Pyro1337
two users editing in the same project?
Jun 21, 2013 6:29 AM
We are using PP CS6 Mac and i would like to know if this is possible. The project is on a server that both users have access to. Is it possible for user A to edit sequence 1 and 2 and user B to edit sequence 3 at the same time?
    Jun 21, 2013 7:20 AM   in reply to Pyro1337
    I don't believe it will be possible.  You might even have troubles with just one person opening and saving the project with it stored on a server.  Ideally, you want everything stored locally.
    What you could do is have each editor work on his part, and when they're done, import those sequences into a new Master project for compilation.
    Jun 21, 2013 7:24 AM   in reply to Pyro1337
    Read about Adobe Anywhere http://www.adobe.com/products/adobeanywhere.html
    http://www.adobe.com/aboutadobe/pressroom/pressreleases/201304/040413A dobeAnywhere.html
    -launched at NAB 2013... final availability expected some time in 2013
    Jun 21, 2013 8:39 AM   in reply to Jim Simon
    Two users editing in the same project is not possible, you'll have the second editor's Premiere crashing as soon as it opens the project.
    Apart from this, working with everything stored on a shared file system isn't problem if sharing and permissions setup is ok. We've been doing this since CS6 release with no issues on Adobe softwares side.
    Adobe anywhere looks incredibly promising but will be far too expensive for small facilities (just take a look at the minimal hardware requirement).
    Jun 21, 2013 2:37 PM   in reply to Pyro1337
    Server hardware
    Qualified Systems:
        - Dell Systems Poweredge R720 2U
        - Hewlett-Packard SL250
    Adobe Anywhere Collaboration Hub
    Quantity required: 1
    Operating system: Microsoft Windows 2008 Server R2 Enterprise (64-bit)
    Network connection: Dual port 10Gbps FullDuplex Ethernet
    Adobe Mercury Streaming Engine
    Minimum quantity required: 3
    GPU required: NVIDIA Tesla K10
    Storage
    Qualified Systems:
         - Harmonic MediaGrid
         - Isilon X400 series
