illustrator cc workspace doesn't update till next action
Jun 24, 2013 12:03 PM
I decided to install a tryout for illustrator cc but I can't do much in it because I can't see wat I've done till I do something else.
example - I draw a rectangle but nothing happens. I draw another rectangle and the canvas refreshes and shows the previous rectangle but not the new one. this happens with every tool. I select something, it doesn't show selected till I do something else.
and then I can't quit. command + q does nothing, but also selecting quit illustrator from the menu does nothing. I have to force quit it.
anybody else with this issue?
I also can't use the type touch tool because the controls don't show up till I do something else, but when I do something else ofcourse the type I wanted to change is no longer selected.
this Is on snow leopard, power mac 2.6 duo xeon processors.
edit: and pathfinder buttons are greyed out.
    Jun 26, 2013 6:31 AM   in reply to mec_os
    Yes. Exact same problem. Not in the tryout, but in the actual version of Illustrator CC. Everything works ‘one click later‘. Can’t close windows, not with the red dot, nor with Close command, nor with Cmd-W. Can’t quit the application either. Color + outline indicators never show the assets of the object I selected.
    Can someone please fix this like really quick?? Thanks.
    Jun 27, 2013 7:25 PM   in reply to Eli - Bourne
    i have exactly the same problem in my case i have both illustrator cs6 and cc and cs6 works excelent but cc will do that! and i have to force quit it.
    on lion 10.7.5
    corei5
    8gb ram
    tryout
    Jun 30, 2013 5:53 PM   in reply to mec_os
    Having the same issue. What's weird is that upon launch, it seems to work fine. After drawing a couple of items the lag time starts to set in. Can't select anything on pasteboard, red dot to close window stops working, have to force quit. Illustrator CS6 version works fine, all other CC apps work fine as well. Not sure what the issue is.
    Macbook Pro
    Snow Leopard
    Intel Core Duo
    8 GB Ram
    Jun 30, 2013 9:06 PM   in reply to mec_os
    Thanks for the info mec_os. I'll give that a try.
    Jul 21, 2013 7:55 PM   in reply to mec_os
    Hi all, I have the same problem too with Illustrator CC (tryout - just installed several days ago). I already have Tahoma and Verdana fonts installed but when I use offline, suddenly the problem appears. What should I do (if I want to use offline)? Thank you...
    Oct 16, 2013 9:32 AM   in reply to Tjien Kang
    Same here. Using Illustrator CC (17.0), OS X 10.6.8, iMac 3.4 GHz Intel Core i7, 8 gigs of RAM. Tahoma and Verdana are installed. Please help.
    Oct 24, 2013 2:46 PM   in reply to Inprov Ryan
    Same issue. We've tried re-installing Illustrator CC, Verdana & Tahoma and we've cleared out the font cache. Please help! Thank you!
    Nov 6, 2013 6:23 AM   in reply to Freckle_Face
    I finally got this issue cleared up, but it was a pain. I ended up wiping all CC apps and doing a fresh install. Yes, it's scorched earth, but thanks to some of the CC features, it was a lot easier than it has been in the past. And Illustrator has been great ever since.
    Nov 6, 2013 7:43 AM   in reply to Inprov Ryan
    There seems to be a couple different work-arounds. The only thing that worked for us was deleting the Preferences folder in Applications > Illustrator. Thanks all!
    Nov 6, 2013 7:53 AM   in reply to Freckle_Face
    Hi Guys, I was asked to install tahoma and verdana when I was installing dreamweaver. I installed them and thats when my problems started. Same symtoms as all you guys above. I was going crazy and read this thread. I went into my suitcase fusion 5 and activated both the fonts in there. Totally fixed the problem. I've Never had anything like this before CC. Adobe need to fix asap.
    Nov 18, 2013 2:15 AM   in reply to trueoutput
    In the latest update of  Adobe Illustrator CC, released about an hour ago, this bug has been fixed. For more details on this update, kindly refer to:
    http://helpx.adobe.com/illustrator/release-note/illustrator-17-0-1-rel ease-notes.html
    Thanks & Regards,
    Raghuveer
Bookmarked By (1)
