Putting Arrays to work: error 1065
Jun 20, 2013 4:34 PM
Hi all,
I have created this array which works well:
function initLetters():void
            for (var i:Number =0; i < lettersL1.length; i++)
                trace (lettersL1[i]); // traces perfectly
My next question: I want to do a lot of stuff with the objects in this array, (like suffle, appear at a certain x,y coordinate, change alpha, move along a path etc. All of wich I need to learn yet LOL)
                             Someone suggested that I add the following code to create a var to do this. When I add this I get the error code below. Is this the righ way to go for what I want?  Maybe it is in the wrong spot again?
   /*var C:Class=Class(getDefinitionByName(lettersL1[i]));
            var c:*=new C(); // create instances from the classes in lettersL1
                                        // do whatever with c*/
When I uncomment the above I suddenly get this error code:
ReferenceError: Error #1065: Variable [object A] is not defined.
    at global/flash.utils::getDefinitionByName()
    at LetterArray/initLetters()
    at LetterArray()
    at BugGoopFSGame()
My .as class code:
package
    import flash.display.*;
    import flash.events.*;
    import flash.text.*;
    import flash.utils.Timer;
    import flash.utils.getDefinitionByName;
    import flash.media.Sound;
    import flash.media.SoundChannel;
    import flash.net.URLRequest;
    public class LetterArray extends MovieClip
        private var _stage:Stage;
        //Movie clips to be used
        public var a:A = new A();//etc
        private var  lettersL1:Array = [a,f,g,h,i,n,o,s,t];
        //Text Fields and Format
                                                            //works well
                                                      //Sound Specs
                                                            //works well
        //***CONSTRUCTOR FUNCTION***
        public function LetterArray(s:Stage)
            _stage = stage;
            trace("Main construtor is working");
            //GameLoop
            initText();
            initLetters();
            initLetterWasClickedOn();
            initCheckIfLetterIsCorrect();
            initInGameAnimation();
            initRemoveLetterChildren();
            initPointsGiven();
    //OTHER FUNCTIONS
        function initText():void
                    // text formatting: general
                trace (lettersL1[i]); //trace works well
  • kglad
    Jul 21, 2002
    Jun 20, 2013 4:56 PM   in reply to Charine -FB buggoop
    do you have classes that match the contents of your array?
  • kglad
    Jul 21, 2002
    Jun 21, 2013 5:44 PM   in reply to Charine -FB buggoop
    if tracing lettersL1 does not yield strings (like "A","F",etc), you're not using getDefinitionByName correctly.
    in particular, if tracing lettersL1 yields a list of objects, you don't have strings in lettersL1.
    if that doesn't solve the problem for you, copy and paste lettersL1.
  • kglad
    Jul 21, 2002
    Jun 24, 2013 3:40 PM   in reply to Charine -FB buggoop
    then use:
    lettersL1[i].x =
    lettersL1[i].y=
    lettersL1[i].alpha=
    // i have no idea how you want to implement a path or even what you mean.
  • kglad
    Jul 21, 2002
    Jun 24, 2013 9:39 PM   in reply to Charine -FB buggoop
    if you have classes a,b,c,d defined and
    var lettersL1:Array=[a,b,c,d,...];
    you could use:
    var prevX:int=0;
    var letter:*=new lettersSl1[i]();
    letter.x = prevX;
    prevX+=letter.width+5;
    _stage.addChild(letter);
  • kglad
    Jul 21, 2002
    Jun 25, 2013 10:17 AM   in reply to Charine -FB buggoop
    does lettersL1 look like message 8?
    if yes, use that code to create objects.  if no, show lettersL1
  • kglad
    Jul 21, 2002
    Jun 26, 2013 5:09 AM   in reply to Charine -FB buggoop
    you're welcome.
