Why are there gaps?
Jun 21, 2013 8:23 AM
Can anyone tell me why there are these two gaps,
1. just under the banner at the very top just above horizontal menu bar
2. just below the fading in and out image slideshow
www.milesfunerals.com/index3.html
    Jun 21, 2013 8:32 AM   in reply to Ness_quick
    Please use the blue "A" button to post links
    Not Found
    The requested URL /index3.html was not found on this server.
    Jun 21, 2013 8:35 AM   in reply to Ness_quick
    Add this to your css.
    #top img {
            display: block;
        #mainContent h1 {
            margin: 0;
            padding: 20px 0 0 0;
    Ken the url is www.milesmemorials.com/index3.html
    Jun 21, 2013 8:41 AM   in reply to osgood_
    In a page with a strict DOCTYPE (HTML5 is always strict), images must be
    set to remove baseline descender space. While display block will work it
    is usually not a good solution as it will effect the ability to float or
    display images adjacently. The preferred fix is usually to set a
    vertical-align property to a value of bottom.
    Al Sparber - PVII
    http://www.projectseven.com
    The Finest Dreamweaver Menus | Galleries | Widgets
    Since 1998
    Jun 21, 2013 9:11 AM   in reply to Ness_quick
    Ness_quick wrote:
    Osgood thats perfect thank you! Could you please explain to me why those gaps where there when there weren't any margins applied?
    Some tags like heading tags for instance h1, h2, h3 etc have default margins applied so you need to zero them out otherwise they may cause issues like the one you had.
    As for the image.........I think that is a browser specific issue. To get around that you have to turn it from an inline element (which it is by default) to a block level element using display: block;
    As you do more developing the more knowledge you will accumulate - you will become familiar with these issues and have the knowledge to correct them. I'm told there is good reason but I'm not really interested in reading techo stuff (which usually is a load of bullsh*t) I'm only interested in solutions so I can get the job done..
    Jun 21, 2013 9:19 AM   in reply to Al Sparber
    Al Sparber - PVII
    Since 1998
    Thanks for the information Al I didn't know that. I'm way behind the time - I'm not using HTML 5 doctype yet.
    Jun 21, 2013 9:47 AM   in reply to osgood_
    It's not a browser issue. Please see my post
    Al Sparber - PVII
    Since 1998
    Jun 21, 2013 9:51 AM   in reply to Al Sparber
    Al Sparber - PVII
    Since 1998
    Yeah I read your post see mine
    Jun 21, 2013 9:53 AM   in reply to osgood_
    Sorry I read Adobe forums in an email client ant there is no
    threading. My mistake.
