valentindascalita
50i footage best workflow for progressive output (web/youtube) / deinterlace
Jun 24, 2013 2:49 PM
Tags: #problem #youtube #premiere_pro #stutter #render #h264 #workflow #progressive #export_settings #sequence_settings #interlaced_to_progressive #50i #deinterlace #interlace #25p #deint
Hello
The reason I have to work with interlaced footage is that the clips are edited for a TV show as well.
I (usualy) get 1080i @ 50fps clips with fast-paced movement of camera & inside the shot (subject) - car racing.
Editing in Adobe Premiere Pro 5.5
I am struggling with some stutter & sharpness loss & thin interlaced lines (even after exporting as progressive).
The current workflow is:
          - importing inside an AVCHD - 1920x1080 @ 50i sequence
          - edit
          - export as h264 - 1920x1080 @ 25P /Constrant Bit Rate @ 10MB
Results not that great : while the smoothness of motion is preserved there is a visible drop in details quality and still visible thin horizontal lines from the interlaced footage.
Also tried:
          - importing inside an AVCHD - 1920x1080 @ 25P sequence
          - edit
          - select 'Always deinterlace' option inside Field Options box (takes extra some time because i have to do this for each individual clip)
Results not that great : stutter motion, more visible drop in details quality and no horizontal lines visible.
My questions are:
     1)What is the best sequence settings for editing 50i settings and exporting for WEB/progressive?
     2)What is the best deinterlace option? ('interpret footage>no field' does not help)
     3)What is the best output/export settings?
Thank you!
    Jun 24, 2013 2:59 PM   in reply to valentindascalita
    1. avchd 1080i50 sequence, same as footage.
    2. dont deinterlace on the timeline, no need unless you are adding speed changes to a clip.
    3. for web use a youtybe preset (H264). These outputs are progressive.
    Jun 24, 2013 3:30 PM   in reply to valentindascalita
    Show us.  Post a link.
    Jun 24, 2013 3:54 PM   in reply to valentindascalita
    OK.
    Next, post a screen shot of your export settings.  We need to see the full video tab and everything above it.
    Jun 24, 2013 8:25 PM   in reply to valentindascalita
    I'm not seeing anything obvious.  I would expect that to work fine and in fact my own 25i media turns out just fine.
    Jun 25, 2013 1:34 AM   in reply to Jim Simon
    Next step is to take a look at the original.
    Can you upload a clip with fast motion.
    Jun 25, 2013 9:13 AM   in reply to valentindascalita
    You are not using the Youtube preset
    Your preset shows that whilst it is h264 some settings have been changed over the default hence CUSTOM showing in the image, it is that you are just outputting a file specifically for your PC/MAC
    Other observations
    Why are you saving to your C drive?  Better to have multiple drives for editing, there are plenty of posts on drive management and setup
    Do you have the default Premiere settings for scratch discs etc?  These will use your C drive which will soon become filled, or at least overwhelmed with raed and wrtite problems
    Why are you saving the file at 10mbps?  Especially for motion my PAL HD MP4 progressive settings are 32 ave 40 max mbps
    Jun 25, 2013 10:58 AM   in reply to Biggles Lamb
    When checking Render at Max depth preset jumps to custom.
    Even at 10 mbps it should produce good quality/
