011858715b 0x118025000 + 5644635
    3   com.macromedia.Flash Player.authplaylib          0x00000001180aec1e 0x118025000 + 564254
    4   com.macromedia.Flash Player.authplaylib          0x0000000118587301 0x118025000 + 5645057
    5   com.macromedia.Flash Player.authplaylib          0x0000000118587382 0x118025000 + 5645186
    Thread 7:
    Thread 8:
    Thread 9:
    Thread 10:
    0   libsystem_kernel.dylib                  0x00007fff93139386 __semwait_signal + 10
    1   libsystem_c.dylib                       0x00007fff968b6800 nanosleep + 163
    2   com.adobe.FLBridge.framework            0x0000000111df5c38 ScObjects::Thread::wait(unsigned int) + 56
    3   com.adobe.FLBridge.framework            0x0000000111df10be ScObjects::BridgeTalkThread::run() + 174
    4   com.adobe.FLBridge.framework            0x0000000111df57f5 ScObjects::Thread::go(void*) + 165
    5   libsystem_c.dylib                       0x00007fff9682c7a2 _pthread_start + 327
    6   libsystem_c.dylib                       0x00007fff968191e1 thread_start + 13
    Thread 11:: C4: CollectionGetRoots
    2   com.adobe.Adobe Flash CC.application          0x00000001008905bb boost::condition_variable::wait(boost::unique_lock<boost::mutex>&) + 155
    3   com.adobe.cloudsync.framework           0x0000000106a0c25f uxtech::c4::AccessTokenCoordinator::RequestNewTokenFromWorkerThread(s td::string const&, bool) + 511
    4   com.adobe.cloudsync.framework           0x0000000106a3aea9 uxtech::c4::ResourceProvider::CreateAccessToken() + 25
    5   com.adobe.cloudsync.framework           0x0000000106a3c663 (anonymous namespace)::Send(uxtech::c4::netio::HttpRequest&, uxtech::c4::netio::HttpResponse&, uxtech::c4::ccapi::TaskProxy&, uxtech::c4::netio::ResourceProvider&, uxtech::c4::netio::ProgressNotifier*) + 451
    6   com.adobe.cloudsync.framework           0x0000000106a46343 uxtech::c4::ccapi::CollectionGetRoots(std::string const&, std::string const*, uxtech::c4::netio::ResourceProvider&, uxtech::c4::ccapi::TaskProxy&, std::tr1::shared_ptr<std::vector<std::tr1::shared_ptr<uxtech::c4::Col lection>, std::allocator<std::tr1::shared_ptr<uxtech::c4::Collection> > > const>&) + 739
    7   com.adobe.cloudsync.framework           0x0000000106a2f7c5 uxtech::c4::NetworkTask::InvokePerform() + 997
    8   com.adobe.cloudsync.framework           0x0000000106a38836 (anonymous namespace)::ThreadControllerContinous::Run() + 1990
    9   com.adobe.cloudsync.framework           0x0000000106a3657a (anonymous namespace)::ThreadController::operator()() + 266
    10  com.adobe.boost_threads.framework          0x0000000102ebae64 thread_proxy + 164
    11  libsystem_c.dylib                       0x00007fff9682c7a2 _pthread_start + 327
    12  libsystem_c.dylib                       0x00007fff968191e1 thread_start + 13
    Thread 12:: C4 ThreadController
    3   com.adobe.cloudsync.framework           0x0000000106a385d3 (anonymous namespace)::ThreadControllerContinous::Run() + 1379
    4   com.adobe.cloudsync.framework           0x0000000106a3657a (anonymous namespace)::ThreadController::operator()() + 266
    5   com.adobe.boost_threads.framework          0x0000000102ebae64 thread_proxy + 164
    Thread 13:: C4 ThreadController
    Thread 14:: C4 ThreadController
    Thread 15:: C4 ThreadController
    Thread 16:: C4 ThreadController
    Thread 17:: C4 ThreadController
    Thread 18:: C4 ThreadController
    Thread 19:: com.apple.NSURLConnectionLoader
    0   libsystem_kernel.dylib                  0x00007fff93137686 mach_msg_trap + 10
    1   libsystem_kernel.dylib                  0x00007fff93136c42 mach_msg + 70
    2   com.apple.CoreFoundation                0x00007fff8f73b233 __CFRunLoopServiceMachPort + 195
    3   com.apple.CoreFoundation                0x00007fff8f740916 __CFRunLoopRun + 1078
    4   com.apple.CoreFoundation                0x00007fff8f7400e2 CFRunLoopRunSpecific + 290
    5   com.apple.Foundation                    0x00007fff97ac9546 +[NSURLConnection(Loader) _resourceLoadLoop:] + 356
    6   com.apple.Foundation                    0x00007fff97b27562 __NSThread__main__ + 1345
    7   libsystem_c.dylib                       0x00007fff9682c7a2 _pthread_start + 327
    8   libsystem_c.dylib                       0x00007fff968191e1 thread_start + 13
    Thread 20:
    Thread 21:
    Thread 22:
    Thread 23:
    2   com.adobe.Adobe Flash CC.application          0x00000001011e3468 ScObjects::Thread::wait(unsigned int) + 56
    3   com.adobe.Adobe Flash CC.application          0x00000001011df01e ScObjects::BridgeTalkThread::run() + 174
    4   com.adobe.Adobe Flash CC.application          0x00000001011e3025 ScObjects::Thread::go(void*) + 165
    Thread 24:: com.apple.CFSocket.private
    0   libsystem_kernel.dylib                  0x00007fff93139322 __select + 10
    1   com.apple.CoreFoundation                0x00007fff8f77ff46 __CFSocketManager + 1302
    2   libsystem_c.dylib                       0x00007fff9682c7a2 _pthread_start + 327
    3   libsystem_c.dylib                       0x00007fff968191e1 thread_start + 13
    Thread 0 crashed with X86 Thread State (64-bit):
      rax: 0x0000000000000003  rbx: 0x000000010cb6d400  rcx: 0x00007fff7d0f8180  rdx: 0x0000000000000129
      rdi: 0x000000011aeda3d0  rsi: 0x000000010cb6dcf0  rbp: 0x00007fff5fbf9500  rsp: 0x00007fff5fbf9448
       r8: 0x00000001193a5030   r9: 0x0000000000000003  r10: 0x00000001192c67f0  r11: 0x00007fff7d30e268
      r12: 0x000000010b399c00  r13: 0x0000000000000000  r14: 0x000000010cb6dcf0  r15: 0x000000010cb6da70
      rip: 0x0000000000000000  rfl: 0x0000000000010212  cr2: 0x0000000000000000
    Logical CPU: 3
    Binary Images:
           0x100000000 -        0x101797fe7 +com.adobe.Adobe Flash CC.application (13.0.0.759 - 13.0.0.759) <9D5BB68D-1BF5-3169-A0E4-CEE916778AC7> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/MacOS/Adobe Flash CC
           0x102e02000 -        0x102e51fff +com.adobe.headlights.LogSessionFramework (2.1.2.1756) <BD518257-970F-344A-92B8-B8BE1A8EB4D8> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
           0x102e87000 -        0x102e89fff +com.adobe.AdobeCrashReporter (7.0 - 7.0.1) <B68D0D42-8DEB-3F22-BD17-981AC060E9D7> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/Ad obeCrashReporter
           0x102e8f000 -        0x102e93ff7 +com.adobe.boost_system.framework (7.0.0.0 - 7.0.0.0) <35465F84-A64F-39ED-AB1C-C3B38DD6113C> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_sy stem
           0x102e9c000 -        0x102ea2ff7 +com.adobe.boost_date_time.framework (7.0.0.0 - 7.0.0.0) <90306C88-8C0A-3AA4-BC05-A0F46A1E8D18> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost _date_time
           0x102eb9000 -        0x102ec8fff +com.adobe.boost_threads.framework (7.0.0.0 - 7.0.0.0) <8DC35A5C-1E28-3AB6-8BC6-9884B8A54AC1> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_t hreads
           0x102eec000 -        0x103140fff +com.adobe.dvacore.framework (7.0.0.0 - 7.0.0.0) <2CCD1883-0B6D-3909-AF70-3E69253FDF71> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
           0x1033cb000 -        0x1033d6ff7 +com.adobe.boost_signals.framework (7.0.0.0 - 7.0.0.0) <3963F332-78F8-3A6F-B453-0939DC2F1A99> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_s ignals
           0x1033ef000 -        0x103898ff7 +com.adobe.dvaui.framework (7.0.0.0 - 7.0.0.0) <C105531E-74CD-3103-AC5E-2E68486B505C> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
           0x103f8e000 -        0x104042ff7 +com.adobe.dvaworkspace.framework (7.0.0.0 - 7.0.0.0) <1C6C6229-AA29-3DA0-BF6C-81F35ADD6FAA> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworks pace
           0x104173000 -        0x10423afff +com.adobe.exo.framework (7.0.0.0 - 7.0.0.0) <43B88221-D61B-3D72-9EC5-214611EF70CC> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/exo.framework/Versions/A/exo
           0x1043c3000 -        0x1043e4ff7 +com.adobe.dvaunittesting.framework (7.0.0.0 - 7.0.0.0) <2AD9FA1A-2B3A-354C-A7B1-A1AFB52CD663> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvauni ttesting
           0x10442c000 -        0x104443ff7 +com.adobe.dvatexteditor.framework (7.0.0.0 - 7.0.0.0) <AFD767BC-90DE-3DB6-BC9E-62CBF541B5C5> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/dvatexteditor.framework/Versions/A/dvatext editor
           0x104480000 -        0x1045b9ff7 +com.adobe.scintilla.framework (7.0.0.0 - 7.0.0.0) <ECEB9E27-C9CF-37FB-87B7-D8FDD02D19AD> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/scintilla.framework/Versions/A/scintilla
           0x104652000 -        0x104982fff +com.adobe.dvaadameve.framework (7.0.0.0 - 7.0.0.0) <2FFFB8F7-CC59-379E-8A62-068543DA5D09> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadameve
           0x105195000 -        0x1051a8ff7 +com.adobe.boost_filesystem.framework (7.0.0.0 - 7.0.0.0) <49D71713-D398-3B5E-B38F-401F14C8B5BE> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boos t_filesystem
           0x1051c6000 -        0x105263ff7 +com.adobe.boost_regex.framework (7.0.0.0 - 7.0.0.0) <DF292CC1-1EC2-347B-B4EE-D05A064DA7E1> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_reg ex
           0x1052fb000 -        0x105322ff7 +com.adobe.mfcdata.framework (7.0.0.0 - 7.0.0.0) <B34ACE9B-B44F-3AA4-AD91-7E0412A3879B> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/mfcdata.framework/Versions/A/mfcdata
           0x10536e000 -        0x1062f1ff7 +com.adobe.psl (AdobePSL 14.0.0.30879 - 14.0.0.30879) <2BFB26EE-7F85-368F-9108-4F20FD6DF3FB> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
           0x1064b2000 -        0x10667bff7 +com.adobe.owl (AdobeOwl version 5.0.13 - 5.0.13) <E9BEFE93-8AB5-3EF9-B59E-69208015C7FA> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
           0x1066be000 -        0x106750fff +com.adobe.flashplayercore.framework (7.0.0.0 - 7.0.0.0) <7841BB7D-9739-3F31-A15B-D5BBB74D039F> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/flashplayercore.framework/Versions/A/flash playercore
           0x1067b4000 -        0x10698bfff +com.adobe.AFlamingo (AFlamingo 2.4.104.30551 - 2.4.104.30551) <0CFE6F29-B675-3D00-8A19-D204AE5B5AE4> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/aflamingo.framework/Versions/A/aflamingo
           0x1069af000 -        0x1069c2ff7 +com.adobe.ahclientframework (1.8.0.31 - 1.8.0.31) <58BB943C-98EC-3812-AAAB-74F66630D1D4> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
           0x1069cc000 -        0x1069e0fff +com.adobe.AdobeSFL (AdobeSFL 1.1.0.30369 - 1.1.0.30369) <E345428A-1893-3428-8DE9-2C61895AC1DA> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/AdobeSFL.framework/Versions/A/AdobeSFL
           0x1069e8000 -        0x106a96fff +com.adobe.cloudsync.framework (7.0.0.0 - 7.0.0.0) <D68CE73A-046F-3295-8792-A0E9E3EE0DA6> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/cloudsync.framework/Versions/A/cloudsync
           0x106bfa000 -        0x106c3fff7 +com.adobe.pip (7.0.0.1768) <F022E031-1429-354F-B718-70F001B342EF> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/AdobePIP.framework/Versions/A/AdobePIP
           0x106c4b000 -        0x106d3cfff +com.adobe.amtlib (7.0.0.163 - 7.0.0.163) <8DE80DCF-E7B0-3E7C-9687-997E100D2EAA> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
           0x106d4f000 -        0x1073ccfcf +com.adobe.PlugPlug (4.0.0.172 - 4.0.0.172) <1B15941F-D885-3AC5-880F-D513DA868B00> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
           0x1079a3000 -        0x107ae7fff +com.adobe.ACE (AdobeACE 2.20.02.30665 - 2.20.02.30665) <73C9699B-5EDC-3FDC-82FF-738C99AA840F> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
           0x107afa000 -        0x1080a8fff +com.adobe.AGM (AdobeAGM 4.30.18.30665 - 4.30.18.30665) <1D87B632-04DC-34B7-9803-43062E4CF2F1> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
           0x108142000 -        0x10815ffff +com.adobe.BIB (AdobeBIB 1.2.03.30665 - 1.2.03.30665) <A69D3AA0-9248-3B77-991B-89B2B7FE46BB> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
           0x108167000 -        0x10818dfff +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <FA20BCA0-05BF-35ED-95B7-5775B8310D12> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBI BUtils
           0x108195000 -        0x1084a5ff7 +com.adobe.CoolType (AdobeCoolType 5.13.00.30665 - 5.13.00.30665) <BBF1FCF6-523A-3E24-967A-10EA909DF89B> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCo olType
           0x1084ed000 -        0x108529fff +com.adobe.ARE (AdobeARE 1.5.02.30665 - 1.5.02.30665) <995E1B5D-578A-392C-B129-63436A6E7621> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
           0x108531000 -        0x108635fff +com.adobe.PDFPort (AdobePDFPort 2.1.0.30665 - 2.1.0.30665) <46896FB3-8FDB-3554-B4F6-013BB944D5EB> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/AdobePDFPort.framework/Versions/A/AdobePDF Port
           0x108648000 -        0x108be1fff +com.adobe.MPS (AdobeMPS 5.8.1.30604 - 5.8.1.30604) <70CBC6A8-2740-37AB-964E-484096A1BF8A> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
           0x108c5e000 -        0x1093c9fff +com.adobe.PDFL (PROD_MAJOR.PROD_MINOR.PROD_STEP - 10.0.1.30505) <38762F4D-B5C5-3FD4-AFFE-5D1195FB76FC> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/AdobePDFL
           0x109481000 -        0x10972bfef +libxerces-c-3.1.dylib (0) <4B8CA11E-F109-5587-49E3-9BDEE767CD82> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/libxerces-c-3.1.dylib
           0x1099ce000 -        0x1099faff7 +libtbb.dylib (0) <64B7013E-D548-3F7B-A2FB-28B7B932275C> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/libtbb.dylib
           0x109a15000 -        0x109a34fe7 +libtbbmalloc.dylib (0) <6887ED68-67ED-3748-82DA-B39A3EB210BB> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/libtbbmalloc.dylib
           0x109a59000 -        0x109a7dfff +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.8.0.30807 - 3.8.0.30807) <16FF5E16-19E0-3CE1-A68E-27567234429F> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/ AdobeAXE8SharedExpat
           0x109aa1000 -        0x109bcffff +com.winsoft.wrservices (WRServices 7.0.0 - 7.0.0) <0853A41B-A14A-37B7-B27F-457F87865EAD> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
           0x109c2d000 -        0x109ce6ff7 +com.adobe.JP2K (1.2.2 - 1.2.2.29712) <869F46FB-FF39-39CA-B1E3-A13035A48B49> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
           0x109d30000 -        0x109d9dfff +com.adobe.AdobeXMPCore (Adobe XMP Core 5.5 -c 14 - 79.151481) <BCDB9366-EDB3-3FEA-854D-3D2C72D48781> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
           0x109dd0000 -        0x109dd5fff  com.apple.agl (3.2.1 - AGL-3.2.1) <F3FD497C-AEB8-35CB-92D4-1669B941435F> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
           0x109ddc000 -        0x109de0ff7 +com.adobe.ape.shim (3.4.0.29366 - 3.4.0.29366) <B9447EE8-6F91-9E85-C163-96600BF70764> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
           0x109de7000 -        0x109e88fff +com.adobe.ICUConverter (4.0 - 3.61) <46764474-111C-3B13-AF62-002B71877405> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/libicu cnv.40.0.dylib
           0x109eb1000 -        0x10abf6fff +com.adobe.ICUData (4.0 - 3.61) <01D90725-4B10-312C-9546-9C0CCCA1B7BB> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/ICUData.framework/Versions/4.0/libicudata. 40.0.dylib
           0x10acbb000 -        0x10acbdff7  com.apple.textencoding.unicode (2.5 - 2.5) <0518078E-C652-3CFC-A3FB-903C600CE831> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
           0x10fb8f000 -        0x10fbfeff7 +com.adobe.adobe_caps (adobe_caps 7.0.0.21 - 7.0.0.21) <CE3C6356-9EE2-3B88-8261-8612A0743F56> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/adobe_caps.framework/adobe_caps
           0x111620000 -        0x11164cfff +ServiceManager-Launcher.dylib (55) <D5A4D905-A054-3E22-A284-3519895C201B> /Library/Application Support/Adobe/*/ServiceManager-Launcher.dylib
           0x111667000 -        0x11166cfff  com.apple.audio.AppleHDAHALPlugIn (2.3.7 - 2.3.7fc4) <586F677E-D0F8-33B2-B6ED-41ED81C9EED9> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHAL PlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
           0x1116de000 -        0x1116fffff  libKoreanConverter.dylib (61) <7A601BB8-19DF-3DDC-9C50-3A798290F377> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
           0x1117c6000 -        0x1117d5ff7  libSimplifiedChineseConverter.dylib (61) <A2B475FF-667F-3B7B-A6E9-8768347F2BD6> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter. dylib
           0x1118ac000 -        0x1118beff7  libTraditionalChineseConverter.dylib (61) <DDAFF75C-0714-34F4-818F-8B439AC7BBCA> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter .dylib
           0x1118c5000 -        0x1118effff +com.adobe.FLAirAndroidExt.framework (13.0.0.0 - 13.0.0.0) <93C52CE1-23D0-35F8-9991-CD58CF6EF1F1> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Common/Configuration/External Libraries/FLAirAndroidExt.bundle/Contents/MacOS/FLAirAndroidExt
           0x11199c000 -        0x1119b8ff7  libJapaneseConverter.dylib (61) <D0F762C2-5372-3AA2-BBA4-066B8E4B1F8E> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
           0x111d6f000 -        0x111da2ff7 +com.adobe.FLAirDesktopExt.framework (13.0.0.0 - 13.0.0.0) <D60E93E6-210F-3B11-93E2-17031A8C620E> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Common/Configuration/External Libraries/FLAirDesktopExt.bundle/Contents/MacOS/FLAirDesktopExt
           0x111dd7000 -        0x111e1eff7 +com.adobe.FLBridge.framework (13.0.0.0 - 13.0.0.0) <1EBA42DC-8249-30AF-A978-393746511053> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Common/Configuration/External Libraries/FLBridge.bundle/Contents/MacOS/FLBridge
           0x111e98000 -        0x111eacff7 +com.adobe.FLfile.framework (13.0.0.0 - 13.0.0.0) <27D4EF74-C593-3FF5-B475-DAC49F251012> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Common/Configuration/External Libraries/FLfile.bundle/Contents/MacOS/FLfile
           0x111ee0000 -        0x112a98fef +com.adobe.FLCreateJS.framework (1.2.0.0 - 1.2.0.0) <C206DCB7-753F-3EDA-B11D-286FEAC1B766> /Users/USER/Library/Application Support/Adobe/*/FLCreateJS.bundle/Contents/MacOS/FLCreateJS
           0x11340b000 -        0x113564ff7 +com.adobe.linguistic.LinguisticManager (7.0.0 - 19061) <F6095811-7D5F-3E06-A664-1EB9FBF8C761> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/Adobe Linguistic
           0x1135b2000 -        0x1135bcfff +libjli.dylib (1) <AE015A48-6B22-38C9-9D55-DD0C2C136E76> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/jre/jre1.7.0_10.jre/Contents/Home/lib/jli/libjli.dyli b
           0x113880000 -        0x1138befff +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 7.0.1.102 - 7.0.1.102) <75ADE364-1107-3DA7-84A2-26C6874EB881> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/ UpdaterNotifications
           0x118025000 -        0x1192c0fcf +com.macromedia.Flash Player.authplaylib (11.6.602.180 - 11.6.602.180) <97DCF07A-8751-6351-DCF0-2BF851175FE0> /Applications/Adobe Flash CC/Adobe Flash CC.app/Contents/Common/Configuration/AuthPlayLib.bundle/Contents/MacO S/AuthPlayLib
        0x7fff6a3a0000 -     0x7fff6a3d493f  dyld (210.2.3) <36CAA36E-72BC-3E48-96D9-B96A2DF77730> /usr/lib/dyld
        0x7fff8b938000 -     0x7fff8b952fff  com.apple.CoreMediaAuthoring (2.1 - 914) <23F2B9D0-7B73-3C42-8EDC-8ADBF9C7B8C2> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versio ns/A/CoreMediaAuthoring
        0x7fff8b99d000 -     0x7fff8bc38ff7  com.apple.JavaScriptCore (8536 - 8536.30) <FE3C5ADD-43D3-33C9-9150-8DCEFDA218E2> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaSc riptCore
        0x7fff8bc63000 -     0x7fff8c40afff  com.apple.CoreAUC (6.16.13 - 6.16.13) <8CBFBC9C-0773-3DEB-AF99-989008CB2B36> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAU C
        0x7fff8c40b000 -     0x7fff8c416ff7  com.apple.bsd.ServiceManagement (2.0 - 2.0) <C12962D5-85FB-349E-AA56-64F4F487F219> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/Ser viceManagement
        0x7fff8c417000 -     0x7fff8c41dfff  libmacho.dylib (829) <BF332AD9-E89F-387E-92A4-6E1AB74BD4D9> /usr/lib/system/libmacho.dylib
        0x7fff8c428000 -     0x7fff8c42cfff  libCoreVMClient.dylib (32.3) <AD8391D9-56DD-3A78-A294-6A30E6ECE1A2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libC oreVMClient.dylib
        0x7fff8c42d000 -     0x7fff8c45bff7  libsystem_m.dylib (3022.6) <B434BE5C-25AB-3EBD-BAA7-5304B34E3441> /usr/lib/system/libsystem_m.dylib
        0x7fff8c53c000 -     0x7fff8c53eff7  com.apple.print.framework.Print (8.0 - 258) <34666CC2-B86D-3313-B3B6-A9977AD593DA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Pri nt.framework/Versions/A/Print
        0x7fff8c53f000 -     0x7fff8c634fff  libiconv.2.dylib (34) <FEE8B996-EB44-37FA-B96E-D379664DEFE1> /usr/lib/libiconv.2.dylib
        0x7fff8c660000 -     0x7fff8c662fff  libquarantine.dylib (52.1) <143B726E-DF47-37A8-90AA-F059CFD1A2E4> /usr/lib/system/libquarantine.dylib
        0x7fff8c663000 -     0x7fff8c6bfff7  com.apple.Symbolication (1.3 - 93) <97F3B1D2-D81D-3F37-87B3-B9A686124CF5> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/ Symbolication
        0x7fff8c6c0000 -     0x7fff8c6e2ff7  libxpc.dylib (140.43) <70BC645B-6952-3264-930C-C835010CCEF9> /usr/lib/system/libxpc.dylib
        0x7fff8c6f2000 -     0x7fff8c80cfff  com.apple.coreavchd (5.6.0 - 5600.4.16) <0CF2ABE5-B088-3B5D-9C04-47AE708ADAE3> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/Core AVCHD
        0x7fff8c80d000 -     0x7fff8cc49fef  com.apple.VideoToolbox (1.0 - 926.104) <9231E12F-3D46-3F3D-B24F-6E16127E5909> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToo lbox
        0x7fff8cc4a000 -     0x7fff8cc53ff7  com.apple.CommerceCore (1.0 - 26.1) <40A129A8-4E5D-3C7A-B299-8CB203C4C65D> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Fr ameworks/CommerceCore.framework/Versions/A/CommerceCore
        0x7fff8cc54000 -     0x7fff8cc98fff  libcups.2.dylib (327.6) <9C01D012-6F4C-3B69-B614-1B408B0ED4E3> /usr/lib/libcups.2.dylib
        0x7fff8cc99000 -     0x7fff8cd34fff  com.apple.CoreSymbolication (3.0 - 117) <C304FDB8-2FF7-34BC-858A-2B96C2B039D5> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Version s/A/CoreSymbolication
        0x7fff8cd35000 -     0x7fff8cd94fff  com.apple.AE (645.6 - 645.6) <44F403C1-660A-3543-AB9C-3902E02F936F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/AE.framework/Versions/A/AE
        0x7fff8cd95000 -     0x7fff8cda2fff  libbz2.1.0.dylib (29) <CE9785E8-B535-3504-B392-82F0064D9AF2> /usr/lib/libbz2.1.0.dylib
        0x7fff8cda3000 -     0x7fff8cdf4ff7  com.apple.SystemConfiguration (1.12.2 - 1.12.2) <A4341BBD-A330-3A57-8891-E9C1A286A72D> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/S ystemConfiguration
        0x7fff8cdf5000 -     0x7fff8cea8ff7  com.apple.PDFKit (2.8.4 - 2.8.4) <BD6E8774-1C8B-3CD1-B5FA-7352B2173068> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDF Kit.framework/Versions/A/PDFKit
        0x7fff8cf52000 -     0x7fff8cf56fff  libCGXType.A.dylib (332) <17C8DD17-B3CB-3633-B252-C368AE51204C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dyl ib
        0x7fff8cf5a000 -     0x7fff8cf5cfff  libCVMSPluginSupport.dylib (8.9.2) <EF1192AC-3357-3A0B-BFAF-6594D7737892> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libC VMSPluginSupport.dylib
        0x7fff8cf5d000 -     0x7fff8cf85fff  libJPEG.dylib (850) <DC750E1E-BD07-339B-A4A6-D86BFE969F68> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/lib JPEG.dylib
        0x7fff8cfaf000 -     0x7fff8cfb1fff  com.apple.securityhi (4.0 - 55002) <26E6D477-EF61-351F-BA8C-67824AA231C6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Sec urityHI.framework/Versions/A/SecurityHI
        0x7fff8cfb2000 -     0x7fff8cffffff  com.apple.CoreMediaIO (308.0 - 4155.4) <B563579E-469D-39A1-975C-F4EDD419602E> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMedia IO
        0x7fff8d083000 -     0x7fff8d0affff  com.apple.framework.Apple80211 (8.4 - 840.22.1) <7CFDDBBB-87DF-3CB5-AB69-A77D73F26239> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/App le80211
        0x7fff8d0b0000 -     0x7fff8d0e5ff7  libTrueTypeScaler.dylib (84.6) <635BEEBD-7969-3083-8B1A-D49E9DA81517> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
        0x7fff8d0eb000 -     0x7fff8d102fff  com.apple.CFOpenDirectory (10.8 - 151.10) <10F41DA4-AD54-3F52-B898-588D9A117171> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Framewo rks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
        0x7fff8d103000 -     0x7fff8d1a9ff7  com.apple.CoreServices.OSServices (557.6 - 557.6) <1BDB5456-0CE9-301C-99C1-8EFD0D2BFCCD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/OSServices.framework/Versions/A/OSServices
        0x7fff8d1aa000 -     0x7fff8d204fff  com.apple.print.framework.PrintCore (8.3 - 387.2) <5BA0CBED-4D80-386A-9646-F835C9805B71> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/PrintCore.framework/Versions/A/PrintCore
        0x7fff8d34f000 -     0x7fff8d34ffff  com.apple.Carbon (154 - 155) <1B2846B1-384E-3D1C-8999-201215723349> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
        0x7fff8d350000 -     0x7fff8d365fff  com.apple.ImageCapture (8.0 - 8.0) <17A45CE6-7DA3-36A5-B7EF-72BC136981AE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ima geCapture.framework/Versions/A/ImageCapture
        0x7fff8d3c1000 -     0x7fff8d4ccfff  libFontParser.dylib (84.6) <96C42E49-79A6-3475-B5E4-6A782599A6DA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
        0x7fff8d4da000 -     0x7fff8d5f292f  libobjc.A.dylib (532.2) <90D31928-F48D-3E37-874F-220A51FD9E37> /usr/lib/libobjc.A.dylib
        0x7fff8d8b8000 -     0x7fff8d8f5fef  libGLImage.dylib (8.9.2) <C38649ED-E1C9-315E-9953-F33E8C6A3C89> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LImage.dylib
        0x7fff8d8f9000 -     0x7fff8d90cff7  com.apple.LangAnalysis (1.7.0 - 1.7.0) <2F2694E9-A7BC-33C7-B4CF-8EC907DF0FEB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/LangAnalysis.framework/Versions/A/LangAnalysis
        0x7fff8d90d000 -     0x7fff8d90dffd  com.apple.audio.units.AudioUnit (1.9 - 1.9) <EC55FB59-2443-3F08-9142-7BCC93C76E4E> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
        0x7fff8d90e000 -     0x7fff8d90fff7  libremovefile.dylib (23.2) <6763BC8E-18B8-3AD9-8FFA-B43713A7264F> /usr/lib/system/libremovefile.dylib
        0x7fff8d9df000 -     0x7fff8d9edfff  com.apple.Librarian (1.1 - 1) <5AC28666-7642-395F-A923-C6F8A274BBBD> /System/Library/PrivateFrameworks/Librarian.framework/Versions/A/Libr arian
        0x7fff8d9f6000 -     0x7fff8da22ff7  libRIP.A.dylib (332) <D26BC320-B415-3C4D-B57F-D525FC361BB2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
        0x7fff8da23000 -     0x7fff8da42ff7  libresolv.9.dylib (51) <0882DC2D-A892-31FF-AD8C-0BB518C48B23> /usr/lib/libresolv.9.dylib
        0x7fff8da5c000 -     0x7fff8daa6ff7  libGLU.dylib (8.9.2) <1B5511FF-1064-3004-A245-972CE5687D37> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LU.dylib
        0x7fff8daa7000 -     0x7fff8dab6fff  com.apple.opengl (1.8.9 - 1.8.9) <6FD163A7-16CC-3D1F-B4B5-B0FDC4ADBF79> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
        0x7fff8dac5000 -     0x7fff8db2dff7  libc++.1.dylib (65.1) <20E31B90-19B9-3C2A-A9EB-474E08F9FE05> /usr/lib/libc++.1.dylib
        0x7fff8db2e000 -     0x7fff8dbaffff  com.apple.Metadata (10.7.0 - 707.11) <2DD25313-420D-351A-90F1-300E95C970CA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/Metadata.framework/Versions/A/Metadata
        0x7fff8dbe9000 -     0x7fff8dc28ff7  com.apple.QD (3.42.1 - 285.1) <77A20C25-EBB5-341C-A05C-5D458B97AD5C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/QD.framework/Versions/A/QD
        0x7fff8dc29000 -     0x7fff8ddaffff  libBLAS.dylib (1073.4) <C102C0F6-8CB6-3B49-BA6B-2EB61F0B2784> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libBLAS.dylib
        0x7fff8ddb0000 -     0x7fff8ddb5fff  com.apple.OpenDirectory (10.8 - 151.10) <CF44120B-9B01-32DD-852E-C9C0E1243FC0> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDir ectory
        0x7fff8ddb6000 -     0x7fff8ddf0ff7  com.apple.GSS (3.0 - 2.0) <970CAE00-1437-3F4E-B677-0FDB3714C08C> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
        0x7fff8ddf5000 -     0x7fff8ddfcfff  com.apple.NetFS (5.0 - 4.0) <82E24B9A-7742-3DA3-9E99-ED267D98C05E> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
        0x7fff8df41000 -     0x7fff8df98ff7  com.apple.ScalableUserInterface (1.0 - 1) <F1D43DFB-1796-361B-AD4B-39F1EED3BE19> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks /ScalableUserInterface.framework/Versions/A/ScalableUserInterface
        0x7fff8df99000 -     0x7fff8dfbbff7  com.apple.Kerberos (2.0 - 1) <C49B8820-34ED-39D7-A407-A3E854153556> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
        0x7fff8e00e000 -     0x7fff8e00efff  com.apple.ApplicationServices (45 - 45) <A3ABF20B-ED3A-32B5-830E-B37831A45A80> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/A pplicationServices
        0x7fff8e04a000 -     0x7fff8e075fff  libxslt.1.dylib (11.3) <441776B8-9130-3893-956F-39C85FFA644F> /usr/lib/libxslt.1.dylib
        0x7fff8e5b3000 -     0x7fff8e5b5fff  com.apple.TrustEvaluationAgent (2.0 - 23) <A97D348B-32BF-3E52-8DF2-59BFAD21E1A3> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Vers ions/A/TrustEvaluationAgent
        0x7fff8e5b6000 -     0x7fff8e5cafff  com.apple.speech.synthesis.framework (4.1.12 - 4.1.12) <94EDF2AB-809C-3D15-BED5-7AD45B2A7C16> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
        0x7fff8e5cb000 -     0x7fff8e5cbfff  com.apple.quartzframework (1.5 - 1.5) <6403C982-0D45-37EE-A0F0-0EF8BCFEF440> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
        0x7fff8e647000 -     0x7fff8e87cff7  com.apple.CoreData (106.1 - 407.7) <24E0A6B4-9ECA-3D12-B26A-72B9DCF09768> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
        0x7fff8e87d000 -     0x7fff8e87dfff  com.apple.CoreServices (57 - 57) <9DD44CB0-C644-35C3-8F57-0B41B3EC147D> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServ ices
        0x7fff8e87e000 -     0x7fff8e900ff7  com.apple.Heimdal (3.0 - 2.0) <C94B0C6C-1320-35A1-8143-FE252E7B2A08> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimda l
        0x7fff8eab3000 -     0x7fff8eae9fff  libsystem_info.dylib (406.17) <4FFCA242-7F04-365F-87A6-D4EFB89503C1> /usr/lib/system/libsystem_info.dylib
        0x7fff8eaf8000 -     0x7fff8eafffff  libGFXShared.dylib (8.9.2) <398F8D57-EC82-3E13-AC8E-470BE19237D7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG FXShared.dylib
        0x7fff8eb01000 -     0x7fff8ee18ff7  com.apple.CoreServices.CarbonCore (1037.6 - 1037.6) <1E567A52-677F-3168-979F-5FBB0818D52B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CarbonCore.framework/Versions/A/CarbonCore
        0x7fff8eec9000 -     0x7fff8eecfff7  libunwind.dylib (35.1) <21703D36-2DAB-3D8B-8442-EAAB23C060D3> /usr/lib/system/libunwind.dylib
        0x7fff8eee2000 -     0x7fff8ef01ff7  com.apple.ChunkingLibrary (2.0 - 133.3) <8BEC9AFB-DCAA-37E8-A5AB-24422B234ECF> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/ A/ChunkingLibrary
        0x7fff8f01c000 -     0x7fff8f2cbfff  com.apple.imageKit (2.2 - 673) <5F0504DA-7CE9-3D97-B2B5-3C5839AEBF1F> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Ima geKit.framework/Versions/A/ImageKit
        0x7fff8f458000 -     0x7fff8f46bff7  libbsm.0.dylib (32) <F497D3CE-40D9-3551-84B4-3D5E39600737> /usr/lib/libbsm.0.dylib
        0x7fff8f46c000 -     0x7fff8f6d9ff7  com.apple.RawCamera.bundle (4.07 - 696) <CCB97D78-309C-3CD9-B499-81192069A333> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamer a
        0x7fff8f6eb000 -     0x7fff8f701fff  com.apple.MultitouchSupport.framework (235.29 - 235.29) <617EC8F1-BCE7-3553-86DD-F857866E1257> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Version s/A/MultitouchSupport
        0x7fff8f70b000 -     0x7fff8f8f5ff7  com.apple.CoreFoundation (6.8 - 744.19) <0F7403CA-2CB8-3D0A-992B-679701DF27CA> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFo undation
        0x7fff8f8fe000 -     0x7fff8f904fff  com.apple.DiskArbitration (2.5.2 - 2.5.2) <C713A35A-360E-36CE-AC0A-25C86A3F50CA> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskA rbitration
        0x7fff8f905000 -     0x7fff90532fff  com.apple.AppKit (6.8 - 1187.39) <199962F0-B06B-3666-8FD5-5C90374BA16A> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
        0x7fff90533000 -     0x7fff90553fff  libPng.dylib (850) <203C43BF-FAD3-3CCB-81D5-F2770E36338B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/lib Png.dylib
        0x7fff905ed000 -     0x7fff905f1ff7  com.apple.CommonPanels (1.2.5 - 94) <AAC003DE-2D6E-38B7-B66B-1F3DA91E7245> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Com monPanels.framework/Versions/A/CommonPanels
        0x7fff90642000 -     0x7fff9069bff7  com.apple.ImageCaptureCore (5.0.4 - 5.0.4) <84F003C2-5758-3D0A-8644-F3A0BA4F22FC> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/Imag eCaptureCore
        0x7fff9069c000 -     0x7fff9074dfff  com.apple.LaunchServices (539.9 - 539.9) <07FC6766-778E-3479-8F28-D2C9917E1DD1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/LaunchServices.framework/Versions/A/LaunchServices
        0x7fff9074e000 -     0x7fff9074ffff  libDiagnosticMessagesClient.dylib (8) <8548E0DC-0D2F-30B6-B045-FE8A038E76D8> /usr/lib/libDiagnosticMessagesClient.dylib
        0x7fff907d3000 -     0x7fff90a2eff7  com.apple.QuartzComposer (5.1 - 284) <D9CDC9ED-9F03-30F0-80DF-BA189A054AC9> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qua rtzComposer.framework/Versions/A/QuartzComposer
        0x7fff90a2f000 -     0x7fff90a34fff  libcompiler_rt.dylib (30) <08F8731D-5961-39F1-AD00-4590321D24A9> /usr/lib/system/libcompiler_rt.dylib
        0x7fff90a35000 -     0x7fff90a38fff  libRadiance.dylib (850) <62E3F7FB-03E3-3937-A857-AF57A75EAF09> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/lib Radiance.dylib
        0x7fff90a39000 -     0x7fff90b36ff7  libxml2.2.dylib (22.3) <47B09CB2-C636-3024-8B55-6040F7829B4C> /usr/lib/libxml2.2.dylib
        0x7fff90b3c000 -     0x7fff90bbbff7  com.apple.securityfoundation (6.0 - 55115.4) <8676E0DF-295F-3690-BDAA-6C9C1D210B88> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/Se curityFoundation
        0x7fff90bbc000 -     0x7fff90c79ff7  com.apple.ColorSync (4.8.0 - 4.8.0) <6CE333AE-EDDB-3768-9598-9DB38041DC55> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ColorSync.framework/Versions/A/ColorSync
        0x7fff90c7f000 -     0x7fff90c8afff  libsystem_notify.dylib (98.5) <C49275CC-835A-3207-AFBA-8C01374927B6> /usr/lib/system/libsystem_notify.dylib
        0x7fff90c8b000 -     0x7fff90ca8ff7  com.apple.openscripting (1.3.6 - 148.3) <C008F56A-1E01-3D4C-A9AF-97799D0FAE69> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ope nScripting.framework/Versions/A/OpenScripting
        0x7fff90d62000 -     0x7fff90d63ff7  libSystem.B.dylib (169.3) <9089D72D-E714-31E1-80C8-698A8E8B05AD> /usr/lib/libSystem.B.dylib
        0x7fff90d64000 -     0x7fff90d79ff7  libdispatch.dylib (228.23) <D26996BF-FC57-39EB-8829-F63585561E09> /usr/lib/system/libdispatch.dylib
        0x7fff91f8c000 -     0x7fff92026fff  libvMisc.dylib (380.6) <714336EA-1C0E-3735-B31C-19DFDAAF6221> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvMisc.dylib
        0x7fff92027000 -     0x7fff92140fff  com.apple.ImageIO.framework (3.2.1 - 850) <C3FFCEEB-AA0C-314B-9E94-7005EE48A403> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
        0x7fff92141000 -     0x7fff92412ff7  com.apple.security (7.0 - 55179.13) <F428E306-C407-3B55-BA82-E58755E8A76F> /System/Library/Frameworks/Security.framework/Versions/A/Security
        0x7fff92483000 -     0x7fff92521ff7  com.apple.ink.framework (10.8.2 - 150) <84B9825C-3822-375F-BE58-A753444FBDE2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink .framework/Versions/A/Ink
        0x7fff92522000 -     0x7fff92525fff  com.apple.help (1.3.2 - 42) <343904FE-3022-3573-97D6-5FE17F8643BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Hel p.framework/Versions/A/Help
        0x7fff925b6000 -     0x7fff92605ff7  libFontRegistry.dylib (100) <2E03D7DA-9B8F-31BB-8FB5-3D3B6272127F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
        0x7fff92606000 -     0x7fff92610fff  com.apple.speech.recognition.framework (4.1.5 - 4.1.5) <D803919C-3102-3515-A178-61E9C86C46A1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Spe echRecognition.framework/Versions/A/SpeechRecognition
        0x7fff9266f000 -     0x7fff92749fff  com.apple.backup.framework (1.4.3 - 1.4.3) <6B65C44C-7777-3331-AD9D-438D10AAC777> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
        0x7fff9274a000 -     0x7fff92752fff  liblaunch.dylib (442.26.2) <2F71CAF8-6524-329E-AC56-C506658B4C0C> /usr/lib/system/liblaunch.dylib
        0x7fff927f5000 -     0x7fff927fdff7  libsystem_dnssd.dylib (379.38.1) <BDCB8566-0189-34C0-9634-35ABD3EFE25B> /usr/lib/system/libsystem_dnssd.dylib
        0x7fff927fe000 -     0x7fff9280afff  libCSync.A.dylib (332) <47466CF6-EB5C-3312-9E24-178F4410A92B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
        0x7fff9280f000 -     0x7fff9290dfff  com.apple.QuickLookUIFramework (4.0 - 555.5) <EE02B332-20F3-3226-A022-D71B808E1CC4> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qui ckLookUI.framework/Versions/A/QuickLookUI
        0x7fff92ac0000 -     0x7fff92ac1ff7  libsystem_sandbox.dylib (220.3) <B739DA63-B675-387A-AD84-412A651143C0> /usr/lib/system/libsystem_sandbox.dylib
        0x7fff92ac2000 -     0x7fff92ac6fff  com.apple.IOSurface (86.0.4 - 86.0.4) <26F01CD4-B76B-37A3-989D-66E8140542B3> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
        0x7fff92ac7000 -     0x7fff92b12fff  com.apple.framework.CoreWLAN (3.3 - 330.15) <047FA8CB-7447-3171-9518-6C88DA71F20E> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
        0x7fff92b13000 -     0x7fff92b13fff  com.apple.Accelerate.vecLib (3.8 - vecLib 3.8) <B5A18EE8-DF81-38DD-ACAF-7076B2A26225> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/vecLib
        0x7fff92b14000 -     0x7fff92e44fff  com.apple.HIToolbox (2.0 - 626.1) <656D08C2-9068-3532-ABDD-32EC5057CCB2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIT oolbox.framework/Versions/A/HIToolbox
        0x7fff92eb9000 -     0x7fff92f39ff7  com.apple.ApplicationServices.ATS (332 - 341.1) <BD83B039-AB25-3E3E-9975-A67DAE66988B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/ATS
        0x7fff92f3a000 -     0x7fff92fceff7  com.apple.CorePDF (2.2 - 2.2) <F17D7D37-4190-38E2-9F43-DD4F87792390> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePD F
        0x7fff92fcf000 -     0x7fff92ff0ff7  libCRFSuite.dylib (33) <736ABE58-8DED-3289-A042-C25AF7AE5B23> /usr/lib/libCRFSuite.dylib
        0x7fff93024000 -     0x7fff93029fff  libcache.dylib (57) <65187C6E-3FBF-3EB8-A1AA-389445E2984D> /usr/lib/system/libcache.dylib
        0x7fff9302c000 -     0x7fff93077fff  com.apple.CoreMedia (1.0 - 926.104) <31EAF297-9C42-3D6F-A8A1-CDAB94A26113> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
        0x7fff93078000 -     0x7fff930e5ff7  com.apple.datadetectorscore (4.1 - 269.3) <5775F0DB-87D6-310D-8B03-E2AD729EFB28> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Version s/A/DataDetectorsCore
        0x7fff930e6000 -     0x7fff93114fff  com.apple.CoreServicesInternal (154.3 - 154.3) <F4E118E4-E327-3314-83D7-EA20B1717ED0> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Vers ions/A/CoreServicesInternal
        0x7fff93115000 -     0x7fff93126ff7  libsasl2.2.dylib (166) <649CAE0E-8FFE-3C60-A849-BE6300E4B726> /usr/lib/libsasl2.2.dylib
        0x7fff93127000 -     0x7fff93142ff7  libsystem_kernel.dylib (2050.24.15) <A9F97289-7985-31D6-AF89-151830684461> /usr/lib/system/libsystem_kernel.dylib
        0x7fff93143000 -     0x7fff931b1ff7  com.apple.framework.IOKit (2.0.1 - 755.24.1) <04BFB138-8AF4-310A-8E8C-045D8A239654> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
        0x7fff931b2000 -     0x7fff931c0fff  libcommonCrypto.dylib (60027) <BAAFE0C9-BB86-3CA7-88C0-E3CBA98DA06F> /usr/lib/system/libcommonCrypto.dylib
        0x7fff9353d000 -     0x7fff936ebfff  com.apple.QuartzCore (1.8 - 304.3) <F450F2DE-2F24-3557-98B6-310E05DAC17F> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
        0x7fff938d9000 -     0x7fff938d9fff  com.apple.vecLib (3.8 - vecLib 3.8) <794317C7-4E38-338A-A874-5E18001C8503> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
        0x7fff938da000 -     0x7fff938e9ff7  libxar.1.dylib (105) <370ED355-E516-311E-BAFD-D80633A84BE1> /usr/lib/libxar.1.dylib
        0x7fff938ea000 -     0x7fff939e7fff  libsqlite3.dylib (138.1) <ADE9CB98-D77D-300C-A32A-556B7440769F> /usr/lib/libsqlite3.dylib
        0x7fff939e8000 -     0x7fff939e8fff  com.apple.Cocoa (6.7 - 19) <1F77945C-F37A-3171-B22E-F7AB0FCBB4D4> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
        0x7fff939e9000 -     0x7fff939e9fff  libOpenScriptingUtil.dylib (148.3) <F8681222-0969-3B10-8BCE-C55A4B9C520C> /usr/lib/libOpenScriptingUtil.dylib
        0x7fff93a05000 -     0x7fff93a92ff7  com.apple.SearchKit (1.4.0 - 1.4.0) <C7F43889-F8BF-3CB9-AD66-11AEFCBCEDE7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/SearchKit.framework/Versions/A/SearchKit
        0x7fff93a93000 -     0x7fff93abdff7  com.apple.CoreVideo (1.8 - 99.4) <E5082966-6D81-3973-A05A-38AA5B85F886> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
        0x7fff93aca000 -     0x7fff93b21ff7  com.apple.AppleVAFramework (5.0.19 - 5.0.19) <541A7DBE-F8E4-3023-A3C0-8D5A2A550CFB> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleV A
        0x7fff93b22000 -     0x7fff93b71fff  com.apple.framework.CoreWiFi (1.3 - 130.13) <CCF3D8E3-CD1C-36CD-929A-C9972F833F24> /System/Library/Frameworks/CoreWiFi.framework/Versions/A/CoreWiFi
        0x7fff93b85000 -     0x7fff93fa2fff  FaceCoreLight (2.4.1) <A34C9575-C4C1-31B1-809B-7751070B4E8B> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/ FaceCoreLight
        0x7fff93fa3000 -     0x7fff93fcaff7  com.apple.PerformanceAnalysis (1.16 - 16) <E4888388-F41B-313E-9CBB-5807D077BDA9> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versi ons/A/PerformanceAnalysis
        0x7fff93fcb000 -     0x7fff93fcefff  com.apple.AppleSystemInfo (2.0 - 2) <BC221376-361F-3F85-B284-DC251D3BB442> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/ A/AppleSystemInfo
        0x7fff93fcf000 -     0x7fff93fe6fff  libGL.dylib (8.9.2) <B8E5948D-BCF2-3727-B74E-D74B8EDC82D6> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG L.dylib
        0x7fff93fe7000 -     0x7fff93ff5ff7  libsystem_network.dylib (77.10) <0D99F24E-56FE-380F-B81B-4A4C630EE587> /usr/lib/system/libsystem_network.dylib
        0x7fff93ff6000 -     0x7fff941f6fff  libicucore.A.dylib (491.11.3) <5783D305-04E8-3D17-94F7-1CEAFA975240> /usr/lib/libicucore.A.dylib
        0x7fff941f7000 -     0x7fff94b874af  com.apple.CoreGraphics (1.600.0 - 332) <5AB32E51-9154-3733-B83B-A9A748652847> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/CoreGraphics
        0x7fff94b88000 -     0x7fff94bbfff7  libssl.0.9.8.dylib (47.1) <B7C438BB-79FF-37B3-B8FB-253E5135CBB4> /usr/lib/libssl.0.9.8.dylib
        0x7fff94bc0000 -     0x7fff94bc1fff  libsystem_blocks.dylib (59) <D92DCBC3-541C-37BD-AADE-ACC75A0C59C8> /usr/lib/system/libsystem_blocks.dylib
        0x7fff94bc4000 -     0x7fff94c1afff  com.apple.HIServices (1.20 - 417) <A1129272-FEC8-350B-BA26-5A97F23C413D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/HIServices.framework/Versions/A/HIServices
        0x7fff94fa7000 -     0x7fff94fa7fff  libkeymgr.dylib (25) <CC9E3394-BE16-397F-926B-E579B60EE429> /usr/lib/system/libkeymgr.dylib
        0x7fff94fa8000 -     0x7fff9506dff7  com.apple.coreui (2.0 - 181.1) <83D2C92D-6842-3C9D-9289-39D5B4554C3A> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
        0x7fff9506e000 -     0x7fff95465fff  libLAPACK.dylib (1073.4) <D632EC8B-2BA0-3853-800A-20DA00A1091C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libLAPACK.dylib
        0x7fff95468000 -     0x7fff9570cff7  com.apple.CoreImage (8.4.0 - 1.0.1) <CC6DD22B-FFC6-310B-BE13-2397A02C79EF> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks /CoreImage.framework/Versions/A/CoreImage
        0x7fff9570d000 -     0x7fff957dfff7  com.apple.CoreText (260.0 - 275.16) <5BFC1D67-6A6F-38BC-9D90-9C712684EDAC> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
        0x7fff957e0000 -     0x7fff957e4fff  libpam.2.dylib (20) <C8F45864-5B58-3237-87E1-2C258A1D73B8> /usr/lib/libpam.2.dylib
        0x7fff957e5000 -     0x7fff957e6ff7  libdnsinfo.dylib (453.19) <14202FFB-C3CA-3FCC-94B0-14611BF8692D> /usr/lib/system/libdnsinfo.dylib
        0x7fff957f0000 -     0x7fff957f7fff  libcopyfile.dylib (89) <876573D0-E907-3566-A108-577EAD1B6182> /usr/lib/system/libcopyfile.dylib
        0x7fff95809000 -     0x7fff9580dfff  libGIF.dylib (850) <D4525F87-759C-338C-B283-BB8DE815D3D5> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/lib GIF.dylib
        0x7fff9580e000 -     0x7fff9580ffff  liblangid.dylib (116) <864C409D-D56B-383E-9B44-A435A47F2346> /usr/lib/liblangid.dylib
        0x7fff9582c000 -     0x7fff95874fff  libcurl.4.dylib (69.2) <EBDBF42D-E4A6-3D05-A76B-2817D79D59E2> /usr/lib/libcurl.4.dylib
        0x7fff95875000 -     0x7fff958b8ff7  com.apple.bom (12.0 - 192) <0BF1F2D2-3648-36B7-BE4B-551A0173209B> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
        0x7fff958b9000 -     0x7fff95a54fef  com.apple.vImage (6.0 - 6.0) <FAE13169-295A-33A5-8E6B-7C2CC1407FA7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vImage.framework/Versions/A/vImage
        0x7fff95a55000 -     0x7fff95aaaff7  libTIFF.dylib (850) <EDAF0D99-70AF-3B3F-9EFA-9463C91D0E3C> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/lib TIFF.dylib
        0x7fff95aab000 -     0x7fff95c1cff7  com.apple.QTKit (7.7.1 - 2599.31) <1CBAB8B9-E335-33E3-B442-60105D265CB7> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
        0x7fff95c1d000 -     0x7fff95c49fff  com.apple.quartzfilters (1.8.0 - 1.7.0) <B8DE45D7-1827-3379-A478-1A574A1D11D9> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qua rtzFilters.framework/Versions/A/QuartzFilters
        0x7fff95c4a000 -     0x7fff95c57fff  com.apple.AppleFSCompression (49 - 1.0) <5508344A-2A7E-3122-9562-6F363910A80E> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versio ns/A/AppleFSCompression
        0x7fff95c58000 -     0x7fff95c63fff  com.apple.CommonAuth (3.0 - 2.0) <7A953C1F-8B18-3E46-9BEA-26D9B5B7745D> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/Com monAuth
        0x7fff95c64000 -     0x7fff95dc2fef  com.apple.MediaControlSender (1.7 - 170.20) <853BE89D-49B0-3922-9ED5-DDBDE9A97356> /System/Library/PrivateFrameworks/MediaControlSender.framework/Versio ns/A/MediaControlSender
        0x7fff95e34000 -     0x7fff95e46ff7  libz.1.dylib (43) <2A1551E8-A272-3DE5-B692-955974FE1416> /usr/lib/libz.1.dylib
        0x7fff95e47000 -     0x7fff95f49fff  libJP2.dylib (850) <2E43216C-3A5A-3693-820C-38B360698FA0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/lib JP2.dylib
        0x7fff95f4a000 -     0x7fff95f96ff7  libauto.dylib (185.4) <AD5A4CE7-CB53-313C-9FAE-673303CC2D35> /usr/lib/libauto.dylib
        0x7fff95fdb000 -     0x7fff96150ff7  com.apple.CFNetwork (596.4.3 - 596.4.3) <A57B3308-2F08-3EC3-B4AC-39A3D9F0B9F7> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
        0x7fff96151000 -     0x7fff961b4ff7  com.apple.audio.CoreAudio (4.1.1 - 4.1.1) <9ACD3AED-6C04-3BBB-AB2A-FC253B16D093> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
        0x7fff961b5000 -     0x7fff961ccfff  com.apple.GenerationalStorage (1.1 - 132.3) <FD4A84B3-13A8-3C60-A59E-25A361447A17> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versi ons/A/GenerationalStorage
        0x7fff961f0000 -     0x7fff961f0fff  com.apple.Accelerate (1.8 - Accelerate 1.8) <6AD48543-0864-3D40-80CE-01F184F24B45> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
        0x7fff961f1000 -     0x7fff96212fff  com.apple.Ubiquity (1.2 - 243.15) <C9A7EE77-B637-3676-B667-C0843BBB0409> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiqu ity
        0x7fff96213000 -     0x7fff964caff7  com.apple.MediaToolbox (1.0 - 926.104) <916B1ACC-2623-39FB-9B5A-1B0162F8C468> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToo lbox
        0x7fff967c8000 -     0x7fff96817ff7  libcorecrypto.dylib (106.2) <CE0C29A3-C420-339B-ADAA-52F4683233CC> /usr/lib/system/libcorecrypto.dylib
        0x7fff96818000 -     0x7fff968e4ff7  libsystem_c.dylib (825.26) <4C9EB006-FE1F-3F8F-8074-DFD94CF2CE7B> /usr/lib/system/libsystem_c.dylib
        0x7fff968e5000 -     0x7fff968f2ff7  com.apple.NetAuth (4.0 - 4.0) <F5BC7D7D-AF28-3C83-A674-DADA48FF7810> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAut h
        0x7fff9690d000 -     0x7fff96967ff7  com.apple.opencl (2.2.19 - 2.2.19) <3C7DFB2C-B3F9-3447-A1FC-EAAA42181A6E> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
        0x7fff96968000 -     0x7fff9698ffff  com.apple.framework.familycontrols (4.1 - 410) <50F5A52C-8FB6-300A-977D-5CFDE4D5796B> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A /FamilyControls
        0x7fff96990000 -     0x7fff9699bff7  com.apple.DisplayServicesFW (2.7.2 - 357) <EC87A00D-FE9C-3CFE-A98C-063C3D23085A> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/ A/DisplayServices
        0x7fff969f3000 -     0x7fff96a4ffff  com.apple.QuickLookFramework (4.0 - 555.5) <8B9EAC35-98F3-3BF0-8B15-3A5FE39F150A> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
        0x7fff97a10000 -     0x7fff97a35ff7  libc++abi.dylib (26) <D86169F3-9F31-377A-9AF3-DB17142052E4> /usr/lib/libc++abi.dylib
        0x7fff97a82000 -     0x7fff97a90ff7  libkxld.dylib (2050.24.15) <A619A9AC-09AF-3FF3-95BF-F07CC530EC31> /usr/lib/system/libkxld.dylib
        0x7fff97a91000 -     0x7fff97df0fff  com.apple.Foundation (6.8 - 945.18) <1D7E58E6-FA3A-3CE8-AC85-B9D06B8C0AA0> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
        0x7fff97e42000 -     0x7fff97e46ff7  com.apple.TCC (1.0 - 1) <F2F3B753-FC73-3543-8BBE-859FDBB4D6A6> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
        0x7fff97e47000 -     0x7fff97f99fff  com.apple.audio.toolbox.AudioToolbox (1.9 - 1.9) <62770C0F-5600-3EF9-A893-8A234663FFF5> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToo lbox
        0x7fff97f9a000 -     0x7fff97fd5fff  com.apple.LDAPFramework (2.4.28 - 194.5) <7C71C445-2B52-3AC0-97E5-9F2E692C8F5C> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
        0x7fff97fd6000 -     0x7fff98007ff7  com.apple.DictionaryServices (1.2 - 184.4) <054F2D6F-9CFF-3EF1-9778-25C551B616C1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/DictionaryServices.framework/Versions/A/DictionaryServices
        0x7fff9819a000 -     0x7fff9829cfff  libcrypto.0.9.8.dylib (47.1) <72AA650B-0453-3BB4-BA03-824627BB199C> /usr/lib/libcrypto.0.9.8.dylib
        0x7fff9829d000 -     0x7fff982e0ff7  com.apple.RemoteViewServices (2.0 - 80.6) <5CFA361D-4853-3ACC-9EFC-A2AC1F43BA4B> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versio ns/A/RemoteViewServices
        0x7fff982e1000 -     0x7fff982edfff  com.apple.CrashReporterSupport (10.8.3 - 418) <DE6AFE16-D97E-399D-82ED-3522C773C36E> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Vers ions/A/CrashReporterSupport
        0x7fff982ee000 -     0x7fff982f1ff7  libdyld.dylib (210.2.3) <F59367C9-C110-382B-A695-9035A6DD387E> /usr/lib/system/libdyld.dylib
        0x7fff982f2000 -     0x7fff982f4ff7  libunc.dylib (25) <92805328-CD36-34FF-9436-571AB0485072> /usr/lib/system/libunc.dylib
        0x7fff985c7000 -     0x7fff985fdfff  com.apple.DebugSymbols (98 - 98) <14E788B1-4EB2-3FD7-934B-849534DFC198> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/D ebugSymbols
        0x7fff985fe000 -     0x7fff98666fff  libvDSP.dylib (380.6) <CD4C5EEB-9E63-30C4-8103-7A5EAEA0BE60> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvDSP.dylib
        0x7fff98667000 -     0x7fff98787fff  com.apple.desktopservices (1.7.4 - 1.7.4) <ED3DA8C0-160F-3CDC-B537-BF2E766AB7C1> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versi ons/A/DesktopServicesPriv
        0x7fff987ee000 -     0x7fff98857fff  libstdc++.6.dylib (56) <EAA2B53E-EADE-39CF-A0EF-FB9D4940672A> /usr/lib/libstdc++.6.dylib
    External Modification Summary:
      Calls made by other processes targeting this process:
        task_for_pid: 2
        thread_create: 0
        thread_set_state: 0
      Calls made by this process:
        task_for_pid: 0
        thread_create: 0
        thread_set_state: 0
      Calls made by all processes on this machine:
        task_for_pid: 531
        thread_create: 3
        thread_set_state: 0
    VM Region Summary:
    ReadOnly portion of Libraries: Total=386.6M resident=187.5M(48%) swapped_out_or_unallocated=199.1M(52%)
    Writable regions: Total=163.8M written=28.9M(18%) resident=84.6M(52%) swapped_out=0K(0%) unallocated=79.2M(48%)
    REGION TYPE                      VIRTUAL
    ATS (font support)                 32.3M
    ATS (font support) (reserved)         8K        reserved VM address space (unallocated)
    CG backing stores                  10.2M
    CG image                             32K
    CG shared images                   1216K
    CoreServices                       2584K
    MALLOC                             63.9M
    MALLOC guard page                    48K
    Memory tag=240                     16.0M
    Memory tag=242                       12K
    Memory tag=243                        4K
    SQLite page cache                   192K
    STACK GUARD                        56.1M
    Stack                              19.8M
    VM_ALLOCATE                        20.3M
    __DATA                             25.2M
    __IMAGE                             528K
    __LINKEDIT                        116.2M
    __TEXT                            270.4M
    __UNICODE                           544K
    mapped file                       314.2M
    shared memory                       308K
    TOTAL                             949.8M
    TOTAL, minus reserved VM space    949.8M
    Model: MacBookPro6,1, BootROM MBP61.0057.B0F, 2 processors, Intel Core i7, 2.8 GHz, 8 GB, SMC 1.57f17
    Graphics: Intel HD Graphics, Intel HD Graphics, Built-In, 288 MB
    Graphics: NVIDIA GeForce GT 330M, NVIDIA GeForce GT 330M, PCIe, 512 MB
    Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1067 MHz, 0x859B, 0x435434473353313036374D2E4D3136464D52
    Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1067 MHz, 0x859B, 0x435434473353313036374D2E4D3136464D52
    AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x93), Broadcom BCM43xx 1.0 (5.106.98.100.17)
    Bluetooth: Version 4.1.4f2 12041, 2 service, 18 devices, 1 incoming serial ports
    Network Service: Ethernet, Ethernet, en0
    Serial ATA Device: M4-CT512M4SSD2, 512.11 GB
    Serial ATA Device: MATSHITADVD-R   UJ-898, 787.6 MB
    USB Device: hub_device, 0x0424  (SMSC), 0x2514, 0xfa100000 / 2
    USB Device: BRCM2070 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0xfa110000 / 4
    USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8218, 0xfa113000 / 5
    USB Device: Apple Internal Keyboard / Trackpad, apple_vendor_id, 0x0237, 0xfa120000 / 3
    USB Device: hub_device, 0x0424  (SMSC), 0x2514, 0xfd100000 / 2
    USB Device: Keyboard Hub, apple_vendor_id, 0x1006, 0xfd140000 / 5
    USB Device: Microsoft Basic Optical Mouse v2.0, 0x045e  (Microsoft Corporation), 0x00cb, 0xfd141000 / 7
    USB Device: Apple Keyboard, apple_vendor_id, 0x0221, 0xfd142000 / 6
    USB Device: IR Receiver, apple_vendor_id, 0x8242, 0xfd120000 / 4
    USB Device: Built-in iSight, apple_vendor_id, 0x8507, 0xfd110000 / 3
    Jul 18, 2013 7:32 AM   in reply to York Gibson
    Hi York Gibson,
    This happens If you have flashfirebug plugin installed in firefox and its enabled. We are investigating the issue further for a fix. However, for the time being uninstalling the flashfirebug plugin should fix the crash. If you prefer editing the configuration files manually, then alternatively you can just comment out or remove the PreLoadSwf key in mm.cfg (found in your home folder) to avoid the crash.
    Let me know if this solution works for you.
    -Sujai
    Jul 19, 2013 1:49 AM   in reply to SujaiS
    Hi. Many thanks for this it worked fine for me.
