AI CC is unresponsive
Jun 20, 2013 4:54 PM
Tags: #problem #unresponsive #illustrator_cc
The program launches. That's about all it does.
Ex. I drew a box with a white fill and black border.
I tried to swap the fill and border and nothing happened.
I zoomed out and it showed the change.
Basically anytime I do something I have to adjust the zoom to get it to show the edit I wanted.
Then it won't let me close the document or quit the program.
Not sure what to do.
    Jun 20, 2013 5:05 PM   in reply to MCaneso
    What OS and it sounds as if your machine is at the limit of supporting AICC.
    Jun 21, 2013 5:21 AM   in reply to MCaneso
    Try deleting the preferences of illustrator. For that go to ~/Library/Preferences/Adobe Illustrator 17 settings/  & ~/Library/Application Support/Adobe/Adobe Illustrator 17/ folders
    Jun 25, 2013 11:51 AM   in reply to MCaneso
    I am having a similar problem. Also runnung System 10.6.8. AICC just doesn't respond. Sometimes I have to force quit because it won't even respond to "Command Q" or the "Quit" menu.
    Adobe says that 10.6.8 is the minimum for AICC but I guess they need to look into that further.
    Updating the system may seem to be the answer but we are also running other print industry specific software that is not ready for System 10.7 or 10.8 - software that is MUCH more expensive to upgrade.
    BTW- deleting the Preferences did nothing.
    Jun 25, 2013 1:01 PM   in reply to MCaneso
    I made a post with this exact same issue already but I'm on mac 10.7.5
    what hardware do you have? I think it may be a graphics card issue.
    Jun 25, 2013 1:06 PM   in reply to R.W. Miller
    tengo el mismo problema, mi sistema operativo es 10.8.4 yo no creo que sea un problema del OS
    esperemos que se arregle este detalle
    I have the same problem, my OS is 10.8.4 I do not think it's a problem of the OS
    hopefully they fix this detail
    Jun 26, 2013 4:53 AM   in reply to mec_os
    Here's my info:
    Model Name:iMac
      Model Identifier:iMac11,3
      Processor Name:Intel Core i5
      Processor Speed:3.6 GHz
      Number Of Processors:1
      Total Number Of Cores:2
      L2 Cache (per core):256 KB
      L3 Cache:4 MB
      Memory:4 GB
      Processor Interconnect Speed:6.4 GT/s
      Boot ROM Version:IM112.0057.B00
    Graphics:
    ATI Radeon HD 5670:
      Chipset Model:    ATI Radeon HD 5670
      Type:    GPU
      Bus:    PCIe
      PCIe Lane Width:    x16
      VRAM (Total):    512 MB
      Vendor:    ATI (0x1002)
    Jun 26, 2013 9:25 AM   in reply to MCaneso
    After a little further research, I found that some people were having similar troubles where fonts were an issue. After installing Verdana and Tahoma, the problem seems to have gone away.
    Fonts: the digital graphics "F" word!
    Jun 26, 2013 10:20 AM   in reply to R.W. Miller
    holy smokes, that did it RW! verdana and tahoma were completely missing from my system. I don't understand how that happened and you'd think they'd be included with the adobe suites.
    edit: I didn't even need to restart illustrator, I've had it opened since yesterday and the issues stopped immediately after turning the fonts on.
    Jun 26, 2013 2:11 PM   in reply to MCaneso
    I uninstall and install verdana and tahoma and follow my same problem any ideas?
    Jun 26, 2013 2:18 PM   in reply to hcigarroa
    Check the user permissions on two folders (sub-folders):
    1. <user>/Library/Application Support/Adobe/Adobe Illustrator 17
    2. <user>/Library/Preferences/Adobe Illustrator 17 Settings
    ~Raghuveer
    Jun 26, 2013 3:08 PM   in reply to Raghuveer Singh Bhunwal
    Screen Shot 2013-06-26 at 4.59.03 PM.pngScreen Shot 2013-06-26 at 5.00.00 PM.png
    here are the folders in these images, what do I check?
    Jun 27, 2013 7:28 PM   in reply to R.W. Miller
    everyone running a font admin soft MUST HAVE BOTH FONTS INSTALLED or else it doesnt respond
    Jul 1, 2013 2:45 PM   in reply to Raghuveer Singh Bhunwal
    Please help me resolve this problem, install the operating system parallels mavericks and install illustarador cc and worked well, does not have this problem,
    in the system which is the montain imac lion and install fonts and desistale and went back to install and corractamente fuinciona not anyone know how to solve it?
    thanks
    Jul 2, 2013 2:02 AM   in reply to hcigarroa
    Same problem here, just activated Verdana (Tahoma was already activated) And the problem is gone. I'm using FontExplorer 4. Thanks everyone!
    Aug 31, 2013 4:23 AM   in reply to Raghuveer Singh Bhunwal
    I'm also suffering from the unresponsive keystroke issue.
    Raghuveer, can you specify what exactly we should be checking please?
    Aug 31, 2013 6:02 AM   in reply to XyzeeCreative
    Can you please describe a little more that what you are observing on your system? (unresponsive keystroke ??)
    Also check wether the Verdana font is enabled or not.
    ~Raghuveer
    Sep 3, 2013 4:31 AM   in reply to Raghuveer Singh Bhunwal
    Hi Raghuveer, thanks for getting back to me. I do have Verdana enabled. There appear to be no duplicates either. My experience so far is that of illustrator intermittently (and with no discernible pattern) not registering keystrokes, sometimes after numerous presses with no response. Normally I attempt another action or click on an icon on the tools palette. This is true of both my USB connected keyboard and my macbook keyboard. If you need any further info just let me know.
    Sep 3, 2013 7:17 AM   in reply to XyzeeCreative
    I uninstall the font manager that used "suitecase" and stayed with the operating system brings "FontBook" verdana fonts there uninstall and install obtained thaoma and maverick operating system to install on a virtual machine I have them not Internet down once this is done the proigrama works perfectly. repair permissions greetings from mexico
Bookmarked By (1)
