Dummy importer
Jun 22, 2013 9:55 AM
Tags: #text #importer_api
Hi folks,
I'm trying to write a dummy importer that would essentially only put a file pointer in the project for reference and archival purposes, like FCP XML translations results text file which gets imported into the project.
I thought that perhaps setting hasVideo and hasAudio as false would do the job, but I keep getting the "Importer returned generic error" in Premiere and "file cannot be imported - this file is damaged or unsupported".
Currently the entry function looks like this:
     switch (selector)
          case imInit:
               result =     SDKInit(stdParms,
                                        reinterpret_cast(param1));
               break;
          case imGetInfo8:
               result =     SDKGetInfo8(stdParms,
                                             reinterpret_cast(param1),
                                             reinterpret_cast(param2));
               break;
          case imGetIndFormat:
               result =     SDKGetIndFormat(stdParms,
               break;
          case imGetIndPixelFormat:
               result = imUnsupported;
               break;
          // Importers that support the Premiere Pro 2.0 API must return malSupports8 for this selector
          case imGetSupports8:
               result = malSupports8;
               break;
     return result;
And only these 3 selectors are supported:
imInit
imGetFormat
imGetIndFormat
imInit and imGetIndFormat work fine, because the importer is added to the list, and attempts to open the file. And the imGetFormat looks like this:
          prMALError                         result                    = malNoError;
     SDKFileInfo8->hasAudio               = kPrFalse;
     SDKFileInfo8->hasVideo               = kPrFalse;
     return result;
Obviously I'm missing something, can anyone help me?
    Jun 23, 2013 8:06 PM   in reply to walczakb
    IIRC you have to have one or both of hasVideo and hasAudio true.
    Jun 24, 2013 8:19 PM   in reply to walczakb
    Hi walczakb,
    That's an interesting concept to add an importer for these files, but as Rallymax points out, the importer API is for video and/or audio.  Since you can just drag-and-drop a .txt file into the Project panel, it's possible you could make a script that sends .txt files to PPro.  Does that fit what you're trying to do?
    See this thread for importing a file using scripting - http://forums.adobe.com/thread/1177191
    Zac
    Jun 25, 2013 1:54 PM   in reply to walczakb
    I believe Trapcode Form's .obj support is implemented using an AEIO plug-in (from the After Effects SDK).  The AEIO probably exposes the 3D info via aux data, and the effect gets the aux data via PF_ChannelSuite which it uses for rendering.  The Premiere importer API doesn't support aux data, so I'm not sure if you were thinking of another mechanism in mind to pass non-visible frame data from the importer to an effect...?
    Jun 27, 2013 10:23 AM   in reply to walczakb
    Oh I see.  The Synth_Importer is used for stuff like Color Mattes and Universal Counting Leaders, which reference no actual file on disk.  Since you want to reference a file, it'd be better to start from the SDK_File_Importer sample.  Granted, there will be more code to trim out for your purposes, but you'll be working with actual files on disk.
    Jun 27, 2013 2:24 PM   in reply to walczakb
    One missing piece is in SDKGetInfo8, it doesn't specify the dimensions of the video. (This is not needed in Synth_Import because that defaults to the dimensions of the current sequence)  GetInfo8 is where the importer tells PPro details about the file it is about to import.
    Jun 28, 2013 10:09 AM   in reply to walczakb
    True, you'd need to handle opening the file in imOpenFile8, as well as imQuietFile and imCloseFile.
