like_it
Flex 4.5 QTP build with maven
Jun 21, 2013 11:26 AM
Hi
I have been struggling for last 2 days to make my swf file compatible with QTP . Initially I used the Flash Builder’s Compiler options to include the swc’s inside the swf and it worked perferctly fine with QTP .
Then the next task was the build the swf through MAVEN so that it could be used with auto-build tools like Jenkins. But after changing the POM , I could see the swf size had increased but with this swf file, QTP is not able to identify the object.
We are using Flex sdk : 4.5.1.21328 and Flex MOJO’s 4.0.-RC1 , I tried using higher version of SDK and Mojo but was not of much use . Any suggestions would be of great help. PFB the POM i am using
<?xml version="1.0" encoding="UTF-8"?>
<project>
<modelVersion>4.0.0</modelVersion>
<groupId>org.dummy.test</groupId>
<artifactId>flexmojos-simplist</artifactId>
<version>0.1-SNAPSHOT</version>
<packaging>swf</packaging>
<build>
  <sourceDirectory>src</sourceDirectory>
  <plugins>
   <plugin>
    <groupId>org.sonatype.flexmojos</groupId>
     <artifactId>flexmojos-maven-plugin</artifactId>
     <version>4.0-RC1</version>
     <extensions>true</extensions>
     <configuration>
       <sourceFile>SparkQTPTesting.mxml</sourceFile>
       <incremental>false</incremental>
       <swfVersion>12</swfVersion>
          </configuration>
       <dependencies>
                                  <dependency>
                                         <groupId>com.adobe.flex</groupId>
                                         <artifactId>compiler</artifactId>
                                         <version>4.5.1.21328</version>
                                         <type>pom</type>
                                  </dependency>
                           </dependencies>
     </plugin>
    </plugins>
   </build>
   <dependencies>
       <dependency>
       <groupId>com.adobe.flex.framework</groupId>
       <artifactId>flex-framework</artifactId>
       <type>pom</type>
       </dependency>
       <dependency>
                       <artifactId>automation_flashflexkit</artifactId>
                      <type>swc</type>
                                  <scope>internal</scope>
                     </dependency>
              <dependency>
                       <artifactId>automation</artifactId>
                      <type>swc</type>
                     </dependency>
                     <dependency>
                       <artifactId>automation_agent</artifactId>
                       <type>swc</type>
                     </dependency>
              <dependency>
                      <groupId>com.automation</groupId>
                       <artifactId>automation_rb</artifactId>
                      <type>swc</type>
                     </dependency>
                                         <dependency>
                       <artifactId>automation_agent_rb</artifactId>
                       <type>swc</type>
                     </dependency>
                           <dependency>
                             <artifactId>automation_dmv</artifactId>
                             <type>swc</type>
                           </dependency>
                                  <dependency>
                                     <artifactId>automation_spark</artifactId>
                                      <type>swc</type>
                                    </dependency>
       </dependencies>
   </project>
