sunflowers12
In 3D, remove backfaces dont work?
Jun 23, 2013 2:45 PM
Tags: #3d
Hi
http://youtu.be/Q7f1xOi9XAw
I do not need to draw on the back of the object.
Am I doing something wrong?
    Jun 23, 2013 6:37 PM   in reply to sunflowers12
    Go into your layers palette and double click on the diffuse layer to check the UVs of your sphere. The front and back maybe overlapping.
    Jun 24, 2013 6:25 PM   in reply to sunflowers12
    What mesh are you using for that spherical model? Was it imported or is that soemthing generated and modified in Ps?
    Removing backfaces is only at the rendering level of the Ps Scene; it doesn't remove triangles from the paint engine targeting. If you don't want to paint on triangles, try selecting an area you don't want painted then going to 3D> Show/Hide Polygons>
    I tried to mimic your sphere test with the sphere mesh provided in Ps and I can't paint on the backside as you're showing. Ps will paint and render the diffuse material on both front and backside of the targeted triangles, but what your movie shows is an odd UV mapping, as brenBot notes.
    regards,
    steve
    Jun 26, 2013 10:48 PM   in reply to sunflowers12
    Thanks for the video illustration. I see what you're talking about now. That video is using Ps CS4 and we've changed 3D interaction quite a bit over the versions. What version do you currently have, and on what platform do you run?
    I have noted a change in behavior with Ps CC and Ps CS6 from earlier versions in this regard (painting with backfaces hidden). I'm doing more background research and will log a bug for further investigation. As a workaround, you might try looking at the 3D> Show/Hide Polygons> commands to remove targets from you're painting.
    regards,
    steve
