newenglandhorse1
Image Trace problems
Jun 19, 2013 9:07 AM
I've been unable to get a faithful image trace in Illustrator CS6.
With the default settings, large amounts of detail are being lost from large 600dpi images.
I have tried adjusting the Threshold , Paths, and Corners, but either more detail is lost, or paths converge
This is extremely perplexing. I am unable to produce work to the professional standards I need.
Below I have uploaded respectively 1) the original 600dpi grayscale image, 2) the image traced in CS3 on default settings, 3) the same image traced in CS3 on default settings, and 4) the same image traced in CS6 with Threshold raised.
fruitplate-bitmap.jpgfruitplate-trace-cs3.jpgfruitplate-trace-cs6.jpgfruitplate-trace-cs3-hi.threshold.jpg
    Jun 20, 2013 2:14 AM   in reply to newenglandhorse1
    Image trace simply doesn't like those high-contrast black-and-white images. Leave a little more anti-aliasing along the lines and you'll get better results.
    Jun 20, 2013 2:46 AM   in reply to newenglandhorse1
    The algorithm has been changed and that's the downside of it, unfortunately.
    Jun 20, 2013 3:27 AM   in reply to newenglandhorse1
    No, you're not the only one. Has been discussed some more times already.
    The upside is that many templates are a lot easier to trace. Especially stuff like colored comic drawings. In many cases you won't need to touch the options.
    Jun 20, 2013 4:58 AM   in reply to newenglandhorse1
    Sorry for that.
    What you can try and what might save you some work is to resample the placed file directly in Illustrator before tracing. scale it a little and convert to grayscale image via the Rasterize function.
