Re: Photoshop CC - adjustment layer curves issue
Jun 21, 2013 3:59 PM
Tags: #bug #curves #bug_report #photoshop_cc #adjustment_curves
First post here in the discussion,
Just upgraded CS6 to CC and really enjoy alot of the changes but there seems to be a bug with the adjustment layer curves (not regular curves).
If I make a change to the curve using modification point and then toggle "undo", the preview of the image will toggle on and off with the change but the modification point does not reset. This point stays in the original position even if the curves are not in effect and will only reset when another layer is selected before returning back to these curves.
One must also manually reset the point if you wanted to revert back to the original (instead of undo) because if you place another modification point on the curve it will revert back to the change you made earlier.
Am I missing something or is this a bug?
Cheers!
- Elder
  • Trevor Dennis
    May 24, 2010
    Jun 21, 2013 5:30 PM   in reply to elderlad
    You are right.  Just tried it in CC and CS6.  In CS6 the curve shape updates in its properties panel as you step backwards with Ctrl Alt z.   In CC if you change the curve shape; click on another layer, then go back to Curves and change the shape, and repeat this a few times.   If you step back with Ctrl Alt z, the image changes, but the shape of the curve in the Properties panel stays the same.  You have to come out and go back to the Curve in properties panel to update the new shape.  Looks like a bug.
    Jun 27, 2013 2:34 AM   in reply to elderlad
    Just repeating what's already been said above.
    Having the same problem with Photoshop CC, tricky to explain this one:
    Working in Curves and/or Selective Color Adjustment layers (probably in any adjustment layer) is very buggy.
    When I do a change f.ex. let's say I'm tweaking inside curves and undo my last change it does reflect it on screen but not in the dialog/palette. So when I do my next tweak both my old tweak (not reflected on screen anymore but still there) and the new one goes into effect.
    It's driving me nuts and have forced me to go back to CS6.
    Adobe HEEEELP!!!!
    Mac Pro
    2 x 2.8 Ghz Quad-Core Intel Xeon
    24 GB 800 Mhz DDR2 FB-DIMM
    4 Disk RAID
    Running 10.6.8
    Jun 27, 2013 9:17 AM   in reply to RTO666
    I see the behavior difference you describe, and will open a bug for this. It clearly is a problem that was introduced somewhere between CS6 and CC. The CS6 behavior, of course, is correct.
    Paul
    Jul 22, 2013 10:30 AM   in reply to PDFerguson
    I'm having the same issue
    Jul 27, 2013 3:58 PM   in reply to PDFerguson
    Hey Paul,
    I see this was posted June 27, exactly a month ago....any news on when they might fix this bug? I'm like Elderlad I use this keyboard command constantly in my work flow. Thanks for keeping us up to date!
    Carrie Beene
    Jul 29, 2013 10:45 AM   in reply to therealCarrieBeene
    Hi Carrie,
    I can't comment on the dates or features of future releases of Photoshop, but this is a high priority bug because it affects a large number of users and is really bad behavior.
    Paul
    Jul 29, 2013 10:57 AM   in reply to PDFerguson
    Good to know it's high priority, thanks! And yes, it's very bad behavior!
    Aug 29, 2013 5:45 PM   in reply to therealCarrieBeene
    Casting my vote as someone waiting for a fix to this.
    LD
    Sep 16, 2013 6:26 PM   in reply to elderlad
    Ha! Yeah, I saw that too on my last update a couple days ago. YAHOO!
