Uninstall Bridge CS6 - not listed in programs/control panel
Jun 21, 2013 9:17 AM
Hi  - I have updated my photoshop and bridge to the new Photoshop Creative Cloud.  I have successfully uninstalled Photoshop but when I look for Bridge CS6 (64 bit) there is nothing.  The new Bridge CC is listed.  Any suggestions on how I remove the old program?
    Jun 21, 2013 9:36 AM   in reply to David Babcock
    Bridge CS6 is installed with Photoshop CS6. You can't install/remove it separately.
    Jun 21, 2013 6:27 PM   in reply to Yammer
    I uninstalled Photoshop CS6 and Bridge CS6 remains.
    Bridge CC is separate and capable of being uninstalled induvidually.
    Jun 21, 2013 7:53 PM   in reply to vycanismajoris
    Yes, Bridge CC is now a separate program with its own install/uninstall program.
    Unless you just deleted CS6 Bridge will uninstall with it.
    Jun 29, 2013 5:12 PM   in reply to Curt Y
    Actually, when I used the Adobe uninstall program to remove Photoshop CS6, it did not uninstall Bridge CS6.  And, I cannot find an uninstall program for Bridge.  So, I am wondering if it is OK to just drag Bridge CS6 to the trash (on an iMac) after installing Bridge CC.
    Any thoughts?
    Jun 29, 2013 5:41 PM   in reply to jelliott2k
    Not a good idea.  If it did not uninstall CS6 bridge (should be version 5.x) you will have to use the Adobe Script Cleaner.
    Jul 7, 2013 4:27 PM   in reply to David Babcock
    I had the same problem, and I realized that bridge cs6 stays for any other cs6 appliation, once you uninstall all cs6 applications bridge cs6 will be gone. What I haven't tried yet is, if after installing bridge cc and then installing any cs6 application including photoshop cs6, will bridge cs6 be installed aswell or bridge cc will be taken as a replacement of any other bridge version?
    Jul 7, 2013 5:42 PM   in reply to 333newbie333
    Prior to CC version Bridge was not a seperate program but part of Photoshop.  So therefore it could neither be installed or deleted as a separate program.
    CC Bridge is a separate program, but there are several features removed over what prior versions had.
    Jul 7, 2013 6:08 PM   in reply to Curt Y
    Curt Y wrote:
    …CC Bridge is a separate program, but there are several features removed over what prior versions had.
    Really?
    So, far from fixing the gazillion bugs and adding enhancements and improvements, they trimmed it down?
    Jul 7, 2013 6:39 PM   in reply to station_two
      Adobe - always improving their software for the user.
    Unavailable in Adobe Bridge CC
    The following features are no longer available in this version of Adobe Bridge.
    • Adobe Output Module
    • Export Panel
    • Compact Mode
    • 3D File format thumbnails and previews
    • Synchronized window
  • Omke Oudeman
    Nov 27, 2004
    Jul 7, 2013 11:54 PM   in reply to 333newbie333
    and then installing any cs6 application including photoshop cs6, will bridge cs6 be installed aswell?
    To return to the original question, yes
    Installing PS CS6 also installs Bridge CS6. You can have multiple versions of CS installed on your computer without problem, as long as you have space. You can also  multiple versions of PS open and active at the same time if the resources of your computer are sufficient.
    However you can have only one version of Bridge open and active at the same time. If you want to switch to an older or newer version you first have to quit the open Bridge and start the other wanted version to use it.
    Also they use different Cache libraries so after opening it first have to read the cache (normally a short task) and also caching the new files (depending on amount and file size this can take some time) will start upon opening.
    Dec 22, 2013 6:25 AM   in reply to David Babcock
    I confirm after trying: deinstalling the last CS6 app using its standalon installer (in my case Illustrator) also removed Bridge CS6 and Media Encoder CS6.
Bookmarked By (1)
