How do you import photos from a Canon EOS 60d into Lightroom without distortion of photos?
Jun 24, 2013 9:48 AM
Tags: #import #canon #lightroom4
Is there a plug in needed or how does one get the photos from Canon EOS camera into Lightroom?  My come through looking distorted and noisy.
    Jun 24, 2013 9:53 AM   in reply to Camie62
    Distorted in what way? Can you show us a screen capture?
    Jun 24, 2013 9:54 AM   in reply to Camie62
    The first thing I would try is adjust one of the images until it looks right.  Remove the noise, and use the lens correction features and other adjustments to make it look the way you want it.  Then, save new camera defaults.  Those adjustments will then be applied whenever you import new images or click reset on images that have already been imported.
    Jun 24, 2013 10:18 AM   in reply to Camie62
    Still not clear what the problem is - Lightroom should have no problem with 60D files.
    OK: which version of Lr? And are the 60D files at high ISO?
    Jun 24, 2013 11:12 AM   in reply to Camie62
    Whoever it is that is telling you these things is not correct.
    Lightroom should have no trouble reading 60D files.
    Is the noise the only issue? You mentioned distortion. Is that an issue too? Can you describe the distortion?
    So both Keith and I are asking for a lot more information.
    Jun 24, 2013 4:21 PM   in reply to Camie62
    Gee, it sure would help if you showed us an example of what such a photo looks like.
    All of a sudden photos that look good at home were being sent to printer and I was being told they couldn't print them at all.
    We ask for details, but there are none here that we can use. "Couldn't print them"?? Why?
    What was your workflow? How did you edit this photo? What settings did you use on export from Lightroom?
    now they won't even accept my photos the quality is so bad.
    Exactly what does "Quality is so bad" mean?
    Again, what was your workflow? How did you edit the photo? What settings did you use on export?
    It sure would be nice if you could show us an example.
    Jun 24, 2013 4:27 PM   in reply to Camie62
    I'm a 60D user. No problems whatsoever. The RAW images import just fine. No extra noise of artifacts, etc.
    You need to provide more details like other's have asked. Include a screen capture.
