xampp error message
Jun 24, 2013 6:35 PM
Tags: #php
When I try to access PHPMyAdmin, I get this error message:
How do I fix this so I can access it?
    Jun 24, 2013 7:02 PM   in reply to future-architect
    Hi future-architect,
    Can you check out the discussion on the thread in the time that the other experts get back to you?
    http://www.apachefriends.org/f/viewtopic.php?p=149788
    Preran
    Jun 24, 2013 11:41 PM   in reply to future-architect
    Which version?
    I ask this because the last versions of windows use IPV6 and you would probably need a IPv6 Listen directive in the Apache httpd.conf. I don't know what you have in your .conf at the moment.
    Jun 25, 2013 2:54 AM   in reply to future-architect
    1) Open Apache(httpd-xampp.conf) by clicking on the Config buton for Apache.
    2) Search for <Directory "C:/xampp/phpmyadmin">
    3) Now just add Require all granted before </Directory>
    4) So the code will look like this.
    <Directory "C:/xampp/phpMyAdmin">
            AllowOverride AuthConfig
            Require all granted
    </Directory>
    5) Now finally Restart the xampp.
    Regards
    Bhawna
    Jun 25, 2013 8:56 PM   in reply to future-architect
    Can you check in your "php.ini" file whether you have got a line such as:
    session.save_path = "c:/temp"
    If you don't have this then I suggest enter it or enable it by removing the semi-colon infront of the line.
    You also need to make sure that on your system there is a folder called temp in the root folder.
    When you have done this, restart the apache server or restart the machine so that the changes take effect.
    This should work now.
    Jun 25, 2013 10:15 PM   in reply to future-architect
    You have not yet stated the version of windows, so I shall assume W8. In that case you should have the following lines in the hosts file
    # localhost name resolution is handled within DNS itself.
        127.0.0.1       localhost
                   ::1       localhost
    The hosts file can be found in Windows/System32/Drivers/etc
    Jul 2, 2013 7:39 AM   in reply to future-architect
    Jul 3, 2013 9:36 AM   in reply to future-architect
    future-architect wrote:
    I am not able to locate it anywhere.  Can I download the config file from somewhere?
    Perhaps you should search for: "config.sample.inc.php".  It should be in the same folder as phpMyAdmin.  This folder should be in your htdocs folder.  To download the file, the easiest way is to download the phpMyAdmin from the source location in the web.  Make sure it is the same version as your own.  The file looks like this:
    <?php
    /* vim: set expandtab sw=4 ts=4 sts=4: */
    * phpMyAdmin sample configuration, you can use it as base for
    * manual configuration. For easier setup you can use setup/
    * All directives are explained in documentation in the doc/ folder
    * or at <http://docs.phpmyadmin.net/>.
    * @package PhpMyAdmin
    * This is needed for cookie based authentication to encrypt password in
    * cookie
    $cfg['blowfish_secret'] = 'a8b7c6d'; /* YOU MUST FILL IN THIS FOR COOKIE AUTH! */
    * Servers configuration
    $i = 0;
    * First server
    $i++;
    /* Authentication type */
    $cfg['Servers'][$i]['auth_type'] = 'cookie';
    /* Server parameters */
    $cfg['Servers'][$i]['host'] = 'localhost';
    $cfg['Servers'][$i]['connect_type'] = 'tcp';
    $cfg['Servers'][$i]['compress'] = false;
    /* Select mysql if your server does not have mysqli */
    $cfg['Servers'][$i]['extension'] = 'mysqli';
    $cfg['Servers'][$i]['AllowNoPassword'] = false;
    * phpMyAdmin configuration storage settings.
    /* User used to manipulate with storage */
    // $cfg['Servers'][$i]['controlhost'] = '';
    // $cfg['Servers'][$i]['controluser'] = 'pma';
    // $cfg['Servers'][$i]['controlpass'] = 'pmapass';
    /* Storage database and tables */
    // $cfg['Servers'][$i]['pmadb'] = 'phpmyadmin';
    // $cfg['Servers'][$i]['bookmarktable'] = 'pma__bookmark';
    // $cfg['Servers'][$i]['relation'] = 'pma__relation';
    // $cfg['Servers'][$i]['table_info'] = 'pma__table_info';
    // $cfg['Servers'][$i]['table_coords'] = 'pma__table_coords';
    // $cfg['Servers'][$i]['pdf_pages'] = 'pma__pdf_pages';
    // $cfg['Servers'][$i]['column_info'] = 'pma__column_info';
    // $cfg['Servers'][$i]['history'] = 'pma__history';
    // $cfg['Servers'][$i]['table_uiprefs'] = 'pma__table_uiprefs';
    // $cfg['Servers'][$i]['tracking'] = 'pma__tracking';
    // $cfg['Servers'][$i]['designer_coords'] = 'pma__designer_coords';
    // $cfg['Servers'][$i]['userconfig'] = 'pma__userconfig';
    // $cfg['Servers'][$i]['recent'] = 'pma__recent';
    /* Contrib / Swekey authentication */
    // $cfg['Servers'][$i]['auth_swekey_config'] = '/etc/swekey-pma.conf';
    * End of servers configuration
    * Directories for saving/loading files from server
    $cfg['UploadDir'] = '';
    $cfg['SaveDir'] = '';
    * Defines whether a user should be displayed a "show all (records)"
    * button in browse mode or not.
    * default = false
    //$cfg['ShowAll'] = true;
    * Number of rows displayed when browsing a result set. If the result
    * set contains more rows, "Previous" and "Next".
    * default = 30
    //$cfg['MaxRows'] = 50;
    * disallow editing of binary fields
    * valid values are:
    * false allow editing
    * 'blob' allow editing except for BLOB fields
    * 'noblob' disallow editing except for BLOB fields
    * 'all' disallow editing
    * default = blob
    //$cfg['ProtectBinary'] = 'false';
    * Default language to use, if not browser-defined or user-defined
    * (you find all languages in the locale folder)
    * uncomment the desired line:
    * default = 'en'
    //$cfg['DefaultLang'] = 'en';
    //$cfg['DefaultLang'] = 'de';
    * default display direction (horizontal|vertical|horizontalflipped)
    //$cfg['DefaultDisplay'] = 'vertical';
    * How many columns should be used for table display of a database?
    * (a value larger than 1 results in some information being hidden)
    * default = 1
    //$cfg['PropertiesNumColumns'] = 2;
    * Set to true if you want DB-based query history.If false, this utilizes
    * JS-routines to display query history (lost by window close)
    * This requires configuration storage enabled, see above.
    * default = false
    //$cfg['QueryHistoryDB'] = true;
    * When using DB-based query history, how many entries should be kept?
    * default = 25
    //$cfg['QueryHistoryMax'] = 100;
    * You can find more configuration options in the documentation
    * in the doc/ folder or at <http://docs.phpmyadmin.net/>.
    I am not running Xampp but my setup is from the actual source of individual applications:  Apache, MySQL, PhpMyAdmin, PHP, and other applications like wordpress, drupal, joomla, etc etc.
    I run my own web server so that I don't have to rely on anybody.
    Jul 11, 2013 10:41 PM   in reply to future-architect
    try this link.. hope it can help you.
