brutha1209
ActionScript keeps guides visible in Flash CC
Jun 21, 2013 2:57 PM
Tags: #actionscript #guide #layers #cc
Hey Everyone,
Has anyone else noticed that when you Guide a layer in Flash CC (a camera guide for animation for example) the Guided layer is still part of a sequence export?
It seems to only work with Actionscript 1 or 2 which are both no longer supported in CC.
I still have more digging to do and will update discussion....
Mark
  • kglad
    Jul 21, 2002
    Jun 22, 2013 7:23 AM   in reply to brutha1209
    what do you mean by, ".. a sequence export"?
  • kglad
    Jul 21, 2002
    Jun 24, 2013 10:04 PM   in reply to brutha1209
    i see that problem, too.  i'll report the bug.
    in the mean time, you can use a motion tween and edit the tween path.
    Jul 3, 2013 12:18 PM   in reply to brutha1209
    I see the same behavior with an AS3 document in CS6 also. However, the behavior of AS2 vs AS3 document is different as you pointed out.
    Your problem can be solved though by hiding the guide layer before export. Can you please try and let us know if it works for you?
    -Dharmendra.
