Manas66
Remote Call to Blazeds and displaying the result set in grid
Jun 25, 2013 3:49 AM
Tags: #flex #blazeds #flash_builder_4.7
I want to call a remote method using Flex application from Blazeds and display the values in DataGrid. Can anyone help in this ?
-- I am using AMFChannel
-- The method to be called is PolicyApnVO.getPoliciesApn()
-- Please advice any correction if required
Here is the mxml code :
<mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
                creationComplete="initApp()" viewSourceURL="srcview/index.html">
    Simple client to demonstrate runtime configuration of destinations.
    The "runtime-employee" destination is configured in
    EmployeeRuntimeRemotingDestination.java.
    <mx:Script>
        <![CDATA[
            import mx.messaging.ChannelSet;
            import mx.messaging.channels.AMFChannel;
            import mx.rpc.remoting.mxml.RemoteObject;
            [Bindable]
            public var srv:RemoteObject;
            public function initApp():void
                var channel:AMFChannel = new AMFChannel("my-amf", "http://192.168.102.208:8400/policyAnalytics/messagebroker/amf");
                var channelSet:ChannelSet = new ChannelSet();
                channelSet.addChannel(channel);
                srv = new RemoteObject();
                srv.destination="runtime-policy";
                srv.channelSet = channelSet;
                srv.PolicyApnVO.getPoliciesApn();
    </mx:Script>
    <mx:Panel title="Policy Details" width="100%" height="100%">
        <mx:DataGrid width="100%" height="100%" dataProvider="{srv.PolicyApnVO.getPoliciesApn.lastResult.data.result} "
                     showDataTips="true">
            <mx:columns>
                <mx:DataGridColumn headerText="APN Id" dataField="apnId"/>
                <mx:DataGridColumn headerText="APN Name" dataField="apnName"/>
                <mx:DataGridColumn headerText="Policy ID" dataField="policyId"/>
                <mx:DataGridColumn headerText="Policy Name" dataField="policyName"/>
            </mx:columns>
        </mx:DataGrid>
    </mx:Panel>
</mx:Application>
    Jun 25, 2013 7:22 AM   in reply to Manas66
    There may be other ways to do this but here's what I would do:
    1) add a results method to the remote object:
    src.result="onResult(event.result)";
    2) add the callback method: private function onResult(event : * = null)
    :void{
                                                         if(event is
    ArrayCollection)
        myData =
    ArrayCollection(event);
    3) add the variable: Re: Remote Call to Blazeds and displaying the result set in grid private var myData:ArrayCollection;
    4) make the dataProvider for the grid use the my data :
    dataProvider=""
    You can probably avoid all this by adjusting your dataProvider. I am just
    not sure what it would be without experimenting. But definitely not what
    you have. Maybe just {svc.result}.
