VNemo
Create-Item stored procedure return error for hte parameter
Jun 25, 2013 6:57 AM
Tags: #adobe #flex #adep #data_services
I'm getting the following error when I create an item with the data services:
INFO: [Data Services] [DEBUG] SQL Assembler jdbc exception on operation=create-item error=com.microsoft.sqlserver.jdbc.SQLServerException: The value is not set for the parameter number 1.
    at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDriverError(S QLServerException.java:190
Configuration settings are:
      <source>flex.data.assemblers.SQLAssembler</source>
      <scope>application</scope>
      <metadata>
        <identity property="TO_ID" undefined-value="0" />
      </metadata>
        <create-item>
          <procedure name="spMob_TakeOff_Details_Header_Insert">
            <procedure-param property-value="#ID#" type="OUT"/>
            <procedure-param property-value="#Session_ID#" />
            <procedure-param property-value="#Notes#" />
          </procedure>
        </create-item>
ID always has value equal to 0, and this procedure always falls.
Could anyone help or explain to fix this?
Could this be bug of JDBC (https://bugs.eclipse.org/bugs/show_bug.cgi?id=385627)?
